Thanks for any help!
Indigo Z-Wave Version: 2.0.121
Node ID: 60
Model: Door/Window Sensor (Strips Guard)
Model ID: 00030003
Manufacturer: Sensative
Manufacturer ID: 019A
Protocol Version: 4.05
Application Version: 10.08
Model Definition Version: 1
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2, 3, 4, 5, 6, 7, 8, 12, 14, 18, 19, 20, 21, 22, 25, 26, 28, 29, 31, 32, 33, 34, 46, 47, 48
Associations: 1:[1]
Config Values: 1:0 2:1
The LED is still flashing so not sure about the 24 hr reporting in change working so someone please help -- this was the only way to monitor my sliding glass door lock and it was not cheap
