Aeon Labs Home Energy Meter ( ZW095 ) not reporting
Mon Oct 22, 2018 12:48 am
Mathiasw offline
I've installed one of these, the single clamp model (for 240v single phase). It doesn't seem to be reporting at all, no matter what I set the reporting interval to (it's currently at 30 seconds). It does correctly update the values if I manually update it using the update button. Any idea why? I'm running Indigo 7.2.
I attach the the sync log and the device details.
Z-Wave Syncing - started for "036 - Simple Meter"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 7, 10, 11, 12, 13, 14, 17, 19, 20, 21, 22, 23, 24, 25, 27, 29, 30, 31, 33, 34
Z-Wave Syncing - assigning return route to "036 - Simple Meter"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Home Energy Monitor (ZW095) - 0002005F
Z-Wave Syncing - retrieved protocol version 4.54, app version 1.35
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Meter : Simple Meter (04 : 31 : 01, base 32)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 72v1 8Ev1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(31 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 32 59]
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 3 "Enable energy change reports" is false
Z-Wave Syncing - device "036 - Simple Meter" parameter 3 "Enable energy change reports" changed to false
Z-Wave Syncing - retrieved parameter 4 "Report threshold watts for total" is 50 watts
Z-Wave Syncing - retrieved parameter 5 "Report threshold watts for clamp 1" is 50 watts
Z-Wave Syncing - retrieved parameter 6 "Report threshold watts for clamp 2" is 50 watts
Z-Wave received "034 - Motion Sensor" status update is off
Z-Wave received "004 - No Idea Where - Motion" status update is off
Z-Wave Syncing - failed to retrieve parameter 7 "Report threshold watts for clamp 3" (skipping)
Z-Wave Syncing - retrieved parameter 8 "Report threshold percentage for total" is 10 %
Z-Wave Syncing - retrieved parameter 9 "Report threshold percentage for clamp 1" is 10 %
Z-Wave Syncing - retrieved parameter 10 "Report threshold percentage for clamp 2" is 10 %
Z-Wave Syncing - failed to retrieve parameter 11 "Report threshold percentage for clamp 3" (skipping)
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 5 seconds
Z-Wave Syncing - device "036 - Simple Meter" parameter 111 "Reporting interval" changed to 600 seconds (was 5 seconds)
Z-Wave received "010 - Luminance - Dining" sensor update to 7 lux
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 120 seconds
Z-Wave received "010 - Humidity - Dining" sensor update to 20%
Z-Wave received "010 - Temperature - Dining" sensor update to 21.7 °C
Z-Wave Syncing - device "036 - Simple Meter" parameter 112 "Reporting interval2" changed to 600 seconds (was 120 seconds)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 120 seconds
Z-Wave Syncing - device "036 - Simple Meter" parameter 113 "Reporting interval3" changed to 600 seconds (was 120 seconds)
Z-Wave received "012 - Luminance - Kitchen" sensor update to 0 lux
Z-Wave received "012 - Humidity - Kitchen" sensor update to 20%
Z-Wave received "012 - Temperature - Kitchen" sensor update to 22.6 °C
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 2
Z-Wave Syncing - device "036 - Simple Meter" parameter 101 "Group 1 flags" changed to 16131 (was 2)
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 1
Z-Wave Syncing - device "036 - Simple Meter" parameter 102 "Group 2 flags" changed to 0 (was 1)
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Syncing - device "036 - Simple Meter" parameter 103 "Group 3 flags" changed to 0
Z-Wave received "011 - Luminance - MidHall" sensor update to 3 lux
Z-Wave received "011 - Humidity - MidHall" sensor update to 27%
Z-Wave received "011 - Temperature - MidHall" sensor update to 22.3 °C
Z-Wave Syncing - created device "036 - Meter Total"
Z-Wave Syncing - created device "036 - Clamp 1"
Z-Wave Syncing - created device "036 - Clamp 2"
Z-Wave Syncing - created device "036 - Clamp 3"
Z-Wave Syncing - complete
SQL Logger creating table device_history_174941567 for "036 - Meter Total"
SQL Logger creating table device_history_123523284 for "036 - Clamp 1"
Z-Wave Indigo Device "036 - Meter Total" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.119
Node ID: 36
Model: Home Energy Monitor (ZW095)
Model ID: 0002005F
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.54
Application Version: 1.35
Model Definition Version: 1
Library Type: 3
Class Name: Simple Meter
Class Hierarchy: 04 : 31 : 01
Command Class Base: 32
Command Versions: 20v1 60v4 85v1 86v1 72v1 8Ev1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Multi-Endpoint Types: 1:(31 : 01)
Multi-Endpoint Classes: 1:[5E 32 59]
Features: routing, beaming, security, energyMeter
Neighbors: 2, 3, 4, 7, 10, 11, 12, 13, 14, 17, 19, 20, 21, 22, 23, 24, 25, 27, 29, 30, 31, 33, 34
Associations: 1:[1]
Config Values: 3:0 4:50 5:50 6:50 103:0 8:10 9:10 10:10 111:600 112:600 113:600 252:0 102:0 101:16131
Tue Oct 23, 2018 12:50 am
Mathiasw offline
Re: Aeon Labs Home Energy Meter ( ZW095 ) not reporting
Also, (see attached screenshot) there is no option displayed for polling the Meter, which I would have hoped would correct this. I tried turning the polling GUI on (in my cack-handed, no knowledge of Python) manner like this, but it didn't work.
>>> meter=indigo.devices[174941567] # "036 - Meter Total"
>>> print meter.globalProps["com.perceptiveautomation.indigoplugin.zwave"]["zwShowPollingUI"]
False
meter.globalProps["com.perceptiveautomation.indigoplugin.zwave"]["zwShowPollingUI"]=True
False
Damn!
Tue Oct 23, 2018 9:46 am
Properties can only be directly changed by the Z-Wave interface (or the plugin that "owns" the device).
Not sure why the device isn't automatically reporting (it should I think). You might try excluding then including it again (that may act as a reset).
Wed Oct 24, 2018 11:56 am
Mathiasw offline
I have tried removing it, factory resetting it and including it again to no avail.
I am puzzled as to why there is no "polling" option on the setup dialog (attached). Indeed, compared to all the options on the device, the configuration dialog seems very sparse.
It DOES return new values if I press the "Update" button. Is there a way of effectively pressing the "Update" button every minute or so with a trigger?
Config Dialog Display
Screenshot 2018-10-23 at 07.46.45.jpg (330.77 KiB) Viewed 2573 times
Wed Oct 24, 2018 12:05 pm
Indigo's polling UI is not shown for that module because the module itself has a configuration parameter for specifying a reporting interval (that doesn't require a status request/poll command). I'm not sure why that isn't working in this case. You can create a Schedule in Indigo that repeats every minute, then just have the action be of type Device Actions->Universal Controls->Request Energy Update and select your 036 - Meter Total device as the target.
Thu Oct 25, 2018 8:48 am
Mathiasw offline
Aeon labs appear to have thought of this; there are several options which configure a threshold (in both percent and watts) required to trigger an update, on each clamp separately and on the device total, and also a "chatter reduction" flag that prevents excessive chatter on the channel.
Needless to say, I fiddled with ALL of these options and it made no difference.
Thu Oct 25, 2018 8:54 am
Mathiasw offline
matt (support) wrote:
... just have the action be of type Device Actions->Universal Controls->Request Energy Update and select your 036 - Meter Total device as the target.
That's exactly what I needed, thank you so much! It seems to be working fine now!
Fri Feb 22, 2019 2:06 pm
Dual offline
Check out my post for my success story with this meter:
AEOTEC Aeon Labs Home Energy Meter Gen5 ZW095 communicating
Wed Jul 10, 2019 6:26 am
Suncroft offline
Does anyone find the HEM Gen 5 ZW095-C does not record Wattage & kWH very accurately? I am seeing mine report values between 20-25% less than the true values as verified by another (non Z-WAVE) monitor and my smart meter which both match,
I am in the UK on a 240v Single Phase feed and using the Single clamp version of the HEM.
I have the Watts and kWH reporting into Indigo just not getting the right values.
Wed Jul 10, 2019 7:50 am
Dual offline
Mine reports accurately. I compare it to my utility company meter. In USA On 110 VAC with dual clamps.
Wed Jul 10, 2019 8:02 am
McJohn offline
- Is the clamp mounted at the right position? (wrong position give bad results)
- Below 1-2 ampere the measurement is not 100% accurate.
It's working perfectly here at the other side of the North Sea....
Tue Sep 24, 2019 11:10 pm
thamindzzeye offline
I understand that I can "request energy update" as an action from
Device Action >> Universal Controls >> Request Energy Update.
But how would I do this in a python file?
i.e.
indigo.device.statusRequest(dev_id)
I can't seem to figure out how to trigger a energy update to my ZW095 anyway in code.
thanks!
