Trane 524 setpoint not loading
Tue Nov 27, 2018 6:30 pm
Ericbo offline
Happy user of Indigo and of the Trade Thermostat 524. Having a problem with the set command. Asking the thermostat to change its set point and it is not doing it. Any troubleshooting you would recommend ?
Thank you!
Nov 27, 2018 at 4:24:13 PM
Schedule Thermostat morning start
Z-Wave sent "002 - Thermostat (TZEMT524AA)" change heat setpoint to 66.2°
Z-Wave sent "002 - Thermostat (TZEMT524AA)" mode change to auto
Z-Wave sent "002 - Thermostat (TZEMT524AA)" change cool setpoint to 80.6°
Z-Wave received "002 - Thermostat (TZEMT524AA)" cool setpoint is 37.0 °C
Z-Wave received "002 - Thermostat (TZEMT524AA)" mode is auto
Nov 27, 2018 at 4:25:08 PM
Z-Wave sent "002 - Thermostat (TZEMT524AA)" mode status request
Z-Wave sent "002 - Thermostat (TZEMT524AA)" fan mode status request
Z-Wave received "002 - Thermostat (TZEMT524AA)" fan mode is auto
Z-Wave sent "002 - Thermostat (TZEMT524AA)" state status request
Z-Wave received "002 - Thermostat (TZEMT524AA)" is idle
Z-Wave sent "002 - Thermostat (TZEMT524AA)" fan state status request
Z-Wave received "002 - Thermostat (TZEMT524AA)" fan is off
Z-Wave sent "002 - Thermostat (TZEMT524AA)" temperature status request
Z-Wave received "002 - Thermostat (TZEMT524AA)" temperature update to 20.6 °C
Z-Wave sent "002 - Thermostat (TZEMT524AA)" heat setpoint status request
Z-Wave received "002 - Thermostat (TZEMT524AA)" heat setpoint is 21.0 °C
Z-Wave sent "002 - Thermostat (TZEMT524AA)" cool setpoint status request
Tue Nov 27, 2018 9:32 pm
Re: Trane 524 setpoint not loading
My guess is that it the thermostat is wanting (or at least currently using) Celsius but you are trying to set Fahrenheit, so the values are out-of-range of what the thermostat will allow.
Does it work if you set it to 25 or 26?
Wed Nov 28, 2018 11:15 am
Ericbo offline
Thanks Matt, so being patient, the Thermostat loaded the F degrees. Not sure why it did not load the first time. Since then, have switched back to C and also loading.
Happy ending, not sure why it did not load the fist time. Now working on moving the setpoints to variables as I want to use different temperature sensors I have set in the house.
Great Indigo as usual :) Eric
By the way, there are no Trane Thermostat thread, would it be possible to create one so all Trane thermostat users can share their use of Indigo/Trane Thermostat ?
Mon Jan 20, 2020 6:49 pm
Ericbo offline
Enjoy my Trane 524 but just lost communication with it (tried a reset by opening/shutting power to the thermostat but still not communicating)
Anybody with that experience ? Thank you
Mon Jan 20, 2020 7:48 pm
Have you tried excluding it and then re-including it (and after successful include, re-sync)?
Fri Jan 24, 2020 10:19 am
Ericbo offline
Yes Matt, thanks for pointing it out. Now the exclusion failed. I tracked that down to the last electrical change I did (changing a 2 gang to an 8 gang). Having moved the power of a lot of electronic systems, I had degraded the signal/noise ratio and lost the Thermostat communication. I have moved the MiniMac/ZWave closer to the Thermostat and all back to normal. I have to find the source of the noise to move back the Mini Mac where it belongs.
Thanks again!
Sat Feb 01, 2020 10:32 am
Ericbo offline
Last update: went back to my 8 gang and changed the way my noise filter is positioned versus the about 20 electronic appliances ... and solved :)
Ready to automate the X10 outlet to save energy at night !!
