Fibaro Roller Shutter 2 Device Definition
Tue Sep 18, 2018 5:24 am
kwijibo007 offline
Hi Matt/Jay,
Could you please add a device definition for this Australian Fibaro Roller Shutter 2?
Indigo Z-Wave Version: 2.0.111
Node ID: 17
Model: Motor Control Class B
Model ID: 03023000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 3.52
Application Version: 25.25
Model Definition Version: 0
Library Type: 3
Class Name: Motor Control Class B
Class Hierarchy: 04 : 11 : 06
Command Class Base: 26
Command Versions: 20v1 85v1 26v3 31v2 32v2 8Ev1 70v1 91v1 72v1 73v1 75v1 86v1 25v1
Features: routing, beaming, energyMeter
Neighbors: 3, 4, 5, 7, 8, 9, 10, 11, 12
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Pete
Sun May 12, 2019 4:11 pm
Re: Fibaro Roller Shutter 2 Device Definition
Indigo 7.3 (and 7.3.1) are now available and should support the Fibaro Shutter Controller (FGRM222)
Mon Jun 10, 2019 3:54 pm
chrish offline
Hi Matt/Jay,
could you please add the newest Version of the Fibaro Roller Shutter 3? FGR-223 EU 5.1?
Indigo Z-Wave Version: 2.0.124
Node ID: 72
Model ID: 03031000
Protocol Version: 6.02
Application Version: 5.01
Library Type: 3
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 60v4 22v1 25v1 26v4 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
Multi-Endpoint Types: 1:(11 : 06), 2:(11 : 06)
Multi-Endpoint Classes: 1:[5E 26 85 8E 59 98 9F 6C 32 71 22], 2:[5E 26 85 8E 59 98 9F 6C 22]
Features: routing, beaming, security, energyMeter
Neighbors: 3, 4, 5, 6, 7, 9, 11, 12, 13, 16, 18, 33, 36, 41, 52, 62, 63
Thank you in advance!!
cheers
Chris
Mon Jun 10, 2019 5:59 pm
Hi Chris – Added to the list!
Fri Jun 14, 2019 8:27 am
joesan offline
Does "added to the list" mean it's done or it's on the To Do list? If the latter, can we still use the Fibaro Roller Shutter 3 before it's officially added? I've just bought 2 and would like to use them.
Fri Jun 14, 2019 10:53 am
Added to the feature request list for a future version ("added to the list" is shorthand for that).
You might be able to use them by catching/sending raw commands (though we don't know what they are until we look into it, which is what we'll do when we actually do the work to add it).
Fri Jun 14, 2019 4:04 pm
I believe for the Roller Shutter 1 and 2 they would work in Indigo before we added a definition (the def'n just added config UI). So if the Roller Shutter 3 works similarly then it might work out-of-the-box right now. Maybe Chris from above will chime in with his experience using it with Indigo.
Sat Jun 15, 2019 11:54 am
neilk offline
I have the roller shutter 3, and as Matt says it works fine, it just lacks the config UI. It looks to be the same definition as Chrish posted. It was a bit of a faff to setup without it but works without a problem once setup.
Node ID: 84
Model ID: 03031000
Application Version: 5.00
Library Type: 3
Command Versions: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 26v4 32v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Neighbors: 3, 5, 6, 8, 9, 12, 13, 14, 15, 18, 26, 27, 28, 29, 30, 33, 34, 50, 51, 53, 59, 75, 76, 77, 78, 79, 80, 81, 85, 86
Mon Jun 17, 2019 2:38 pm
joesan offline
Thanks all. That's great news! I appreciate you taking the time to give the info Neil.
Mon Jun 17, 2019 3:16 pm
neilk offline
No problem - let me know if you hit any problems and we can compare notes.
Neil
Mon Dec 02, 2019 4:30 pm
palantir offline
Node ID: 84
Model ID: 03031000
Library Type: 3
Neil, I am (trying to) use the same but am struggling. My 2 Fibaro Roller Shutter 3's are added to my system and there seems to be communication (I hear them clicking) but the curtains simple do not open reliably. It used to work (so-so). Sometimes curtains opened, sometimes not. I tried to recalibrate them and since then nothing works anymore. Tried to factory reset and re-add to Indigo, but currently my curtains wont close anymore.
Do you use them to control curtains as well? Did you have to do anything special, like calibrating them?
Ronald
Fri Apr 10, 2020 4:40 am
davinci offline
How did you setup the devices? I only get a multi level switch...
Z-Wave Indigo Device "112 - Mulitlevel Switch" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 112
Model ID: 03031000
Library Type: 3
Neighbors: 4, 5, 6, 11, 12, 27, 29, 31, 32, 40, 57, 58, 59, 60, 61, 66, 67, 68, 69, 71, 73, 74
Sun Apr 26, 2020 8:33 am
palantir offline
Node ID: 112
Model ID: 03031000
Library Type: 3
That is indeed how they show up. Could open/close the curtains or gates by sending an On/Off to the Multilevel switch...
Wed Dec 23, 2020 5:31 pm
Indigo 7.5 is now available and includes preliminary (untested) support for the Fibaro Roller Shutter 3 (FGR223). Let me know if the 3 devices Indigo defines after sync work correctly. Note you might have to edit your Triggers/Schedules or other logic to select the correct devices after you re-sync (the device order created during the sync may be different).
Fri Jan 01, 2021 4:52 pm
Dtmr offline
Hey Matt,
I'm rather a user than an expert for Z-Wave. So please bear with me if my comments are not sufficient for direct support.
I am using 4 Fibaro FGR-223 for my window shutters and I had them all running in Indigo 7.4. Simply just up/down but that was working for me :)
With 7.5, I had to resync these devices:
3 FGR-223 sync without (major - just pretty slow and with time outs) problems and I got all the features as described in the manufacturer's manual.
In Indigo 7.4, I got two elements shown for the device (one with all functions and a second one which was unused).
Now, I have 3 elements per device in a device group:
    The Energy, of the Device Group has all the settings (as typical for the first device) but i can just update/reset the power consumption.
      However, the curren load/total usage shows always 0
    The Position and the Slates/Tilt show on/off/brightness/status request functions.
      However on all elements, I receive error messages:
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Shutter Position" does not support on command
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Shutter Position" does not support off command
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Shutter Position" does not support status request command
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Slats Tilt" does not support off command
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Slats Tilt" does not support on command
      Z-Wave Error device "2. Etage - Rolladen - doppel links - Slats Tilt" does not support status request command
Consequently, I can operate the roller only manually using the wall switch :)
The 4th FGR223 refused to finish sync and I receive some encryption error messages:
    Z-Wave Syncing - started for "039 - Motor Control Class B"
    Z-Wave Syncing - retrieved module neighbors list: 16, 18, 22, 30, 32, 33, 36, 37, 38, 40
    Z-Wave Syncing - assigning return route to "039 - Motor Control Class B"
    Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Shutter Controller (FGR223) - 03031000
    Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 38
    Z-Wave Error RCVD encryptedPacket: full raw packet 01 25 00 04 00 27 1F 98 81 7A B9 D6 01 13 8B 3A F2 C2 84 53 97 1A FF 74 1B 9D 79 13 E4 0F 8F B8 32 6D 5C 4D A5 AA D9
    Z-Wave Error RCVD encryptedPacket: encrypted packet C2 84 53 97 1A FF 74 1B 9D 79 13 E4
    Z-Wave Error RCVD encryptedPacket: decrypted packet 38 27 07 B5 1B 94 44 23 3A 50 66 D1
    Z-Wave Error encrypted command received from node ID 039 has invalid CBC-MAC value (ignoring)
    Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
    Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 5D
    Z-Wave Error RCVD encryptedPacket: full raw packet 01 1E 00 04 00 27 18 98 81 A4 B4 55 52 ED DD B4 FD 50 BC A3 15 63 F3 14 83 51 4E E1 8D 10 76 E5
    Z-Wave Error RCVD encryptedPacket: encrypted packet 50 BC A3 15 63
    Z-Wave Error RCVD encryptedPacket: decrypted packet 5D 05 2D B0 D0
    Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Motor Control Class B (04 : 11 : 06, base 26)
    Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 26v1 32v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
    Z-Wave Syncing - retrieved encrypt commands: 85 86 8E 59 5A 5B 60 26 32 70 71 72 73 75 7A
    Z-Wave Syncing - retrieved capabilities: routing, beaming, security
    Z-Wave Syncing - retrieved battery level of 42%
    Z-Wave Error Syncing - failed
    Z-Wave Error Timeout waiting for "039 - Motor Control Class B". Module might be asleep, or is unreachable.
Basically, the sync stops almost always at the same position. Sometines with the encryption error messages, sometimes without.
Also, this shutterl I can operate from the wall switch without any problems.
Right next to the FGR223 which isn't synching. I have an FGRM222 for a sunshade. The FRGM222 re-synch at warp speed so I guess it's not a distance/connection problem.
Also, with the FGRM222, I only get one device element (not a device group) which includes all settings, incl. energy.
Any ideas if I make some mistakes here?
