First, I am seeing a "Model ID" I have not encountered here and can't find online. Here is my status report:
Indigo Z-Wave Version: 2.0.119
Node ID: 10
Model: Relay Power Switch
Model ID: 02023002
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 3.52
Application Version: 2.02
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v2 25v1 86v1 27v1 8Ev1 70v1 72v1 73v1 7Av1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01)
Multi-Endpoint Classes: 1:[25], 2:[25]
Features: routing, beaming
Neighbors: 9, 11, 12, 13, 14, 15, 16, 17
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Note that the model 02023002 is not one I can find anywhere. And, note that "Config Values" indicates "-none-". Any attempt to change any configuration parameter, or query them, fails.
Any advice on where to start?
