The manual for Aeotec Garage Door Controller ZW062 is very vague about the 'motor control' cable connection.
Can anyone confirm how this aspect works?
Is it merely a momentary close of circuit to mimic an on wall toggle switch or something more sophisticated?
https://aeotec.com/z-wave-garage-door-controller - says "Simply connects to your garage door’s existing motor via two cables."
I am looking at this because my current solution uses a relay & sensor solution that seems to have stopped working with Indigo 7.3 (the device now reports as a relay without the sensors).
Any experience with the ZW062 most welcome!
regards
MM
