- Posted on
Tue Oct 15, 2019 2:34 pm
McJohn
offline
Thanks for the great hint. Default was this temp interval setting 0.
Changed it to 60 seconds:
Z-Wave device "091 - Smart Implant - Binary IN1" parameter 66 "Internal temperature interval" changed to 60 seconds
Wait 2 minutes. Nothing happened. Did a re-sync:
Z-Wave Syncing - started for "Smart Implant - Binary IN1"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 7, 12, 13, 14, 15, 16, 19, 20, 24, 25, 30, 34, 86, 95
Z-Wave Syncing - assigning return route to "091 - Smart Implant - Binary IN1"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smart Implant (FGBS222) - 05021000
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave received "Air Quality Monitor" sensor update to 3.0 micro-g/m3
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 31v11 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 1 "Normally Open"
Z-Wave Syncing - retrieved parameter 40 "Input 1 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 0 "Normally Closed"
Z-Wave Syncing - retrieved parameter 41 "Input 2 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 24 "Swap inputs (IN1 and IN2)" is false
Z-Wave Syncing - retrieved parameter 154 "Output 1 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 156 "Output 1 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 155 "Output 2 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 157 "Output 2 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 25 "Swap outputs (OUT1 and OUT2)" is false
Z-Wave Syncing - retrieved parameter 66 "Internal temperature interval" is 60 seconds
Z-Wave Syncing - retrieved parameter 65 "Internal temperature sensitivity" is 5 * 0.1°C
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 0 * 0.1 V
Z-Wave Syncing - retrieved parameter 150 "Analog IN1 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 151 "Analog IN2 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 68 "External sensor interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 67 "External sensor sensitivity" is 5 * 0.1
Z-Wave Syncing - complete
Z-Wave sent "Smart Implant - Binary IN1" status request
Z-Wave sent "Smart Implant Analog IN1" status request
Z-Wave received "Smart Implant Analog IN1" sensor update to 10.16 V
Z-Wave sent "Smart Implant - Binary IN2" status request
Z-Wave sent "Smart Implant - Analog IN2" status request
Z-Wave received "Smart Implant - Analog IN2" sensor update to 10.14 V
Z-Wave sent "Smart Implant - Relay 1" status request
Z-Wave sent "Smart Implant - Relay 2" status request
Z-Wave sent "Smart Implant - Temperature" status request
Nothing happened.
Changed the "Internal temp sensitivity" to 1:
Z-Wave device "091 - Smart Implant - Binary IN1" parameter 65 "Internal temperature sensitivity" changed to 1 * 0.1°C
Waited 30 minutes.
Nothing happened (it's now 13 degrees outside).
I think like the rest of the Implant parts; they are not communicating back to Indigo at the moment.
- Screen Shot 2019-10-15 at 22.23.46.png (130.35 KiB) Viewed 2670 times
