If anyone else comes across this thread, this lock
IS supported and
WILL work, the one I got was a dud apparently because the replacement worked and I ordered 5 more and they all worked as well. The docs aren't clear on how you pair these, though, and I had to do some searching to find it so for future reference:
- In Indigo, go to Interface -> Z-wave -> Start Inclusion Mode With Encryption
- Press the Schlage button
- Enter the 6-digit programming code (found in the manual as well as the inside of the lock)
- Press the Schlage button again
- Press the 0 button, this puts the lock into pairing mode
I've also found the
Z-wave Lock Manager plugin an absolute necessity when it comes to managing user codes on Z-wave locks. On these Schlage and my Yales, the sequence of keys required to set or disable a user code is terrible and this plugin makes it a snap and has worked for me every single time. Cudos to HowardP for his great work on that plugin!!!
