I've installed one of these, the single clamp model (for 240v single phase). It doesn't seem to be reporting at all, no matter what I set the reporting interval to (it's currently at 30 seconds). It does correctly update the values if I manually update it using the update button. Any idea why? I'm running Indigo 7.2.
I attach the the sync log and the device details.
Z-Wave Syncing - started for "036 - Simple Meter"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 7, 10, 11, 12, 13, 14, 17, 19, 20, 21, 22, 23, 24, 25, 27, 29, 30, 31, 33, 34
Z-Wave Syncing - assigning return route to "036 - Simple Meter"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Home Energy Monitor (ZW095) - 0002005F
Z-Wave Syncing - retrieved protocol version 4.54, app version 1.35
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Meter : Simple Meter (04 : 31 : 01, base 32)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 85v1 86v1 72v1 8Ev1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(31 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 32 59]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 3 "Enable energy change reports" is false
Z-Wave Syncing - device "036 - Simple Meter" parameter 3 "Enable energy change reports" changed to false
Z-Wave Syncing - retrieved parameter 4 "Report threshold watts for total" is 50 watts
Z-Wave Syncing - retrieved parameter 5 "Report threshold watts for clamp 1" is 50 watts
Z-Wave Syncing - retrieved parameter 6 "Report threshold watts for clamp 2" is 50 watts
Z-Wave received "034 - Motion Sensor" status update is off
Z-Wave received "004 - No Idea Where - Motion" status update is off
Z-Wave Syncing - failed to retrieve parameter 7 "Report threshold watts for clamp 3" (skipping)
Z-Wave Syncing - retrieved parameter 8 "Report threshold percentage for total" is 10 %
Z-Wave Syncing - retrieved parameter 9 "Report threshold percentage for clamp 1" is 10 %
Z-Wave Syncing - retrieved parameter 10 "Report threshold percentage for clamp 2" is 10 %
Z-Wave Syncing - failed to retrieve parameter 11 "Report threshold percentage for clamp 3" (skipping)
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 5 seconds
Z-Wave Syncing - device "036 - Simple Meter" parameter 111 "Reporting interval" changed to 600 seconds (was 5 seconds)
Z-Wave received "010 - Luminance - Dining" sensor update to 7 lux
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 120 seconds
Z-Wave received "010 - Humidity - Dining" sensor update to 20%
Z-Wave received "010 - Temperature - Dining" sensor update to 21.7 °C
Z-Wave Syncing - device "036 - Simple Meter" parameter 112 "Reporting interval2" changed to 600 seconds (was 120 seconds)
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 120 seconds
Z-Wave Syncing - device "036 - Simple Meter" parameter 113 "Reporting interval3" changed to 600 seconds (was 120 seconds)
Z-Wave received "012 - Luminance - Kitchen" sensor update to 0 lux
Z-Wave received "012 - Humidity - Kitchen" sensor update to 20%
Z-Wave received "012 - Temperature - Kitchen" sensor update to 22.6 °C
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 2
Z-Wave Syncing - device "036 - Simple Meter" parameter 101 "Group 1 flags" changed to 16131 (was 2)
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 1
Z-Wave Syncing - device "036 - Simple Meter" parameter 102 "Group 2 flags" changed to 0 (was 1)
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Syncing - device "036 - Simple Meter" parameter 103 "Group 3 flags" changed to 0
Z-Wave received "011 - Luminance - MidHall" sensor update to 3 lux
Z-Wave received "011 - Humidity - MidHall" sensor update to 27%
Z-Wave received "011 - Temperature - MidHall" sensor update to 22.3 °C
Z-Wave Syncing - created device "036 - Meter Total"
Z-Wave Syncing - created device "036 - Clamp 1"
Z-Wave Syncing - created device "036 - Clamp 2"
Z-Wave Syncing - created device "036 - Clamp 3"
Z-Wave Syncing - complete
SQL Logger creating table device_history_174941567 for "036 - Meter Total"
SQL Logger creating table device_history_123523284 for "036 - Clamp 1"
Z-Wave Indigo Device "036 - Meter Total" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.119
Node ID: 36
Model: Home Energy Monitor (ZW095)
Model ID: 0002005F
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.54
Application Version: 1.35
Model Definition Version: 1
Library Type: 3
Class Name: Simple Meter
Class Hierarchy: 04 : 31 : 01
Command Class Base: 32
Command Versions: 20v1 60v4 85v1 86v1 72v1 8Ev1 70v1 32v4 73v1 56v1 98v1 59v1 7Av1 5Ev1
Multi-Endpoint Types: 1:(31 : 01)
Multi-Endpoint Classes: 1:[5E 32 59]
Features: routing, beaming, security, energyMeter
Neighbors: 2, 3, 4, 7, 10, 11, 12, 13, 14, 17, 19, 20, 21, 22, 23, 24, 25, 27, 29, 30, 31, 33, 34
Associations: 1:[1]
Config Values: 3:0 4:50 5:50 6:50 103:0 8:10 9:10 10:10 111:600 112:600 113:600 252:0 102:0 101:16131
