- Code: Select all
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 501, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 675, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2235, in processQueueInPacket
File "zwaveinterface.py", line 2209, in _processFuncCall
File "zwaveinterface.py", line 2270, in _processCommandReply
File "zwaveinterface.py", line 2254, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2207, in _processFuncCall
File "zwavecmd_multiinstanceinfo.py", line 271, in _processMultiEndPointPacket
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serialinterface.py", line 113, in __init__
self.str = ''.join([chr(byte) for byte in self.bytelist])
ValueError: chr() arg not in range(256)
Z-Wave Error exc type is <type 'exceptions.ValueError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Z-Wave connected to Z-Wave 4.61 static controller interface on /dev/cu.usbmodemFA131 (firmware 5.27)
Z-Wave found module included in controller with no matching device (missing or disabled): 056 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 082 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 087 - Basic Wall Controller
Z-Wave received "vaskerom_bevegelse" status update is off
