My iMac went on the fritz so I pressed into service an old iMac I had for my Indigo server. I copied over the files from a TimeMachine backup and mover over the Z-Wave Controller (version 2 I believe) to the old iMac. All went well to a point. All my devices seem to show up, my triggers are all there but the Z-Wave controller is not being seen. Tried restart, different ports and a USB Hub ( which I was using on the iMac that is now dead) I looked at the log and it showed the "serial port open error:[Errno 16] could not open port. And make sure FTDI driver is installed. Kind of stuck now, any help would be great, thanks in advance.
Ted
Update- I had to install the Silicon Labs VCP Driver Kit ( as per the Get Started Guide, when all is lost RTFM.)
