Asconasny wrote:...sadly the network socket or rfc2217 is not implemented in the rfxcom plugin. only usb.
So no luck getting that to work.
Au contraire... You can map the socket connection to a device in/dev. Check out socat.
berkinet wrote:I found the source of the problem. In IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py, at line 501 writeTimeout is set to 2.0. Setting it to None resolves the issue with rfc2217 connections. However, I am not suggesting this change is the fix, it may well cause other issues, I just wanted to report that I had found the root of the problem
matt (support) wrote:berkinet wrote:I found the source of the problem. In IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py, at line 501 writeTimeout is set to 2.0. Setting it to None resolves the issue with rfc2217 connections. However, I am not suggesting this change is the fix, it may well cause other issues, I just wanted to report that I had found the root of the problem
To summarize, the exception only occurs with rfc2217 connections because pyserial currently never handles non-None writeTimeout values for that connection type, correct? If so, then I will add a condition to that code in serialinterface so that None is passed (but only for rfc2217 connections). Does that sound reasonable, and will they be helpful for you?
berkinet wrote:Asconasny wrote:...sadly the network socket or rfc2217 is not implemented in the rfxcom plugin. only usb.
Asconasny wrote:thanks for confirming this.
Been struggelig trying to get this working, even tried to turn off the System Integrity Protection. (SIP) no luck
A work-around would be much appreciated.
Asconasny wrote:already done.
First thing i tried when i had trouble with this.
and like you said, didnt help.
