Is the Zooz ZST10 USB Z-WAVE PLUS S2 STICK compatible?
Sun Nov 11, 2018 1:15 pm
vvrangler offline
Looking at this slightly cheaper Zwave usb stick, is it currently compatible with Indigo?
Thank you!
Sun Nov 11, 2018 3:50 pm
Re: Is the Zooz ZST10 USB Z-WAVE PLUS S2 STICK compatible?
Don't know that anyone has tried one - we haven't. Given the claim (on Amazon) that it doesn't require a driver it most likely uses the built-in modem driver (as does the Z-Stick Gen5 and the HomeSeer SmartStick+). If I had to guess, I'd say that it will probably work. Most of those interfaces use the standard Z-Wave Serial API which is what Indigo uses to talk to the interface. But we won't know for sure until someone tries one.
Sun Nov 11, 2018 7:06 pm
vvrangler offline
Thanks Jay!
Sat Jan 25, 2020 7:03 pm
tornado offline
Has anyone confirmed if this works?
Thanks.
Sun Jan 26, 2020 2:00 pm
Not that we are aware of. The next version of Indigo (7.4.1; not yet available) includes support for the Z-WaveMe USB Stick (ZME UZB1). The changes we made for supporting the UZB1 increase the likelihood that the ZST10 will work out-of-the-box with Indigo, but we haven't yet tried it. If it doesn't work then we'll order one and troubleshoot into it.
Sun Apr 18, 2021 11:22 am
Brendan offline
I just got the new ZST10-700. Alas, it doesn't even show up as selectable in the Z-Wave > Configure dialog. So I guess I can report that at least the new model does not work.
I can see it in System Report as "CP2102N USB to UART Bridge Controller". And Home Assistant can connect to it just fine. But alas, no luck in Indigo. :(
Sun Apr 18, 2021 4:03 pm
You have to install the SI Labs driver for it to show up in the serial port popup. I believe you can download it here.
Sun Apr 18, 2021 10:39 pm
Brendan offline
Ha. And here I believed the Zooz user manual when it said, "No drivers needed: works out of the box on Windows, Linux, and MAC OS".
Thanks, Matt. I'll give that driver a try.
Brendan
