OK, I'm relatively new to home automation, but still have dabbled in it for a couple years now...
This is odd to say the least but maybe someone else has encountered similar.
I have a Fibaro wall plug (US version) controlling my patio lights.
I first programmed a couple schedules into it:
Schedule 1 was to turn the patio lights ON at sunset.
Schedule 2 was to turn them off at 11:00pm.
Now what happens is that the lights do come on at sunset, but go off about 22 minutes later.
The auto off in xx:xx is NOT checked in the schedule dialog.
IF I manually trigger them back on, they do stay on until 11:00pm, at which time they go off properly.
After looking everything over, I deleted Schedule 1 (deleted completely).
The next evening, Schedule 1, the ON at sunset was truly gone, as the lights did NOT come on at sunset.
On evening 2, I manually turned on the patio lights and watched.
They should have stayed on until 11:00pm as I left Schedule 2 active.
The lights still went OFF at just after 8:00pm, just as they were doing when Schedule 1 was active.
I don't know where the OFF command is coming from.
The Event Log shows the command, not associated with a Trigger or Schedule.
Anyone experience anything like this? I've never had an issue like this.
The last resort I can think of is to run an exclusion/inclusion on the wall plug and see if it resets anything.
Any thoughts or ideas will be readily welcomed.
Thanks in advance!
Greg
