Everspring SP816 Outdoor PIR
Fri Jan 18, 2019 7:12 am
racarter offline
Please could you add this device to the next release? Currently it syncs OK but just shows as a Notification Sensor.
Z-Wave Indigo Device "Porch PIR" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.116
Node ID: 76
Model: Notification Sensor
Model ID: 00010005
Manufacturer: Everspring
Manufacturer ID: 0060
Protocol Version: 4.61
Application Version: 1.02
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 6Cv1 71v1 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 2, 6, 7, 8, 10, 11, 12, 15, 16, 17, 18, 20, 24, 25, 28, 33, 34, 35, 41, 42, 52, 53
Associations: 1:[1] 2:[]
Config Values: - none -
Fri Jan 18, 2019 4:17 pm
Re: Everspring SP816 Outdoor PIR
Does the sensor state update to ON/OFF inside Indigo when motion is detected?
If not, can you enable Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item) and trip the motion detector a couple of times? Wait a few minutes after tripping it so the log can capture the follow-up "off" command. Copy/paste the Event Log results into a reply for me and I'll get it on our request list.
Fri Jan 18, 2019 4:34 pm
racarter offline
Hi Matt
No, the sensor state doesn't update when tripped. Here's the log data you asked for:
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 43 09 71 05 00 00 00 FF 07 08 00 3A
Z-Wave Debug . . requestAlarmSensorStatus: node 067, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 4C 09 71 05 00 00 00 FF 07 08 00 35
Z-Wave Debug . . requestAlarmSensorStatus: node 076, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 4C 0A 71 05 00 00 00 FF 07 00 01 08 28
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Fri Jan 18, 2019 4:42 pm
Thanks, that is what we need. In the mean time you can follow the steps here to capture the ON and OFF commands.
Sun May 12, 2019 4:14 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Everspring Motion Sensor (SP816).
Mon May 13, 2019 12:23 am
racarter offline
Cool! Thanks Matt. :)
