Everspring SM810
Wed Oct 24, 2018 8:14 am
aderrington offline
Everspring SM810
I've got a new Zwave door/window sensor - Everspring SM810-1. I've added it to Indigo however it only shows up as a notification sensor. I've submitted it to Indigo however has anyone else come across this sensor and figured out who to use it with Indigo?
Here's the devices info from the log:
Z-Wave Indigo Device "095 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 95
Model: Notification Sensor
Model ID: 00020003
Manufacturer: Everspring
Manufacturer ID: 0060
Protocol Version: 4.61
Application Version: 1.01
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 6Cv1 71v1 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 2, 6, 17, 21, 22, 29, 40, 46, 47, 53, 54, 59, 60, 73, 75, 82, 87
Associations: 1:[1] 2:[]
Config Values: - none -
Any help would be greatly appreciated.
Andrew
Mon Oct 29, 2018 12:29 pm
Re: Everspring SM810
What does it Report/not report when you open/close the door that you’re expecting?
You might try excluding it then re-including with encryption enabled.
Tue Nov 06, 2018 4:15 pm
aderrington offline
Yeah, i've tried with encryption both enabled and disabled, neither one helps unfortunately.
Thanks for the suggestion.
Wed Nov 07, 2018 9:58 am
Turn on Indigo's Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure... menu item, then open/close the door several times. Copy/paste the Event Log window results and we can help you create a Trigger to catch those commands.
Sun May 12, 2019 4:34 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Everspring Door/Window Sensor (SM810).
