Just received this PIR sensor from AliExpress which looks just like the original Neo PIR and Lux (and Lux was at best flaky in them) but now with an added Temperature Sensor as well.
UK/EU frequency price was £23.10 from AliExpress (delivery took 10 days) or from UK supplier Vesternet for £38.00 plus carriage!
Included the sensor but nothing is working at present, a bit surprised as I thought it might be seen as an original without temperature.
Hopefully they will be included in the 7.2 update
Sync output
Z-Wave Syncing - started for "195 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 85, 139, 150, 151, 156, 157, 158, 166, 186, 190
Z-Wave Syncing - assigning return route to "195 - Notification Sensor"
Z-Wave Watcher Debug Raw command sent (Node 195): 01 06 00 60 C3 24 04 7A (True)
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 72 04 25 05 72 (True)
Z-Wave Syncing - retrieved manufacture and model names: Neo - 0258, Notification Sensor - 0003108D
Z-Wave Watcher Debug Raw command received (Node 195): 01 0E 00 04 00 C3 08 72 05 02 58 00 03 10 8D 8D
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 86 11 25 06 90 (True)
Z-Wave Syncing - retrieved protocol version 4.38, app version 3.80
Z-Wave Watcher Debug Raw command received (Node 195): 01 0F 00 04 00 C3 09 86 12 06 04 26 03 50 42 00 9F
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 86 13 84 25 07 15 (True)
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 86 13 31 25 08 AF (True)
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Watcher Debug Raw command received (Node 195): 01 0A 00 04 00 C3 04 86 14 84 02 22
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v7 72v1 73v1 71v1 59v1 5Av1 5Ev1
Z-Wave Watcher Debug Raw command received (Node 195): 01 0A 00 04 00 C3 04 86 14 31 07 92
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 84 05 25 09 89 (True)
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave received "Dining Room Samsung TV Switch" power load to 25.0 W
Z-Wave Syncing - device "195 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0D 00 13 C3 06 84 04 00 0E 10 01 25 0A 94 (True)
Z-Wave Watcher Debug Raw command received (Node 195): 01 0C 00 04 00 C3 06 84 06 00 0E 10 01 AF
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 85 05 25 0B 8A (True)
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 85 02 01 25 0C 89 (True)
Z-Wave Watcher Debug Raw command received (Node 195): 01 09 00 04 00 C3 03 85 06 04 B5
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 85 02 02 25 0D 8B (True)
Z-Wave Watcher Debug Raw command received (Node 195): 01 0C 00 04 00 C3 06 85 03 01 03 00 01 B7
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 85 02 03 25 0E 89 (True)
Z-Wave Watcher Debug Raw command received (Node 195): 01 0B 00 04 00 C3 05 85 03 02 03 00 B1
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Watcher Debug Raw command sent (Node 195): 01 0A 00 13 C3 03 85 02 04 25 0F 8F (True)
Z-Wave Watcher Debug Raw command received (Node 195): 01 0B 00 04 00 C3 05 85 03 03 03 00 B0
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Watcher Debug Raw command received (Node 195): 01 0B 00 04 00 C3 05 85 03 04 03 00 B7
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 80 02 25 10 93 (True)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Watcher Debug Raw command received (Node 195): 01 09 00 04 00 C3 03 80 03 64 D5
Z-Wave Syncing - complete
Z-Wave Watcher Debug Raw command sent (Node 195): 01 09 00 13 C3 02 71 04 25 11 65 (True)
Z-Wave Indigo Device "195 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 195
Model: Notification Sensor
Model ID: 0003108D
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 4.38
Application Version: 3.80
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v7 72v1 73v1 71v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 85, 139, 150, 151, 156, 157, 158, 166, 186, 190
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
