matt (support) wrote:With debug logging enabled: Use the Interfaces->Z-Wave->Manage Associations... menu to remove the Z-Wave Interfaces from the Responding Devices list for Group #1, then close that dialog and re-sync the device and try both inputs again. Presuming IN2 still doesn't work (it might), copy/paste the Event Log results showing the results of everything.
Hi @Matt,
Proceeded as requested above. Binary IN2 switching still doesn't seem to be received by Indigo.
Here is the debug log:
14 Feb 2020 12:02:06
Z-Wave Debug SENT removeAssociation: 01 0B 00 13 68 04 85 04 01 01 25 7F 50
Z-Wave Debug RCVD removeAssociation: 01 05 00 13 7F 00 96 (node ACK)
Z-Wave removed association of "001 - Indigo Z-Wave Interface" from "Sensor Novo Piscina - Binary IN1" group 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 68 03 85 02 01 25 80 AE
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 80 00 69 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 68 05 85 03 01 01 00 1B
Z-Wave Debug . . requestAssociations: node 104, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 104, group: 1, associations: []
Z-Wave retrieved group 1 associations: []
14 Feb 2020 12:02:31
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 57 09 71 05 00 00 00 FF 06 16 00 31
Z-Wave Debug . . requestAlarmSensorStatus: node 087, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 22, classSubKeyExt 7100000616
Z-Wave Debug . . requestAlarmSensorStatus: defnStatusByte 255
Z-Wave received "Sensor Lavanderia - Dry Contact" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 57 09 71 05 00 00 00 FF 06 17 00 30
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 6, valueExt 23, classSubKeyExt 7100000617
Z-Wave Debug . . requestAlarmSensorStatus: defnStatusByte 0
Z-Wave received "Sensor Lavanderia - Dry Contact" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 58 09 71 05 00 00 00 FF 06 16 00 3E
Z-Wave Debug . . requestAlarmSensorStatus: node 088, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave received "Sensor Varanda - Dry Contact" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 58 09 71 05 00 00 00 FF 06 17 00 3F
Z-Wave received "Sensor Varanda - Dry Contact" status update is off
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Sensor Novo Piscina - Binary IN1"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 68 01 01 11
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 08 00 00 8C 00 08 22 00 00 04 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 104, neighbors: 20, 43, 44, 48, 60, 66, 70, 91, 102, 103
Z-Wave Syncing - retrieved module neighbors list: 20, 43, 44, 48, 60, 66, 70, 91, 102, 103
Z-Wave Syncing - assigning return route to "104 - Sensor Novo Piscina - Binary IN1"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 68 01 D5
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 104, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 68 24 81 54
Z-Wave Debug RCVD nodeInfoFrame: 01 1F 00 49 84 68 19 04 07 01 5E 25 85 8E 59 55 86 72 5A 73 98 9F 5B 31 60 70 56 71 75 7A 6C 22 E4
Z-Wave Debug . . nodeInfoFrame: node 104, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 68 02 72 04 25 82 5E
Z-Wave Debug RCVD requestManufactureInfo: 01 05 00 13 82 00 6B (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 68 08 72 05 01 0F 05 02 20 00 CB
Z-Wave Debug . . requestManufactureInfo: node 104, manufacturerId 010F, productId 05022000
Z-Wave Debug . . requestManufactureInfo: Fibaro System, Smart Implant (FGBS222)
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smart Implant (FGBS222) - 05022000
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000617, 0 (0.0008 secs)
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000617, 0 (0.0010 secs)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 68 02 86 11 25 83 BE
Z-Wave Debug RCVD requestVersInfoGen: 01 05 00 13 83 00 6A (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 68 09 86 12 03 06 02 05 01 02 00 00
Z-Wave Debug . . requestVersInfoGen: node 104, protoVers 6.02, appVers 5.01
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 68 03 86 13 31 25 84 88
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 05 00 13 84 00 6D (node ACK)
Z-Wave Debug . . requestVersInfoCmdClass: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 68 04 86 14 31 0B 35
Z-Wave Debug . . requestVersInfoCmdClass: node 104, class command 31 using version 11
Z-Wave Debug . . requestVersInfoCmdClass: node 104, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 68 03 86 13 60 25 85 D8
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 05 00 13 85 00 6C (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 68 04 86 14 60 04 6B
Z-Wave Debug . . requestVersInfoCmdClass: node 104, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 104, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 68 02 60 07 25 86 4B
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 05 00 13 86 00 6F (node ACK)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 68 05 60 08 00 07 00 F2
Z-Wave Debug . . requestMultiEndPointInfo: node 104, numEndPoints 7, sameClass False, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 01 25 87 47
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 87 00 6E (node ACK)
Z-Wave Debug . . requestMultiEndPointDetails: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 68 0E 60 0A 01 07 01 5E 85 8E 59 71 6C 22 98 9F D0
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 1, notStatic False, class hierarchy 07 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 02 25 88 4B
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 88 00 61 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 68 0E 60 0A 02 07 01 5E 85 8E 59 71 6C 22 98 9F D3
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 2, notStatic False, class hierarchy 07 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 03 25 89 4B
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 89 00 60 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 68 0E 60 0A 03 21 01 5E 85 8E 59 31 6C 22 98 9F B4
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 3, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 04 25 8A 4F
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 8A 00 63 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 68 0E 60 0A 04 21 01 5E 85 8E 59 31 6C 22 98 9F B3
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 4, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 05 25 8B 4F
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 8B 00 62 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 15 00 04 00 68 0F 60 0A 05 10 01 5E 25 85 8E 59 75 6C 22 98 9F E2
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 5, notStatic False, class hierarchy 10 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 06 25 8C 4B
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 8C 00 65 (node ACK)
Z-Wave Debug . . requestMultiEndPointDetails: requeuing 2 unsolicited packets
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 15 00 04 00 68 0F 60 0A 06 10 01 5E 25 85 8E 59 75 6C 22 98 9F E1
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 6, notStatic False, class hierarchy 10 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 68 03 60 09 07 25 8D 4B
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 05 00 13 8D 00 64 (node ACK)
Z-Wave Debug . . requestMultiEndPointDetails: requeuing 4 unsolicited packets
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 10 57 09 71 05 00 00 00 FF 06 17 00 20
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 15 00 04 00 68 0F 60 0A 07 21 01 5E 85 8E 59 31 71 6C 22 98 9F C1
Z-Wave Debug . . requestMultiEndPointDetails: node 104, endPoint 7, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 104, combined multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 001, classes [94, 133, 142, 89, 113, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 002, classes [94, 133, 142, 89, 113, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 003, classes [94, 133, 142, 89, 49, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 004, classes [94, 133, 142, 89, 49, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 005, classes [94, 37, 133, 142, 89, 117, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 006, classes [94, 37, 133, 142, 89, 117, 108, 34, 152, 159]
Z-Wave Debug . . getDynamicSubModelsFunc: endpoint 007, classes [94, 133, 142, 89, 49, 113, 108, 34, 152, 159]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 68 02 85 05 25 8E A4
Z-Wave Debug RCVD requestAssociationGroupCount: 01 05 00 13 8E 00 67 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 68 03 85 06 03 19
Z-Wave Debug . . requestAssociationGroupCount: node 104, group count: 3
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 68 03 85 02 01 25 8F A1
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 8F 00 66 (node ACK)
Z-Wave Debug . . requestAssociations: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 4E 09 71 05 00 00 00 FF 06 16 00 28
Z-Wave Debug . . requestAlarmSensorStatus: node 078, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave received "Sensor Garagem - Dry Contact" status update is on
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 68 03 85 02 02 25 90 BD
Z-Wave Debug RCVD requestAssociations: 18 (RETRANSMIT REQUEST)
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 68 03 85 02 02 25 90 BD (re-sent because retransmit request)
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 90 00 79 (node ACK)
Z-Wave Debug . . requestAssociations: requeuing 3 unsolicited packets
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000616, FF, new: 710000, 7100000616, FF (0.0010 secs)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 68 05 85 03 02 05 00 1C
Z-Wave Debug . . requestAssociations: node 104, group: 2, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 104, group: 2, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 68 03 85 02 03 25 91 BD
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 91 00 78 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 68 05 85 03 03 05 00 1D
Z-Wave Debug . . requestAssociations: node 104, group: 3, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 104, group: 3, associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Debug SENT addInterfaceMultiInstanceAssociation: 01 0D 00 13 68 06 8E 01 01 00 01 01 25 92 B6
Z-Wave Debug RCVD addInterfaceMultiInstanceAssociation: 01 05 00 13 92 00 7B (node ACK)
Z-Wave Debug . . addInterfaceMultiInstanceAssociation: requeuing 1 unsolicited packets
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Debug . . addInterfaceAssociation: node 104, group: 1, associations: [1]
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 4E 09 71 05 00 00 00 FF 06 17 00 29
Z-Wave received "Sensor Garagem - Dry Contact" status update is off
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000617, 0, new: 710000, 7100000617, 0 (0.0009 secs)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 14 25 93 5A
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 93 00 7A (node ACK)
Z-Wave Debug . . requestConfigVal: requeuing 4 unsolicited packets
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 68 0A 60 0D 07 01 31 05 01 22 01 77 83
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 7
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 68 06 31 05 01 22 01 77 FF
Z-Wave Debug . . requestVarSensorStatus: node 104, endpoint 7, type 1, raw value 2201...
Z-Wave Debug . . requestVarSensorStatus: 37.5 °C (float: 37.500000)
Z-Wave received "Sensor Novo Piscina - Temperature" sensor update to 37.5 °C
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 10 68 0A 60 0D 07 01 31 05 01 22 01 77 93
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 10 68 06 31 05 01 22 01 77 FF
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 14 01 00 FE
Z-Wave Debug . . requestConfigVal: node 104, parm index 20, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 0 "Normally Closed"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 20:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 28 25 94 61
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 94 00 7D (node ACK)
Z-Wave Debug . . requestConfigVal: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 28 01 02 C0
Z-Wave Debug . . requestConfigVal: node 104, parm index 40, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 40 "Input 1 scene sending" is 2 "Double Tap"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 40:2 20:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 15 25 95 5D
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 95 00 7C (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 15 01 00 FF
Z-Wave Debug . . requestConfigVal: node 104, parm index 21, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 0 "Normally Closed"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 40:2 20:0 21:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 29 25 96 62
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 96 00 7F (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 29 01 02 C1
Z-Wave Debug . . requestConfigVal: node 104, parm index 41, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 41 "Input 2 scene sending" is 2 "Double Tap"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 40:2 41:2 20:0 21:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 18 25 97 52
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 97 00 7E (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 18 01 00 F2
Z-Wave Debug . . requestConfigVal: node 104, parm index 24, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 24 "Swap inputs (IN1 and IN2)" is false
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 40:2 41:2 20:0 21:0 24:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 9A 25 98 DF
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 98 00 71 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 9A 01 00 70
Z-Wave Debug . . requestConfigVal: node 104, parm index 154, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 154 "Output 1 type" is 0 "Normally Open"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 24:0 20:0 21:0 40:2 41:2 154:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 9C 25 99 D8
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 99 00 70 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 9C 02 00 00 71
Z-Wave Debug . . requestConfigVal: node 104, parm index 156, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 156 "Output 1 delayed off" is 0 * 0.1 seconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 24:0 20:0 21:0 40:2 41:2 154:0 156:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 9B 25 9A DC
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 9A 00 73 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 9B 01 00 71
Z-Wave Debug . . requestConfigVal: node 104, parm index 155, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 155 "Output 2 type" is 0 "Normally Open"
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 24:0 20:0 21:0 40:2 41:2 154:0 155:0 156:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 9D 25 9B DB
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 9B 00 72 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 9D 02 00 00 70
Z-Wave Debug . . requestConfigVal: node 104, parm index 157, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 157 "Output 2 delayed off" is 0 * 0.1 seconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 24:0 20:0 21:0 40:2 41:2 154:0 155:0 156:0 157:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 19 25 9C 58
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 9C 00 75 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 19 01 00 F3
Z-Wave Debug . . requestConfigVal: node 104, parm index 25, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 25 "Swap outputs (OUT1 and OUT2)" is false
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 24:0 20:0 21:0 25:0 40:2 41:2 154:0 155:0 156:0 157:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 42 25 9D 02
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 9D 00 74 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 42 02 00 3C 93
Z-Wave Debug . . requestConfigVal: node 104, parm index 66, value 60 (size 2)
Z-Wave Syncing - retrieved parameter 66 "Internal temperature interval" is 60 seconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 66:60 40:2 41:2 20:0 21:0 24:0 25:0 154:0 155:0 156:0 157:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 41 25 9E 02
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 9E 00 77 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 41 02 00 05 A9
Z-Wave Debug . . requestConfigVal: node 104, parm index 65, value 5 (size 2)
Z-Wave Syncing - retrieved parameter 65 "Internal temperature sensitivity" is 5 * 0.1°C
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 68 05 70 04 41 01 01 25 9F 02
Z-Wave Debug RCVD setConfigVal: 01 05 00 13 9F 00 76 (node ACK)
Z-Wave Syncing - device "104 - Sensor Novo Piscina - Binary IN1" parameter 65 "Internal temperature sensitivity" changed to 1 * 0.1°C (was 5 * 0.1°C)
Z-Wave Debug . . pushNewValToNode: node 104, combined config vals: 65:1 66:60 40:2 41:2 20:0 21:0 24:0 25:0 154:0 155:0 156:0 157:0
Z-Wave Debug RCVD requestReply1: 01 09 00 04 00 68 03 22 02 00 B9 (hex)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 40 25 A0 3D
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A0 00 49 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 40 02 00 00 AD
Z-Wave Debug . . requestConfigVal: node 104, parm index 64, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 40:2 41:2 20:0 21:0 24:0 25:0 154:0 155:0 156:0 157:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 3F 25 A1 43
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A1 00 48 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 3F 01 05 D0
Z-Wave Debug . . requestConfigVal: node 104, parm index 63, value 5 (size 1)
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 5 * 0.1 V
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 40:2 41:2 20:0 21:0 24:0 25:0 154:0 155:0 156:0 157:0 63:5
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 96 25 A2 E9
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A2 00 4B (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 96 01 0A 76
Z-Wave Debug . . requestConfigVal: node 104, parm index 150, value 10 (size 1)
Z-Wave Syncing - retrieved parameter 150 "Analog IN1 debounce" is 10 milliseconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 40:2 41:2 20:0 21:0 150:10 24:0 25:0 154:0 155:0 156:0 157:0 63:5
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 97 25 A3 E9
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A3 00 4A (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 68 05 70 06 97 01 0A 77
Z-Wave Debug . . requestConfigVal: node 104, parm index 151, value 10 (size 1)
Z-Wave Syncing - retrieved parameter 151 "Analog IN2 debounce" is 10 milliseconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 40:2 41:2 20:0 21:0 150:10 151:10 24:0 25:0 154:0 155:0 156:0 157:0 63:5
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 44 25 A4 3D
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A4 00 4D (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 44 02 00 00 A9
Z-Wave Debug . . requestConfigVal: node 104, parm index 68, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 68 "External sensor interval" is 0 seconds
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 68:0 40:2 41:2 20:0 21:0 150:10 151:10 24:0 25:0 154:0 155:0 156:0 157:0 63:5
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 68 03 70 05 43 25 A5 3B
Z-Wave Debug RCVD requestConfigVal: 01 05 00 13 A5 00 4C (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 68 06 70 06 43 02 00 05 AB
Z-Wave Debug . . requestConfigVal: node 104, parm index 67, value 5 (size 2)
Z-Wave Syncing - retrieved parameter 67 "External sensor sensitivity" is 5 * 0.1
Z-Wave Debug . . requestConfigVal: node 104, combined config vals: 64:0 65:1 66:60 67:5 68:0 40:2 41:2 20:0 21:0 150:10 151:10 24:0 25:0 154:0 155:0 156:0 157:0 63:5
Z-Wave Syncing - complete
Z-Wave Debug SENT requestAlarmSensorStatus: 01 0D 00 13 68 06 60 0D 01 01 71 04 25 A6 14
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 05 00 13 A6 00 4F (node ACK)
Z-Wave Debug terminatingSyncUI
Z-Wave sent "Sensor Novo Piscina - Binary IN1" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 68 07 60 0D 01 01 22 02 00 D4
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 1
Z-Wave Debug RCVD requestReply2: 01 09 00 04 00 68 03 22 02 00 FF (hex)
Z-Wave Debug SENT requestVarSensorStatus: 01 0F 00 13 68 08 60 0D 01 03 31 04 02 00 25 A7 59
Z-Wave Debug RCVD requestVarSensorStatus: 01 05 00 13 A7 00 4E (node ACK)
Z-Wave sent "Sensor Novo Piscina - Analog IN1" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 68 0A 60 0D 03 01 31 05 0F 42 04 02 99
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 3
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 68 06 31 05 0F 42 04 02 FF
Z-Wave Debug . . requestVarSensorStatus: node 104, endpoint 3, type 15, raw value 4204...
Z-Wave Debug . . requestVarSensorStatus: 10.26 V (float: 10.260000)
Z-Wave received "Sensor Novo Piscina - Analog IN1" sensor update to 10.26 V
Z-Wave Debug SENT requestAlarmSensorStatus: 01 0D 00 13 68 06 60 0D 01 02 71 04 25 A8 19
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 05 00 13 A8 00 41 (node ACK)
Z-Wave sent "Sensor Novo Piscina - Binary IN2" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 68 07 60 0D 02 01 22 02 00 D7
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 2
Z-Wave Debug SENT requestVarSensorStatus: 01 0F 00 13 68 08 60 0D 01 04 31 04 02 00 25 A9 50
Z-Wave Debug RCVD requestVarSensorStatus: 01 05 00 13 A9 00 40 (node ACK)
Z-Wave sent "Sensor Novo Piscina - Analog IN2" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 68 0A 60 0D 04 01 31 05 0F 42 04 02 9E
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 4
Z-Wave Debug . . requestVarSensorStatus: node 104, endpoint 4, type 15, raw value 4204...
Z-Wave received "Sensor Novo Piscina - Analog IN2" sensor update to 10.26 V
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 68 06 60 0D 01 05 25 02 25 AA 4E
Z-Wave Debug RCVD requestRelayStatus: 01 05 00 13 AA 00 43 (node ACK)
Z-Wave sent "Sensor Novo Piscina - Relay 1" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 68 07 60 0D 05 01 25 03 00 D6
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 5
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 68 03 25 03 00 FF
Z-Wave Debug . . requestRelayStatus: node 104, endpoint 5, value 0
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 68 06 60 0D 01 06 25 02 25 AB 4C
Z-Wave Debug RCVD requestRelayStatus: 01 05 00 13 AB 00 42 (node ACK)
Z-Wave sent "Sensor Novo Piscina - Relay 2" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 68 07 60 0D 06 01 25 03 00 D5
Z-Wave Debug . . multiEndPointPacket: node 104, endPoint 6
Z-Wave Debug . . requestRelayStatus: node 104, endpoint 6, value 0
Z-Wave Debug SENT requestVarSensorStatus: 01 0E 00 13 68 07 60 0D 01 07 31 04 01 25 AC 5B
Z-Wave Debug RCVD requestVarSensorStatus: 01 05 00 13 AC 00 45 (node ACK)
Z-Wave sent "Sensor Novo Piscina - Temperature" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 68 07 60 0D 05 01 25 03 FF 29
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 68 03 25 03 FF FF
Z-Wave Debug . . requestRelayStatus: node 104, endpoint 5, value 255
Z-Wave received "Sensor Novo Piscina - Relay 1" status update is on
Z-Wave Debug RCVD multiEndPointPacket: 01 13 00 04 00 68 0D 60 0D 01 01 71 05 00 00 00 FF 07 00 00 6C
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 68 09 71 05 00 00 00 FF 07 00 00 FF
Z-Wave Debug . . requestAlarmSensorStatus: node 104, endpoint 1, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Z-Wave received "Sensor Novo Piscina - Binary IN1" status update is off
Z-Wave received "Sensor Novo Piscina - Relay 1" status update is off
Z-Wave Debug RCVD multiEndPointPacket: 01 13 00 04 00 68 0D 60 0D 01 01 71 05 00 00 00 FF 07 02 00 6E
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 68 09 71 05 00 00 00 FF 07 02 00 FF
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 2, classSubKeyExt 7100000702
Z-Wave received "Sensor Novo Piscina - Binary IN1" status update is on
14 Feb 2020 12:04:42
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 68 0A 60 0D 07 01 31 05 01 22 01 78 8C
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 68 06 31 05 01 22 01 78 FF
Z-Wave Debug . . requestVarSensorStatus: 37.6 °C (float: 37.600000)
Z-Wave received "Sensor Novo Piscina - Temperature" sensor update to 37.6 °C
Z-Wave Debug filtering duplicate command -- old: 710000, 7100000700, 0, new: 710000, 7100000700, 0 (0.3556 secs)
Z-Wave connection reset requested
Z-Wave connected to Z-Wave 4.05 static controller interface on
socket://192.168.1.170:2001 (firmware 4.32)
