New to Zwave, but after a bit of trial and error I think I understand what I need to do. Need some help troubleshooting.
1. Aeotec Gen 5 - Z-Stick
2. Schlage 469
3. Indigo 7.2
Here is the output of me including the lock with encryption:
Z-Wave started controller inclusion mode with encryption
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 02 01 00 00 B1
Z-Wave Debug RCVD inclusionMode node found: 01 07 00 4A 02 02 00 00 B2
Z-Wave Debug RCVD inclusionMode adding slave node: 01 0F 00 4A 02 03 05 08 04 40 03 22 72 7A 98 86 C5
Z-Wave Debug RCVD inclusionMode node respondCmds: 22 72 7A 98 86
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 02 05 05 00 B0
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 02 06 05 00 B3
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 DC 00 04 40 03 7E
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Keypad Door Lock
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 62
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 62 63 86 22 72 98 7A
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming, security, frequentWaking
Z-Wave controller included module: 005 - Keypad Door Lock
Z-Wave querying module for encryption support
Z-Wave Debug SENT requestSecuritySchemes: 01 0A 00 13 05 03 98 04 00 25 16 4F
Z-Wave Debug RCVD requestSecuritySchemes: 01 09 00 04 00 05 03 98 05 00 69
Z-Wave Debug . . requestSecuritySchemes: node 005, schemeIndex 0
Z-Wave starting encryption key exchange with module
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 17 08
Z-Wave Debug RCVD nonceReport: node 005, nonce EC B8 BE 58 F3 4E A0 BF
Z-Wave Debug SENT setNetworkSecurityKey: ** ** ** ** (encrypted)
Z-Wave Debug RCVD nonceFetch: node 005
Z-Wave Debug SENT nonceReport: 01 11 00 13 05 0A 98 80 69 26 08 16 E5 90 1D 19 25 19 F6
Z-Wave Debug RCVD encryptedPacket: 00 98 07 (decrypted)
Z-Wave Debug RCVD keyVerify: 01 08 00 04 00 05 02 98 07 FF
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Here is the sync of the device
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "005 - Keypad Door Lock"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 05 01 01 7C
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E
Z-Wave Debug . . getNodeNeighbors: nodeId 005, neighbors: - none -
Z-Wave Syncing - assigning return route to "005 - Keypad Door Lock"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 05 01 B8
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 005, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 05 24 1A A2
Z-Wave Debug RCVD nodeInfoFrame: 01 0E 00 49 84 05 08 04 40 03 22 72 7A 98 86 42
Z-Wave Debug . . nodeInfoFrame: node 005, combined class list: 20v1 62v1 63v1 86v1 22v1 72v1 98v1 7Av1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 05 02 98 40 25 1B 04
Z-Wave Debug RCVD nonceReport: node 005, nonce C6 F1 EC 60 42 A4 12 DE
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug SENT nonceReport: 01 11 00 13 05 0A 98 80 A3 47 10 B5 5B 7E C6 37 25 1D 47
Z-Wave Error rcvd incomplete interface packet (skipping): 01 26 00 04 00 05 20 98
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 BB 00 C2 06 55 D2 FD 0A 48 30 40 00 64 3F 34 0D 7B 35 14 60 7C A3 A0 80 C0 B6 42 A5 39 2C F5 01 26 00 04 00 05 20 98
Z-Wave Debug timeout waiting for module command after sending nonce report (not critical)
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 05 02 72 04 25 1E AF
Z-Wave Error rcvd unexpected bytes (sent ACK): 81 BB 00 C2 06 55 D2 FD 0A 48 30 40 00 64 3F 34 0D 7B 35 14 60 7C A3 A0 80 C0 B6 42 A5 39 2C F5 06 01 04 01 13 01 E8
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 05 02 72 04 25 1E AF (re-sent because no response)
Z-Wave Debug . . requestManufactureInfo: requeuing 2 unsolicited packets
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 05 08 72 05 00 3B 63 41 50 44 82
Z-Wave Debug . . requestManufactureInfo: node 005, manufacturerId 003B, productId 63415044
Z-Wave Debug . . requestManufactureInfo: Schlage, Door Lock (BE369/468/469)
Z-Wave Syncing - retrieved manufacture and model names: Schlage - 003B, Door Lock (BE369/468/469) - 63415044
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 05 02 86 11 25 1F 4F
Z-Wave Debug RCVD packet: 01 07 00 13 1F 00 00 68 9C (hex)
Z-Wave Debug RCVD requestVersInfoGen: 01 0E 00 04 00 05 08 86 12 06 03 2A 80 16 44 91
Z-Wave Debug . . requestVersInfoGen: node 005, protoVers 3.42, appVers 128.22
Z-Wave Syncing - retrieved protocol version 3.42, app version 128.22
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 05 07 86 12 06 03 2A 80 16 D9
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 86v1 22v1 72v1 98v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Syncing - created device "005 - Door Lock (BE369/468/469)"
Z-Wave Syncing - complete
Z-Wave Debug SENT requestLockStatus1: 01 09 00 13 05 02 62 02 25 20 87
Z-Wave sent "005 - Door Lock (BE369/468/469)" status request
Z-Wave Debug terminatingSyncUI
Here is the debug of the device:
Indigo Z-Wave Version: 2.0.119
Node ID: 5
Model: Door Lock (BE369/468/469)
Model ID: 63415044
Manufacturer: Schlage
Manufacturer ID: 003B
Protocol Version: 3.42
Application Version: 128.22
Model Definition Version: 0
Library Type: 6
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 20v1 62v1 63v1 86v1 22v1 72v1 98v1 7Av1
Encryption Status: Enabled for Commands - none -
Features: routing, beaming, security, frequentWaking
Neighbors: - none -
Associations: - none -
Config Values: - none -
Attached is the status of the device. I believe looking at other threads it should look a lot different especially the encryption part
The lock doesn't not respond to anything I do in indigo. Thoughts?
