Does anyone have any experience with the Qubino RGBW controller?
http://qubino.com/products/flush-rgbw-dimmer/
welchgregusa wrote:I've set up a bunch (14) and generally they seem to work well—I can set the independent RGBW values (in the GUI and in Python), etc.
One issue I have seen, that I'm still investigating, is that the devices seem to "lose sync" w/ Indigo at times—I've seen it after a reboot, but other times as well. I have to go back to each device and do a sync, and then they work fine again. They all have constant 12V power (via a Mean Well power supply) and AFAIK they are all otherwise fine. This is in Indigo 7.4.1. Most of the devices are firmware 2.98 but two are 2.95. I've never seen this before with other devices.
Would love to hear any ideas....
Thanks.
2020-09-13 22:45:41.527 Z-Wave Error module 206 included in controller does not match device "RGBW LED, CR Window 4 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.533 Z-Wave Error module 207 included in controller does not match device "RGBW LED, CR Window 3 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.537 Z-Wave Error module 208 included in controller does not match device "RGBW LED, CR Window 2 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.542 Z-Wave Error module 209 included in controller does not match device "RGBW LED, CR Window 1 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.546 Z-Wave Error module 210 included in controller does not match device "RGBW LED, CR Door 2 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.550 Z-Wave Error module 211 included in controller does not match device "RGBW LED, CR Door 1 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.554 Z-Wave Error module 212 included in controller does not match device "RGBW LED, FR Window (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.559 Z-Wave Error module 213 included in controller does not match device "RGBW LED, FR Door 2 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.563 Z-Wave Error module 214 included in controller does not match device "RGBW LED, FR Door 1 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.566 Z-Wave found module included in controller with no matching device (missing or disabled): 215 - Dimmable Power Switch
2020-09-13 22:45:41.571 Z-Wave Error module 216 included in controller does not match device "RGBW LED, KIT Window 2 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.575 Z-Wave Error module 217 included in controller does not match device "RGBW LED, KIT Window 1 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.579 Z-Wave Error module 218 included in controller does not match device "RGBW LED, LR Door 2 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.584 Z-Wave Error module 219 included in controller does not match device "RGBW LED, LR Door 1 (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.588 Z-Wave Error module 220 included in controller does not match device "RGBW LED, KIT Door (Z)" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwColorDimmerType (4, 17, 1))
2020-09-13 22:45:41.592 Z-Wave found module included in controller with no matching device (missing or disabled): 222 - Notification Sensor
2020-09-13 22:45:41.596 Z-Wave found module included in controller with no matching device (missing or disabled): 223 - Notification Sensor
Z-Wave sent "RGBW LED, CR Window 4 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, CR Window 3 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, CR Window 2 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, CR Window 1 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, FR Window (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, FR Door 2 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, FR Door 1 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, KIT Window 2 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, KIT Window 1 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, KIT Door (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, LR Door 2 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, LR Door 1 (Z)" set color to -- -- -- -- --
Z-Wave Error serial port communication error: read failed: [Errno 6] Device not configured
Z-Wave Error Z-Stick Plus (ZW090) might be disconnected
Z-Wave Error silently retrying serial connection every 5.0 seconds
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem14601 (firmware 1.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 075 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 082 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 089 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 090 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 092 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 095 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 112 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 113 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 116 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 118 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 121 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 122 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 123 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 128 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 130 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 132 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 138 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 141 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 145 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 148 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 150 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 155 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 163 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 188 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 191 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 197 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 200 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 228 - Notification Sensor
Z-Wave found module included in controller with no matching device (missing or disabled): 229 - Notification Sensor
Action Group Mood, Evening, Update, RGBW
Z-Wave sent "RGBW LED, CR Door 2 (Z)" set color to -- -- -- -- --
Z-Wave sent "RGBW LED, CR Door 1 (Z)" set color to -- -- -- -- --
Z-Wave Syncing - started for "RGBW LED, CR Door 1 (Z)"
Z-Wave Syncing - retrieved module neighbors list: 206, 207, 208, 209, 210, 212, 214, 215, 216, 217, 218, 219, 220
Z-Wave Syncing - assigning return route to "211 - RGBW LED, CR Door 1 (Z)"
Z-Wave Syncing - retrieved manufacture and model names: Qubino - 0159, Flush RGBW Dimmer (ZMNHWD) - 00010054
Z-Wave Syncing - retrieved protocol version 4.24, app version 2.98
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 73v1 26v2 86v1 27v1 70v1 72v1 33v2 59v1 7Av1 5Av1 5Ev1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved parameter 7 "Power up state" is 0 "Off"
Z-Wave Syncing - retrieved parameter 14 "Dimmers mode" is 0 "Single RGBW Color Device"
Z-Wave Syncing - retrieved parameter 1 "Input 1 mode" is 4 "Brightness - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 2 "Input 2 mode" is 7 "Rainbow - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 3 "Input 3 mode" is 8 "Scene - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 4 "Input 4 mode" is 1 "Normal - Momentary Switch Type"
Z-Wave Syncing - retrieved parameter 5 "Auto scene mode" is 1 "Ocean - Flowing Shades of Blue"
Z-Wave Syncing - retrieved parameter 6 "Auto scene duration" is 3 "3 Seconds"
Z-Wave Syncing - retrieved parameter 11 "Minimum value" is 1
Z-Wave Syncing - retrieved parameter 10 "Maximum value" is 99
Z-Wave Syncing - retrieved parameter 12 "Button tap duration" is 10 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 13 "Button down duration" is 3 seconds
Z-Wave Syncing - complete
Z-Wave Syncing - started for "RGBW LED, CR Door 2 (Z)"
Z-Wave Syncing - retrieved module neighbors list: 37, 38, 39, 40, 41, 47, 56, 159, 206, 207, 208, 209, 211, 212, 214, 215, 216, 217, 218, 219, 220
Z-Wave Syncing - assigning return route to "210 - RGBW LED, CR Door 2 (Z)"
Indigo Z-Wave Version: 7.4.1
Node ID: 219
Model: Flush RGBW Dimmer (ZMNHWD)
Model ID: 00010054
Manufacturer: Qubino
Manufacturer ID: 0159
Protocol Version: 4.24
Application Version: 2.98
Model Definition Version: 3
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 73v1 26v2 86v1 27v1 70v1 72v1 33v2 59v1 7Av1 5Av1 5Ev1 25v1
Features: routing, beaming
Neighbors: 37, 38, 39, 56, 159, 185, 186, 206, 207, 208, 209, 210, 211, 212, 213, 214, 216, 217, 218, 220
Associations: 1:[1]
Config Values: 1:4 2:7 3:8 4:1 5:1 6:3 7:0 10:99 11:1 12:10 13:3 14:0
Users browsing this forum: wi_pedaler and 11 guests
