Aeotec siren
Sun Aug 11, 2019 2:11 pm
Re: Aeotec siren
This one requires a pretty complicated definition with custom code, so it is a bit tricky. When you sync'd it with Indigo did it create multiple devices? If so you can try sending it raw Z-Wave commands. One of these two will probably turn on the siren:
0x20 0x01 0xFF
0x25 0x01 0xFF
and one of these two will turn it off:
0x20 0x01 0x00
0x25 0x01 0x00
I'm not sure which device you should send it to that Indigo created during the sync, so you'll just need to try them all. It is probably one of the last ones. Note that once the version of Indigo is released that supports your Aeotec module version you will need to re-sync the device, and the devices that get created may be in a different order than what they are for you currently. That is, the device you end up sending the raw command to will likely end up being wrong after you get the new version, which is probably fine because you'll want to switch over from using the raw commands to using the Turn On/Off commands anyhow (so you'll be changing your actions/logic regardless).
Sun Aug 11, 2019 2:29 pm
rapamatic offline
Re: Aeotec siren
Indigo only created one device, an "AV Control Point"
Here's the data dump:
  Z-Wave                          Indigo Device "032 - Chime" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.124
Node ID: 32
Model: AV Control Point
Model ID: 010300A4
Manufacturer: Aeon Labs
Manufacturer ID: 0371
Protocol Version: 5.03
Application Version: 1.04
Model Definition Version: 0
Library Type: 3
Class Name: AV Control Point
Class Hierarchy: 04 : 03 : 01
Command Class Base: 00
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 79v1 7Av1
Multi-Endpoint Types: 1:(03 : 01), 2:(03 : 01), 3:(03 : 01), 4:(03 : 01), 5:(03 : 01), 6:(03 : 01), 7:(03 : 01), 8:(03 : 01)
Multi-Endpoint Classes: 1:[5E 98 9F 6C 85 59 8E 71 79], 2:[5E 98 9F 6C 85 59 8E 71 79], 3:[5E 98 9F 6C 85 59 8E 71 79], 4:[5E 98 9F 6C 85 59 8E 71 79], 5:[5E 98 9F 6C 85 59 8E 71 79], 6:[5E 98 9F 6C 85 59 8E 71 79], 7:[5E 98 9F 6C 85 59 8E 71 79], 8:[5E 98 9F 6C 85 59 8E 71 79]
Features: routing, beaming, security
Neighbors: 3, 4, 6, 9, 13, 17, 27
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[]
Config Values: - none -
I'm much less interested in this as a siren, more for chimes when outdoor motion is detected or for doors opening (like with a security system). I'll try those codes, but it may be better to wait - don't want the siren to be going off while I'm at work and the wife has to smash the siren to get it to shut off.
Sun Aug 11, 2019 2:41 pm
Re: Aeotec siren
I suspect it isn't going to work sending it to the root device. Probably best to wait for the next version of Indigo for support on this one.
Sun Aug 11, 2019 2:53 pm
rapamatic offline
Re: Aeotec siren
For what it's worth, the first command, 0X20 0X01 0XFF made a long doorbell-type sound go off, only one time (no need to stop).
I'm eagerly awaiting the next release :)
Sun Aug 11, 2019 3:38 pm
Re: Aeotec siren
Great – I'm glad that at least worked. Will be much better in next release for you.
Sat Sep 14, 2019 9:44 am
zoff offline
Re: Aeotec siren
Does anyone have a command to get the siren to sound like a siren instead of a door bell?
Sat Sep 14, 2019 9:57 am
Re: Aeotec siren
Does your device sync event log show Model ID: 010300A4 as well? If so, the option to change the tone/volume will be in the next (soon to be released) version of Indigo.
Sun Sep 15, 2019 4:43 am
danielw offline
Re: Aeotec siren
Matt, can you confirm that also the standalone Indoor Siren ZW164-C will be supported in that same version? My Model ID: 000300A4
Currently I don't even get the raw z-wave commands to work :-( - but it's ok to wait for the upcoming version for now.
Node ID: 47
Model ID: 000300A4
Library Type: 3
Encryption Status: Enabled for Commands 85 86 8E 59 5A 60 70 71 73 79 7A
Multi-Endpoint Classes: 1:[5E 98 9F 6C], 2:[5E 98 9F 6C], 3:[5E 98 9F 6C], 4:[5E 98 9F 6C], 5:[5E 98 9F 6C], 6:[5E 98 9F 6C], 7:[5E 98 9F 6C], 8:[5E 98 9F 6C]
Neighbors: 1, 6, 12, 15, 17, 19, 22, 23, 27, 31, 35, 36, 37, 41
Daniel
Sun Sep 15, 2019 2:09 pm
Re: Aeotec siren
Looks like the Indigo Siren 6 is just the Doorbell 6 without the remote doorbell button. We'll add it to the device definitions as well.
Mon Sep 30, 2019 4:02 pm
Re: Aeotec siren
Indigo 7.4 is now available and includes support for the Aeotec Indoor Siren 6 (ZW164) and a new variant of the Doorbell 6 (ZW162).
Tue Oct 01, 2019 3:19 am
danielw offline
Re: Aeotec siren
Sweet - but how to trigger it? :?
I have re-synced my ZW164 device and now getting 5 devices as expected. When I want to execute button 1 (as example) in a trigger with action type "Turn On (Light/appliance Control)" it fails me (Same with Toggle):
Z-Wave Error device "Siren - Button 1" does not support on command
Tue Oct 01, 2019 8:39 am
Re: Aeotec siren
Can you copy/paste the Event Log results of the sync for me into a reply?
Tue Oct 01, 2019 3:15 pm
danielw offline
Re: Aeotec siren
2019-10-01 10:08:43.742 Z-Wave Syncing - started for "Siren"
2019-10-01 10:08:43.796 Z-Wave Syncing - retrieved module neighbors list: 1, 6, 12, 15, 17, 19, 22, 23, 27, 31, 35, 36, 37, 41
2019-10-01 10:08:43.797 Z-Wave Syncing - assigning return route to "047 - Siren"
2019-10-01 10:08:44.039 Z-Wave Syncing - assigned return route
2019-10-01 10:08:45.254 Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0371, Indoor Siren 6 (ZW164) - 000300A4
2019-10-01 10:08:45.914 Z-Wave Syncing - retrieved protocol version 5.03, app version 1.04
2019-10-01 10:08:53.236 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : AV Control Point : -- (04 : 03 : 01, base 00)
2019-10-01 10:08:53.236 Z-Wave Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 6Cv1 8Ev1 70v1 71v1 72v1 73v1 55v1 59v1 98v1 79v1 5Av1 7Av1 5Ev1 9Fv1
2019-10-01 10:08:53.236 Z-Wave Syncing - retrieved encrypt commands: 60 85 86 8E 70 71 73 59 79 5A 7A
2019-10-01 10:08:53.237 Z-Wave Syncing - retrieved capabilities: routing, beaming, security
2019-10-01 10:09:07.916 Z-Wave Syncing - retrieved multi-endpoint types: 1:(03 : 01), 2:(03 : 01), 3:(03 : 01), 4:(03 : 01), 5:(03 : 01), 6:(03 : 01), 7:(03 : 01), 8:(03 : 01)
2019-10-01 10:09:07.916 Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 98 9F 6C], 2:[5E 98 9F 6C], 3:[5E 98 9F 6C], 4:[5E 98 9F 6C], 5:[5E 98 9F 6C], 6:[5E 98 9F 6C], 7:[5E 98 9F 6C], 8:[5E 98 9F 6C]
2019-10-01 10:09:22.453 Z-Wave Syncing - retrieved group 1 associations: []
2019-10-01 10:09:29.742 Z-Wave Syncing - retrieved group 2 associations: []
2019-10-01 10:09:37.092 Z-Wave Syncing - retrieved group 3 associations: []
2019-10-01 10:09:44.375 Z-Wave Syncing - retrieved group 4 associations: []
2019-10-01 10:09:51.669 Z-Wave Syncing - retrieved group 5 associations: []
2019-10-01 10:09:58.975 Z-Wave Syncing - retrieved group 6 associations: []
2019-10-01 10:10:06.262 Z-Wave Syncing - retrieved group 7 associations: []
2019-10-01 10:10:13.611 Z-Wave Syncing - retrieved group 8 associations: []
2019-10-01 10:10:20.890 Z-Wave Syncing - retrieved group 9 associations: []
2019-10-01 10:10:21.380 Z-Wave Syncing - added group 1 multi association to interface
2019-10-01 10:10:21.547 Z-Wave Syncing - changed device "Siren" type from zwCustomType to zwSoundSwitchType
2019-10-01 10:10:21.575 Z-Wave Syncing - created device "047 - Button 2"
2019-10-01 10:10:21.584 Z-Wave Syncing - created device "047 - Button 3"
2019-10-01 10:10:21.596 Z-Wave Syncing - created device "047 - Security Siren"
2019-10-01 10:10:21.605 Z-Wave Syncing - created device "047 - Tamper Alert"
2019-10-01 10:10:21.611 Z-Wave Syncing - complete
2019-10-01 10:10:21.647 Z-Wave Error device "Siren" does not support status request command
Tue Oct 01, 2019 3:28 pm
Re: Aeotec siren
Looks like you included the module with encryption and that is causing some confusion as to what commands Indigo thinks it supports. Try excluding it and re-including it without encryption (then re-syncing it) and I believe it will work. It requires a complicated device definition so getting it working with encryption is going to take some additional work on our end.
Tue Oct 01, 2019 3:44 pm
danielw offline
Re: Aeotec siren
Yep now it works without encryption.
Thank you for the swift response, truly amazing.
Z-Wave Syncing - started for "049 - AV Control Point"
Z-Wave Syncing - retrieved module neighbors list: 1, 6, 12, 15, 17, 19, 22, 23, 28, 31, 35, 36, 37, 41
Z-Wave Syncing - assigning return route to "049 - AV Control Point"
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 8Ev1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 79v1 7Av1
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 98 9F 6C 85 59 8E 71 79], 2:[5E 98 9F 6C 85 59 8E 71 79], 3:[5E 98 9F 6C 85 59 8E 71 79], 4:[5E 98 9F 6C 85 59 8E 71 79], 5:[5E 98 9F 6C 85 59 8E 71 79], 6:[5E 98 9F 6C 85 59 8E 71 79], 7:[5E 98 9F 6C 85 59 8E 71 79], 8:[5E 98 9F 6C 85 59 8E 71 79]
Z-Wave Syncing - created device "049 - Button 1"
Z-Wave Syncing - created device "049 - Button 2"
Z-Wave Syncing - created device "049 - Button 3"
Z-Wave Syncing - created device "049 - Security Siren"
Z-Wave Syncing - created device "049 - Tamper Alert"
Z-Wave sent "049 - Button 1" status request
Z-Wave sent "049 - Button 2" status request
Z-Wave sent "049 - Button 3" status request
Z-Wave sent "049 - Security Siren" status request
Z-Wave sent "049 - Tamper Alert" status request
