Steinel RS LED D2 Z-Wave Panel (+ microwave sensor (!) )
Fri Feb 01, 2019 12:08 pm
shapa offline
Really unique and nice device.
https://www.steinel.de/en/smart-home/sm ... -wave.html
LED panel with built-in microwave motion sensor (work so much better than traditional IR - can actually work via walls / doors / etc) and Lux meter
Easy to include, syncs well. Works now only as an "on / off" panel, motion and lux sensors identified but not working.
Some cool features like ambient light level training, night mode, etc.
Z-Wave Syncing - started for "124 - Relay Switch"
Z-Wave Syncing - retrieved module neighbors list: 4, 5, 18, 21, 22, 29, 31, 36, 37, 39, 40, 44, 46, 49, 54, 56, 57, 59, 60, 61, 62, 64, 65, 66, 67, 71, 74, 76, 82, 88, 90, 93, 96, 98, 100, 104, 108, 111, 115, 122, 126, 127, 130, 137, 141, 144, 148, 150, 151, 166, 168, 180, 181, 182, 189, 196, 201, 204, 217, 218, 219, 220, 223, 227, 228, 232
Z-Wave Syncing - assigning return route to "124 - Relay Switch"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0271, Relay Power Switch - 00011A74
Z-Wave Syncing - retrieved protocol version 4.38, app version 1.00
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave received "Child Room Danfoss Radiator Thermostat" heat setpoint is 22.00 °C
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 22v1 71v1 25v1 86v1 27v1 2Bv1 2Cv1 8Ev1 70v1 31v4 72v1 73v1 77v1 59v1 7Av1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(07 : 01), 3:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 25 2B 2C 27 22], 2:[5E 85 8E 59 71], 3:[5E 31 85 8E 59]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: [1]
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - complete
Z-Wave sent "124 - Relay Switch" status request
Z-Wave sent "124 - Notification Sensor" status request
Z-Wave sent "124 - Multilevel Sensor" status request
Z-wave manuals
http://manuals-backend.z-wave.info/make ... 0-17035489
https://www.steinel.de/out/steinel_rela ... 043511.pdf
Please support it, for me, it's perfect for bathrooms / entrance halls / etc - minimal motion is detected, much more sensible than all other sensors I used (but no false detections).
Fri Feb 01, 2019 12:21 pm
shapa offline
Re: Steinel RS LED D2 Z-Wave Panel (+ microwave sensor (!) )
I'm able to get raw motion on / off events
Motion Detected:
Z-Wave Watcher Debug Raw command received (Node 124): 01 0F 00 04 00 7C 09 71 05 00 00 00 FF 07 08 00 05
Motion Stopped:
Z-Wave Watcher Debug Raw command received (Node 124): 01 10 00 04 00 7C 0A 71 05 00 00 00 FF 07 00 01 08 18
Mon Feb 04, 2019 4:14 pm
I've added this to the request list for a complete definition.
In the mean time have you tried creating Triggers on the raw Z-Wave command to be able to detect motion?
Mon Feb 04, 2019 5:57 pm
shapa offline
Matt,
Yes, triggers + raw works fine.
Wed May 01, 2019 11:58 am
shapa offline
Indigo 7.3 - device recognised, but still not working "officially" - motion sensor is always off, light sensor - no readings.
Z-Wave Syncing - retrieved manufacture and model names: Steinel - 0271, Relay Power Switch - 00011A74
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 71v1 8Ev1 59v1 5Av1 5Ev1 60v4 22v1 25v1 27v1 2Bv1 2Cv1 70v1 31v4 72v1 73v1 77v1 7Av1
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - created device "027 - Relay Switch"
Z-Wave Syncing - created device "027 - Notification Sensor"
Z-Wave Syncing - created device "027 - Multilevel Sensor"
Wed May 08, 2019 9:35 am
That is correct. We were able to get the Steinel LED Floodlight (XLED home 2) added but the Steinel RS LED D2 didn't make it in.
Mon May 13, 2019 7:13 am
shapa offline
Any plans to support? :)
A light level sensor would be really nice to read directly.
Actually purchased one more device - outdoor LED light with microwave sensor, will submit specs ASAP
Tue May 14, 2019 8:46 am
It is definitely on the request list.
Sat Jun 01, 2019 3:27 pm
shapa offline
Submitted a second device - outdoor Microwave sensor + LED light.
Very nice one. Extremely reliable and precise detection can be adjusted to centimetres.
https://www.steinel.de/en/domestic-user ... ilver.html
Z-Wave Syncing - started for "Driveway LED Sensor Light"
Z-Wave Syncing - retrieved module neighbors list: 3, 5, 10, 12, 13, 19, 20, 21, 22, 23, 24, 25, 30, 38, 39, 40, 44, 46, 49, 54, 56, 57, 61, 62, 65, 66, 67, 71, 74, 76, 82, 87, 88, 90, 93, 98, 100, 104, 108, 115, 122, 124, 126, 141, 144, 148, 150, 166, 181, 182, 189, 204, 218, 219, 222, 227, 232
Z-Wave Syncing - assigning return route to "051 - Driveway LED Sensor Light"
Z-Wave Syncing - retrieved manufacture and model names: Steinel - 0271, Dimmable Power Switch - 00011A75
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 22v1 71v1 85v1 26v4 27v1 2Bv1 2Cv1 8Ev1 70v1 31v4 72v1 73v1 5Ev1 77v1 59v1 7Av1 5Av1 86v1
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 01), 2:(07 : 01), 3:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 26 2B 2C 27 22], 2:[5E 85 8E 59 71], 3:[5E 31 85 8E 59]
Z-Wave received "Stairs 1st Floor PM2.5 Sensor Particulate Matter" sensor update to 26.0 micro-g/m3
Sun Jun 02, 2019 9:57 am
krissh offline
How does the ambient light level training and night mode work? I couldn’t figure it out from the documentation. As I understand, it is non dimmable?
Tue Jun 04, 2019 1:59 pm
shapa offline
Outdoor light is dimmable.
Home lights are not.
Not using "ambient light level training" - it's designed for a group of devices (to have identical lux readings)
Users browsing this forum: dduff617 and 14 guests
