Thanks for the info.
This Implant is a month old but has the same model ID as the version from October 2019.
See info below.
With a Schedule at every 1 second with a Full Status Request update it's working but that's not the way it has to be..
What's the different with Nick's configuration?
Yes, I am using servodan 43-198 analogue lux sensor and wind speed sensor. At first the smart implant didn't report updates to indigo but after remove/resycn, see steps above, it worked.
Model: Smart Implant (FGBS222)
Model ID: 05021000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.02
Application Version: 5.01
Model Definition Version: 2
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Multi-Endpoint Types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Multi-Endpoint Classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Features: routing, beaming, security
Neighbors: 2, 3, 4, 5, 6, 7, 8, 9, 10, 12, 13, 14, 15, 20, 21, 22, 23, 24, 25, 26, 27, 29, 30, 31, 34, 35, 86, 87, 91, 95, 96, 100, 106
Associations: 1:[1] 2:[] 3:[]
Config Values: 64:1 65:5 66:0 67:1 68:1 40:0 41:2 20:4 21:2 150:1 151:10 24:0 25:0 154:0 155:0 156:0 157:0 63:1
