NEO COOLCAM Z-wave Plus Smart Power Plug UK Socket
Wed Sep 26, 2018 12:13 pm
CliveS offline
Also received the NEO UK 3 Pin Plug which is the smallest UK Z-Wave plug I have seen.
Neo UK 3 Pin Zwave Plug.jpg (3.86 KiB) Viewed 3727 times
Included it and it has the same parameters as the Euro plug version so everything works out of the box so obviously uses the same circuit board just repackaged as a UK plug.
Price from AliExpress was £24.64
Euro Plug details
Z-Wave Indigo Device "139 - Smart Power Plug (NAS-WR01ZE)" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 139
Model: Smart Power Plug (NAS-WR01ZE)
Model ID: 00031087
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 4.05
Application Version: 3.93
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 72v1 70v1 71v1 32v4 73v1 59v1 5Av1 5Ev1 25v1
Features: routing, beaming, energyMeter
Neighbors: - none -
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
New UK Plug Details
Z-Wave Indigo Device "193 - Smart Power Plug (NAS-WR01ZE)" Z-Wave Properties:
Node ID: 193
Model ID: 00031087
Manufacturer: Neo
Application Version: 3.94
Library Type: 3
Neighbors: 103, 151, 156, 157, 158, 165, 166, 186, 188, 190
Sync
Z-Wave Syncing - started for "193 - Smart Power Plug (NAS-WR01ZE)"
Z-Wave Syncing - retrieved module neighbors list: 103, 151, 156, 157, 158, 165, 166, 186, 188, 190
Z-Wave Syncing - assigning return route to "193 - Smart Power Plug (NAS-WR01ZE)"
Z-Wave Watcher Debug Raw command sent (Node 193): 01 06 00 60 C1 24 AE D2 (True)
Z-Wave Watcher Debug Raw command sent (Node 193): 01 09 00 13 C1 02 72 04 25 AF DA (True)
Z-Wave Syncing - retrieved manufacture and model names: Neo - 0258, Smart Power Plug (NAS-WR01ZE) - 00031087
Z-Wave Watcher Debug Raw command received (Node 193): 01 0E 00 04 00 C1 08 72 05 02 58 00 03 10 87 85
Z-Wave Watcher Debug Raw command sent (Node 193): 01 09 00 13 C1 02 86 11 25 B0 24 (True)
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.94
Z-Wave Watcher Debug Raw command received (Node 193): 01 0F 00 04 00 C1 09 86 12 03 04 05 03 5E 41 00 B6
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 86 13 32 25 B1 17 (True)
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 27v1 72v1 70v1 71v1 32v4 73v1 59v1 5Av1 5Ev1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Watcher Debug Raw command received (Node 193): 01 0A 00 04 00 C1 04 86 14 32 04 90
Z-Wave Watcher Debug Raw command sent (Node 193): 01 09 00 13 C1 02 85 05 25 B2 31 (True)
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 85 02 01 25 B3 34 (True)
Z-Wave Watcher Debug Raw command received (Node 193): 01 09 00 04 00 C1 03 85 06 03 B0
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 85 02 02 25 B4 30 (True)
Z-Wave Watcher Debug Raw command received (Node 193): 01 0C 00 04 00 C1 06 85 03 01 05 00 01 B3
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 85 02 03 25 B5 30 (True)
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Watcher Debug Raw command received (Node 193): 01 0B 00 04 00 C1 05 85 03 02 05 00 B5
Z-Wave Watcher Debug Raw command received (Node 193): 01 0B 00 04 00 C1 05 85 03 03 05 00 B4
Z-Wave Watcher Debug Raw command sent (Node 193): 01 09 00 13 C1 02 32 03 25 B6 84 (True)
Z-Wave Watcher Debug Raw command received (Node 193): 01 0A 00 04 00 C1 04 32 04 A1 35 96
Z-Wave Syncing - complete
Z-Wave Watcher Debug Raw command sent (Node 193): 01 09 00 13 C1 02 25 02 25 B7 93 (True)
Z-Wave sent "193 - Smart Power Plug (NAS-WR01ZE)" status request
Z-Wave sent "193 - Smart Power Plug (NAS-WR01ZE)" energy status request
Z-Wave Watcher Debug Raw command received (Node 193): 01 09 00 04 00 C1 03 25 03 FF E9
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 32 01 00 25 B8 8A (True)
Z-Wave Watcher Debug Raw command received (Node 193): 01 14 00 04 00 C1 0E 32 02 21 44 00 00 00 05 00 22 00 00 00 05 57
Z-Wave Watcher Debug Raw command sent (Node 193): 01 0A 00 13 C1 03 32 01 10 25 B9 9B (True)
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" power load to 16.48 W
Z-Wave Watcher Debug Raw command received (Node 193): 01 14 00 04 00 C1 0E 32 02 21 54 00 00 06 70 00 22 00 00 06 73 44
CliveS
Wed Sep 26, 2018 3:08 pm
Re: NEO COOLCAM Z-wave Plus Smart Power Plug UK Socket
Thanks for sharing, and I'm glad it is identifying itself the same to Indigo.
Thu Sep 27, 2018 4:36 am
Suncroft offline
Out of interest does this plug report on/off status to Indigo when controlled locally with the button on the plug?
Stephen
Thu Sep 27, 2018 6:50 am
CliveS offline
Stephen
Yes it is instant for both on and off
Manual Switching
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" status update is on
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" status update is off
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" power load to 17.49 W
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" power load to 17.27 W
and then from Indigo
Z-Wave sent "193 - Smart Power Plug (NAS-WR01ZE)" off
Z-Wave sent "193 - Smart Power Plug (NAS-WR01ZE)" on
Z-Wave received "193 - Smart Power Plug (NAS-WR01ZE)" power load to 17.18 W
CliveS
Fri Sep 28, 2018 2:10 am
Suncroft offline
Cool thanks, May get a few of these at that price then.
Stephen
Fri Sep 28, 2018 2:40 am
CliveS offline
The link to the plug is
https://www.aliexpress.com/item/NEO-COOLCAM-Z-wave-Plus-Smart-Power-Plug-UK-Socket-Smart-Home-Automation-Alarm-System-home/32883044487.html?spm=a2g0s.9042311.0.0.36bf4c4devKvTv
They also do the same plug but WiFi version "Coolcam Smart UK Plug Support Amazon Alexa Google Home,IFTTT Remote Control WiFi Switch Mini Socket Outlet with Timing Function" for £15.00 so double check it is Z-Wave you order.
CliveS
Wed May 08, 2019 12:54 pm
siclark offline
Word of warning on these, I have 2 that have been in use for approx 6 months. Wife complaining that one of them not working today and kept turning off. I kept turning back on via Home app, and it turned back off. Got home to find it looking like this! well, once I finally got it out the wall. took 5 mins and the reason being the plastic was melted and one of the pins was trapped in the wall socket!
Fri May 17, 2019 9:30 am
CliveS offline
What was plugged into it, that does not look good and I have just purchased a new one this week!!
CliveS
Fri May 17, 2019 9:47 am
CliveS offline
I have just bought a new UK Neo Power Plug and it is an upgrade from the original version in that it now supports Encryption
It works fine except it errors on Energy Total with
   Z-Wave                          received "Blue Iris Server Power Plug " energy total to -21474834.26 kWh
   Z-Wave Error                    received "Blue Iris Server Power Plug " energy total value out-of-bounds -21474834.26 kWh (ignored)
   Z-Wave                          received "Blue Iris Server Power Plug " power load to 59.90 W
   UnSupported Sensors             Blue Iris Server Plug Energy Report is 21474838.7 kWh
   UnSupported Sensors             Blue Iris Server Plug socket-kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 80 00 00 DE 01 2D 80 00 00 DE 7E - socket-kWh
   UnSupported Sensors
   UnSupported Sensors             Blue Iris Server Plug Power Report is 59.9 w
   UnSupported Sensors             Blue Iris Server Plug socket-Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 17 66 01 2D 00 00 16 6A 63 - socket-Watts
   UnSupported Sensors
   UnSupported Sensors             Blue Iris Server Plug Voltage Report is 255.59 v
   UnSupported Sensors             Blue Iris Server Plug socket-Volts - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 42 63 D7 01 2D 62 73 5D - socket-Volts
   UnSupported Sensors
   UnSupported Sensors             Blue Iris Server Plug Current Report is 0.28 a
   UnSupported Sensors             Blue Iris Server Plug socket-Amps - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1C 01 2D 00 1B F7 - socket-Amps
New Version Device Details
17 May 2019 at 16:13:41
Z-Wave Indigo Device "Blue Iris Server Power Plug " Z-Wave Properties:
Indigo Z-Wave Version: 2.0.124
Node ID: 230
Model: Power Plug
Model ID: 02001027
Manufacturer: Neo
Protocol Version: 6.02
Application Version: 2.32
Library Type: 3
Command Versions: 85v1 86v1 8Ev1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 25v1 27v1 6Cv1 72v1 70v1 71v1 32v4 73v1
Features: routing, beaming, security, energyMeter
Neighbors: 103, 149, 150, 151, 156, 158, 186, 188, 190, 196, 202, 226, 227
Original Version Device Details
17 May 2019 at 16:14:02
Z-Wave Indigo Device "HP_DS1 Server Power Plug" Z-Wave Properties:
Node ID: 226
Model: Power Plug (NAS-WR01ZE)
Model ID: 00031087
Manufacturer: Neo
Library Type: 3
Neighbors: 6, 149, 151, 157, 158, 188, 190, 196, 202, 203
CliveS
Fri May 17, 2019 10:13 am
siclark offline
It was plugged into a tumble drier. It quite happily handled the 300w of power, guess as it's a relay not an dimmer. However my sparky friend thinks the extra weight could have pulled on the plug slightly causing a less than perfect connection that for warm and caused it to melt. Was fine for 6 months
the smart socket turned itself off preventing more damage as the RCD didn't trip.
Wondering if I risk a replacement and tape it it together or leave it.
Fri May 17, 2019 12:46 pm
CliveS offline
You could always do what I did with the Neo euro version and make an inline switch, cut a UK plug and socket and add a male and female Euro-Schuko.
https://www.ebay.co.uk/itm/White-Kaiser-Euro-Schuko-rewireable-socket-quality-German-made/113221099999?hash=item1a5c80e1df:g:jTAAAOSwZ-lbgqDu
https://www.ebay.co.uk/itm/White-Kaiser-Euro-Schuko-rewireable-plug-quality-German-made/113210566944?epid=1788444342&hash=item1a5be02920:g:9bYAAOSwHk9beWoW
That would take the strain off the plug socket
CliveS
Thu Jun 13, 2019 9:09 am
CliveS offline
Matt,
When you update the definition for the newer UK power plug that supports Encryption and gives log errors on Total Energy ( details above in message dated Fri 17 May 2019 16:47) can you also include a "Hide status and energy message broadcast in Event Log" tick box please.
CliveS
Fri Jun 14, 2019 3:51 pm
Hi Clive,
So we can have it properly labeled in the UI, is the model number for the new one the same as the old: NAS-WR01ZE?
Regarding the energy error message, can you send it a status request (to poll out the current energy), then press the button in the Main Window UI to reset the energy to 0 and press the status request button again? I'm curious what the Event Log shows in that case (before and after the reset).
Sun Jun 16, 2019 12:48 pm
CliveS offline
matt (support) wrote:
Hi Clive,
Yes it seems all NEO Power Plugs are NAS-WR01ZE ( the EU ones show as Smart Power Plug (NAS-WR01ZE) , the original UK as Power Plug (NAS-WR01ZE) and the new one as just Power Plug , which is not good for my OCD :)
2019-06-16 10:13:28.043 Z-Wave Debug received "Dining Room Motion Sensor" status update is on
2019-06-16 10:13:29.433 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 44 80 00 00 BA 01 2D 80 00 00 BA 7E
2019-06-16 10:13:29.433 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4480...
2019-06-16 10:13:29.434 Z-Wave Debug . . requestMeterLevel: -21474834.62 kWh (float: -21474834.620000)
2019-06-16 10:13:29.434 Z-Wave received "Blue Iris Server Power Plug " energy total to -21474834.62 kWh
2019-06-16 10:13:29.434 Z-Wave Error received "Blue Iris Server Power Plug " energy total value out-of-bounds -21474834.62 kWh (ignored)
2019-06-16 10:13:29.435 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 54 00 00 15 6F 01 2D 00 00 15 55 54
2019-06-16 10:13:29.436 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:13:29.436 Z-Wave Debug . . requestMeterLevel: 54.87 W (float: 54.870000)
2019-06-16 10:13:29.436 Z-Wave received "Blue Iris Server Power Plug " power load to 54.87 W
2019-06-16 10:13:29.441 UnSupported Sensors Test Neo New UK Plug Energy Report is 21474838.34 kWh
2019-06-16 10:13:29.441 UnSupported Sensors Test Neo New UK Plug kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 80 00 00 BA 01 2D 80 00 00 BA 7E - kWh
2019-06-16 10:13:29.443 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 42 62 A7 01 2D 60 1F 42
2019-06-16 10:13:29.444 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4262...
2019-06-16 10:13:29.444 Z-Wave Debug . . requestMeterLevel: 252.55 V (float: 252.550000)
2019-06-16 10:13:29.448 UnSupported Sensors Test Neo New UK Plug Power Report is 54.87 w
2019-06-16 10:13:29.449 UnSupported Sensors Test Neo New UK Plug Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 15 6F 01 2D 00 00 15 55 54 - Watts
2019-06-16 10:13:29.455 UnSupported Sensors Test Neo New UK Plug Voltage Report is 252.55 v
2019-06-16 10:13:29.455 UnSupported Sensors Test Neo New UK Plug Volts - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 42 62 A7 01 2D 60 1F 42 - Volts
2019-06-16 10:13:29.456 UnSupported Sensors Test
2019-06-16 10:13:29.476 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1A 01 2D 00 1A F0
2019-06-16 10:13:29.477 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4A00...
2019-06-16 10:13:29.477 Z-Wave Debug . . requestMeterLevel: 0.26 A (float: 0.260000)
2019-06-16 10:13:29.480 UnSupported Sensors Test Neo New UK Plug Current Report is 0.26 a
2019-06-16 10:13:29.480 UnSupported Sensors Test Neo New UK Plug Amps - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1A 01 2D 00 1A F0 - Amps
2019-06-16 10:13:34.464 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 B2 37
2019-06-16 10:13:34.465 Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 3, raw value 0A00...
2019-06-16 10:13:34.465 Z-Wave Debug . . requestVarSensorStatus: 178 lux (float: 178.000000)
2019-06-16 10:27:17.664 Z-Wave sent "Blue Iris Server Power Plug " energy status request
2019-06-16 10:27:17.664 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E6 03 32 01 00 25 6F 7A
2019-06-16 10:27:17.943 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 01 00 E5 00 00 00 00 B6
2019-06-16 10:27:17.943 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:27:17.943 Z-Wave Debug . . requestMeterLevel: 0.01 kWh (float: 0.010000)
2019-06-16 10:27:17.944 Z-Wave received "Blue Iris Server Power Plug " energy total to 0.01 kWh
2019-06-16 10:27:17.945 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E6 03 32 01 10 25 70 75
2019-06-16 10:27:17.949 UnSupported Sensors Test Neo New UK Plug Energy Report is 0.01 kWh
2019-06-16 10:27:17.949 UnSupported Sensors Test Neo New UK Plug kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 01 00 E5 00 00 00 00 B6 - kWh
2019-06-16 10:27:17.950 UnSupported Sensors Test
2019-06-16 10:27:18.226 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 54 00 00 16 13 00 E5 00 00 14 A1 17
2019-06-16 10:27:18.227 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:27:18.227 Z-Wave Debug . . requestMeterLevel: 56.51 W (float: 56.510000)
2019-06-16 10:27:18.227 Z-Wave received "Blue Iris Server Power Plug " power load to 56.51 W
2019-06-16 10:27:18.232 UnSupported Sensors Test Neo New UK Plug Power Report is 56.51 w
2019-06-16 10:27:18.232 UnSupported Sensors Test Neo New UK Plug Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 16 13 00 E5 00 00 14 A1 17 - Watts
2019-06-16 10:27:21.093 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 BC 06 31 05 04 22 00 00 5F
2019-06-16 10:27:21.093 Z-Wave Debug . . requestVarSensorStatus: node 188, endpoint None, type 4, raw value 2200...
2019-06-16 10:27:21.094 Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
2019-06-16 10:27:23.983 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 63 06 31 05 01 22 00 C3 46
2019-06-16 10:27:23.984 Z-Wave Debug . . requestVarSensorStatus: node 099, endpoint None, type 1, raw value 2200...
2019-06-16 10:27:23.984 Z-Wave Debug . . requestVarSensorStatus: 19.5 °C (float: 19.500000)
2019-06-16 10:27:23.984 Z-Wave Debug received "Living Room PST02 Temperature" sensor update to 19.5 °C
2019-06-16 10:27:25.519 Z-Wave Debug SENT resetAccumEnergyTotal: 01 09 00 13 E6 02 32 05 25 71 62
2019-06-16 10:27:25.550 Z-Wave sent "Blue Iris Server Power Plug " energy usage reset
2019-06-16 10:27:28.942 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BE 0A 32 02 21 32 00 04 00 00 00 00 78
2019-06-16 10:27:28.943 Z-Wave Debug . . requestMeterLevel: node 190, endpoint None, meterType 01, raw value 3200...
2019-06-16 10:27:28.943 Z-Wave Debug . . requestMeterLevel: 0.4 W (float: 0.400000)
2019-06-16 10:27:29.118 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 BE 0E 32 02 21 44 00 00 08 CD 00 00 00 00 00 00 CF
2019-06-16 10:27:29.118 Z-Wave Debug . . requestMeterLevel: node 190, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:27:29.119 Z-Wave Debug . . requestMeterLevel: 22.53 kWh (float: 22.530000)
2019-06-16 10:27:31.927 Z-Wave sent "Blue Iris Server Power Plug " energy status request
2019-06-16 10:27:31.928 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E6 03 32 01 00 25 72 67
2019-06-16 10:27:32.211 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 00 00 0F 00 00 00 00 5D
2019-06-16 10:27:32.211 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:27:32.211 Z-Wave Debug . . requestMeterLevel: 0.00 kWh (float: 0.000000)
2019-06-16 10:27:32.212 Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 E6 03 32 01 10 25 73 76
2019-06-16 10:27:32.214 UnSupported Sensors Test Neo New UK Plug Energy Report is 0.0 kWh
2019-06-16 10:27:32.214 UnSupported Sensors Test Neo New UK Plug kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 00 00 0F 00 00 00 00 5D - kWh
2019-06-16 10:27:32.215 UnSupported Sensors Test
2019-06-16 10:27:32.491 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 54 00 00 16 6F 00 0F 00 00 16 13 31
2019-06-16 10:27:32.491 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:27:32.492 Z-Wave Debug . . requestMeterLevel: 57.43 W (float: 57.430000)
2019-06-16 10:27:32.492 Z-Wave received "Blue Iris Server Power Plug " power load to 57.43 W
2019-06-16 10:27:32.496 UnSupported Sensors Test Neo New UK Plug Power Report is 57.43 w
2019-06-16 10:27:32.497 UnSupported Sensors Test Neo New UK Plug Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 16 6F 00 0F 00 00 16 13 31 - Watts
2019-06-16 10:27:34.998 Trigger EvoHome Hall-Kitchen Temperature Change
2019-06-16 10:27:35.007 Action Collection Hall-Kitchen Temperature is 18.5
2019-06-16 10:27:35.009 Action Collection Hall-Kitchen Setpoint Is 16.0
2019-06-16 10:27:36.404 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 01 22 00 DE 71
2019-06-16 10:27:36.404 Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 1, raw value 2200...
2019-06-16 10:27:36.404 Z-Wave Debug . . requestVarSensorStatus: 22.2 °C (float: 22.200000)
2019-06-16 10:27:36.405 Z-Wave Debug received "Kitchen Fibaro Temperature" sensor update to 22.2 °C
2019-06-16 10:27:38.065 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BC 0A 32 02 21 44 00 00 05 58 00 00 55
2019-06-16 10:27:38.065 Z-Wave Debug . . requestMeterLevel: node 188, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:27:38.066 Z-Wave Debug . . requestMeterLevel: 13.68 kWh (float: 13.680000)
2019-06-16 10:27:51.061 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 BC 06 31 05 04 22 00 00 5F
2019-06-16 10:27:51.061 Z-Wave Debug . . requestVarSensorStatus: node 188, endpoint None, type 4, raw value 2200...
2019-06-16 10:27:51.061 Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
2019-06-16 10:27:52.842 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 DF 06 31 05 03 0A 03 2A 3A
2019-06-16 10:27:52.842 Z-Wave Debug . . requestVarSensorStatus: node 223, endpoint None, type 3, raw value 0A03...
2019-06-16 10:27:52.843 Z-Wave Debug . . requestVarSensorStatus: 810 lux (float: 810.000000)
2019-06-16 10:27:52.843 Z-Wave Debug received "Front Door Luminance" sensor update to 810 lux
2019-06-16 10:27:59.025 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 D5 06 31 05 03 0A 00 D4 CD
2019-06-16 10:27:59.025 Z-Wave Debug . . requestVarSensorStatus: node 213, endpoint None, type 3, raw value 0A00...
2019-06-16 10:27:59.025 Z-Wave Debug . . requestVarSensorStatus: 212 lux (float: 212.000000)
2019-06-16 10:27:59.026 Z-Wave Debug received "Bathroom Fibaro Luminance Sensor" sensor update to 212 lux
2019-06-16 10:27:59.198 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BE 0A 32 02 21 32 00 04 00 00 00 00 78
2019-06-16 10:27:59.198 Z-Wave Debug . . requestMeterLevel: node 190, endpoint None, meterType 01, raw value 3200...
2019-06-16 10:27:59.198 Z-Wave Debug . . requestMeterLevel: 0.4 W (float: 0.400000)
2019-06-16 10:28:10.236 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E3 0E 32 02 21 44 00 00 00 3B 01 2D 00 00 00 3B 7B
2019-06-16 10:28:10.236 Z-Wave Debug . . requestMeterLevel: node 227, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:28:10.237 Z-Wave Debug . . requestMeterLevel: 0.59 kWh (float: 0.590000)
2019-06-16 10:28:11.193 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E3 0E 32 02 21 54 00 00 0E 2F 01 2D 00 00 0E 46 02
2019-06-16 10:28:11.193 Z-Wave Debug . . requestMeterLevel: node 227, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:28:11.193 Z-Wave Debug . . requestMeterLevel: 36.31 W (float: 36.310000)
2019-06-16 10:28:11.194 Z-Wave received "HP_DS2 Server Power Plug" power load to 36.31 W
2019-06-16 10:28:12.230 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E3 0A 32 02 A1 42 60 C2 01 2D 61 5B 65
2019-06-16 10:28:12.230 Z-Wave Debug . . requestMeterLevel: node 227, endpoint None, meterType 01, raw value 4260...
2019-06-16 10:28:12.230 Z-Wave Debug . . requestMeterLevel: 247.70 V (float: 247.700000)
2019-06-16 10:28:13.189 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E3 0A 32 02 A1 4A 00 14 01 2D 00 14 F5
2019-06-16 10:28:13.189 Z-Wave Debug . . requestMeterLevel: node 227, endpoint None, meterType 01, raw value 4A00...
2019-06-16 10:28:13.189 Z-Wave Debug . . requestMeterLevel: 0.20 A (float: 0.200000)
2019-06-16 10:28:14.084 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BC 0A 32 02 21 44 00 00 05 58 00 00 55
2019-06-16 10:28:14.084 Z-Wave Debug . . requestMeterLevel: node 188, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:28:14.085 Z-Wave Debug . . requestMeterLevel: 13.68 kWh (float: 13.680000)
2019-06-16 10:28:21.063 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 BC 06 31 05 04 22 00 00 5F
2019-06-16 10:28:21.064 Z-Wave Debug . . requestVarSensorStatus: node 188, endpoint None, type 4, raw value 2200...
2019-06-16 10:28:21.065 Z-Wave Debug . . requestVarSensorStatus: 0.0 W (float: 0.000000)
2019-06-16 10:28:24.139 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 49 06 31 05 03 0A 00 58 DD
2019-06-16 10:28:24.139 Z-Wave Debug . . requestVarSensorStatus: node 073, endpoint None, type 3, raw value 0A00...
2019-06-16 10:28:24.140 Z-Wave Debug . . requestVarSensorStatus: 88 lux (float: 88.000000)
2019-06-16 10:28:24.140 Z-Wave Debug received "Kitchen Fibaro Lux" sensor update to 88 lux
2019-06-16 10:28:24.208 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 DD 06 31 05 03 0A 06 ED FA
2019-06-16 10:28:24.208 Z-Wave Debug . . requestVarSensorStatus: node 221, endpoint None, type 3, raw value 0A06...
2019-06-16 10:28:24.209 Z-Wave Debug . . requestVarSensorStatus: 1773 lux (float: 1773.000000)
2019-06-16 10:28:24.209 Z-Wave Debug received "Drive Left Luminance" sensor update to 1773 lux
2019-06-16 10:28:29.387 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 00 00 3B 00 00 00 00 69
2019-06-16 10:28:29.387 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:28:29.387 Z-Wave Debug . . requestMeterLevel: 0.00 kWh (float: 0.000000)
2019-06-16 10:28:29.388 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BE 0A 32 02 21 32 00 04 00 00 00 00 78
2019-06-16 10:28:29.388 Z-Wave Debug . . requestMeterLevel: node 190, endpoint None, meterType 01, raw value 3200...
2019-06-16 10:28:29.389 Z-Wave Debug . . requestMeterLevel: 0.4 W (float: 0.400000)
2019-06-16 10:28:29.389 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 54 00 00 17 32 00 3B 00 00 16 6F 25
2019-06-16 10:28:29.390 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:28:29.390 Z-Wave Debug . . requestMeterLevel: 59.38 W (float: 59.380000)
2019-06-16 10:28:29.391 Z-Wave received "Blue Iris Server Power Plug " power load to 59.38 W
2019-06-16 10:28:29.392 UnSupported Sensors Test Neo New UK Plug Energy Report is 0.0 kWh
2019-06-16 10:28:29.392 UnSupported Sensors Test Neo New UK Plug kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 00 00 00 00 00 3B 00 00 00 00 69 - kWh
2019-06-16 10:28:29.400 UnSupported Sensors Test Neo New UK Plug Power Report is 59.38 w
2019-06-16 10:28:29.400 UnSupported Sensors Test Neo New UK Plug Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 17 32 00 3B 00 00 16 6F 25 - Watts
2019-06-16 10:28:29.401 UnSupported Sensors Test
2019-06-16 10:28:29.409 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 42 62 B9 00 3B 62 82 D4
2019-06-16 10:28:29.410 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4262...
2019-06-16 10:28:29.410 Z-Wave Debug . . requestMeterLevel: 252.73 V (float: 252.730000)
2019-06-16 10:28:29.412 UnSupported Sensors Test Neo New UK Plug Voltage Report is 252.73 v
2019-06-16 10:28:29.412 UnSupported Sensors Test Neo New UK Plug Volts - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 42 62 B9 00 3B 62 82 D4 - Volts
2019-06-16 10:28:29.413 UnSupported Sensors Test
2019-06-16 10:28:29.444 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1C 00 3B 00 1B E0
2019-06-16 10:28:29.444 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4A00...
2019-06-16 10:28:29.444 Z-Wave Debug . . requestMeterLevel: 0.28 A (float: 0.280000)
2019-06-16 10:28:29.447 UnSupported Sensors Test Neo New UK Plug Current Report is 0.28 a
2019-06-16 10:28:29.447 UnSupported Sensors Test Neo New UK Plug Amps - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1C 00 3B 00 1B E0 - Amps
2019-06-16 10:28:29.512 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 BE 0E 32 02 21 44 00 00 08 CD 00 00 00 00 00 00 CF
2019-06-16 10:28:29.512 Z-Wave Debug . . requestMeterLevel: node 190, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:28:29.512 Z-Wave Debug . . requestMeterLevel: 22.53 kWh (float: 22.530000)
2019-06-16 10:28:50.070 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 BC 0A 32 02 21 44 00 00 05 58 00 00 55
2019-06-16 10:28:50.071 Z-Wave Debug . . requestMeterLevel: node 188, endpoint None, meterType 01, raw value 4400...
2019-06-16 10:28:50.071 Z-Wave Debug . . requestMeterLevel: 13.68 kWh (float: 13.680000)
2019-06-16 10:28:52.074 Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 BC 06 31 05 04 22 00 00 5F
2019-06-16 10:43:29.316 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4480...
2019-06-16 10:43:29.316 Z-Wave Debug . . requestMeterLevel: -21474836.46 kWh (float: -21474836.460000)
2019-06-16 10:43:29.316 Z-Wave received "Blue Iris Server Power Plug " energy total to -21474836.46 kWh
2019-06-16 10:43:29.317 Z-Wave Error received "Blue Iris Server Power Plug " energy total value out-of-bounds -21474836.46 kWh (ignored)
2019-06-16 10:43:29.319 UnSupported Sensors Test Neo New UK Plug Energy Report is 21474836.5 kWh
2019-06-16 10:43:29.319 UnSupported Sensors Test Neo New UK Plug kWh - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 44 80 00 00 02 01 2D 80 00 00 02 7E - kWh
2019-06-16 10:43:29.360 Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 E6 0E 32 02 21 54 00 00 17 86 01 2D 00 00 15 C4 2E
2019-06-16 10:43:29.361 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 5400...
2019-06-16 10:43:29.361 Z-Wave Debug . . requestMeterLevel: 60.22 W (float: 60.220000)
2019-06-16 10:43:29.361 Z-Wave received "Blue Iris Server Power Plug " power load to 60.22 W
2019-06-16 10:43:29.366 UnSupported Sensors Test Neo New UK Plug Power Report is 60.22 w
2019-06-16 10:43:29.366 UnSupported Sensors Test Neo New UK Plug Watts - Node 230 : Hex E6 - 01 14 00 04 00 E6 0E 32 02 21 54 00 00 17 86 01 2D 00 00 15 C4 2E - Watts
2019-06-16 10:43:29.367 UnSupported Sensors Test
2019-06-16 10:43:29.369 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 42 63 8E 01 2D 63 28 5E
2019-06-16 10:43:29.370 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4263...
2019-06-16 10:43:29.370 Z-Wave Debug . . requestMeterLevel: 254.86 V (float: 254.860000)
2019-06-16 10:43:29.374 UnSupported Sensors Test Neo New UK Plug Voltage Report is 254.86 v
2019-06-16 10:43:29.374 UnSupported Sensors Test Neo New UK Plug Volts - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 42 63 8E 01 2D 63 28 5E - Volts
2019-06-16 10:43:29.407 Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1C 01 2D 00 1A F6
2019-06-16 10:43:29.408 Z-Wave Debug . . requestMeterLevel: node 230, endpoint None, meterType 01, raw value 4A00...
2019-06-16 10:43:29.408 Z-Wave Debug . . requestMeterLevel: 0.28 A (float: 0.280000)
2019-06-16 10:43:29.410 UnSupported Sensors Test Neo New UK Plug Current Report is 0.28 a
2019-06-16 10:43:29.411 UnSupported Sensors Test Neo New UK Plug Amps - Node 230 : Hex E6 - 01 10 00 04 00 E6 0A 32 02 A1 4A 00 1C 01 2D 00 1A F6 - Amps
2019-06-16 10:43:30.208 Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 98 09 71 05 00 00 00 FF 07 08 00 E1
2019-06-16 10:43:30.208 Z-Wave Debug . . requestAlarmSensorStatus: node 152, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
2019-06-16 10:43:30.208 Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Hope that is what you need but I can send the whole days log if required.
CliveS
Thu Jun 20, 2019 9:42 pm
We'll get that labelled correctly in the next version.
Unfortunately, there isn't much I can do about the kWh being reported as out-of-bounds (huge negative number). Just to make sure it wasn't an Indigo problem I manually decoded the packet the module is sending in this case:
0x01, 0x14, 0x00, 0x04, 0x00, 0xE6, 0x0E, 0x32, 0x02, 0x21, 0x44, 0x80, 0x00, 0x00, 0xBA, 0x01, 0x2D, 0x80, 0x00, 0x00, 0xBA, 0x7E
Using the Meter Report Command section of the Z-Wave spec (Z-Wave Application Command Class Specification section 4.48.4) and the value being sent to Indigo is indeed a really large negative number. In this case 32 bit signed integer 800000BA is -2147483462 and the scale of the number is to the hundredths, so that would be 21474834.62. Looks like a firmware buglet in the module itself – it is sending bad data in this case.
