Great if this device can be updated in 7.3.
Indigo Z-Wave Version: 2.0.119
Node ID: 64
Model: Relay Power Switch
Model ID: 06021003
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 4.24
Application Version: 3.02
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 85v1 86v1 71v1 8Ev1 56v1 98v1 59v1 5Av1 5Ev1 20v1 22v1 25v1 27v1 72v1 70v1 31v5 32v2 73v1 7Av1
Features: routing, beaming, security, energyMeter
Neighbors: 2, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 23, 24, 25, 26, 27, 38, 39
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
