- The syncing problems
- And the FGR-223 device definition in Indigo
It's indeed strange that the description of the first (head) device of the FGR-223 is an energy meter. That's simply not good.
Same problem here.
We have not connected it at the moment at the new awning, so we couldn't test it (we do hear the click of the relay when we switch On and Off the Device "Shutter Position")
but the sync was very fast and we haven't had any sync problems .
See log below.
Could you exclude and include one of the FGR-223's again?
- Code: Select all
Z-Wave Syncing - started for "129 - Motor Control Class B"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 10, 13, 15, 19, 20, 21, 22, 23, 24, 25, 26, 27, 29, 30, 31, 34, 35, 91, 98, 100, 102, 106, 111, 116, 117, 119, 121, 122, 123, 124, 125, 126, 127
Z-Wave Syncing - assigning return route to "129 - Motor Control Class B"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Shutter Controller (FGR223) - 03031000
Z-Wave Sync cing - retrieved protocol version 6.02, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Motor Control Class B (04 : 11 : 06, base 26)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 26v4 32v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 06), 2:(11 : 06)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 6C 32 71 22], 2:[5E 26 85 8E 59 98 9F 6C 22]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved parameter 151 "Operating mode" is 1 "Roller with Position"
Z-Wave Syncing - retrieved parameter 150 "Force calibration" is 0 "Not Calibrated"
Z-Wave Syncing - retrieved parameter 156 "Up movement duration" is 6000 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 157 "Down movement duration" is 6000 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 152 "Slats duration and gate close timer" is 150 * 10 milliseconds
Z-Wave Syncing - retrieved parameter 153 "Slats position return to previous" is 1 "When Indigo Controlled or Switch Operated"
Z-Wave Syncing - retrieved parameter 154 "Motor stop delay after end switch" is 10 * 100 milliseconds
Z-Wave Syncing - retrieved parameter 155 "Motor operation detection" is 10 watts
Z-Wave Syncing - retrieved parameter 20 "Switch type" is 0 "Momentary"
Z-Wave Syncing - retrieved parameter 40 "Switch 1 scenes" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 41 "Switch 2 scenes" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 24 "Reverse S1 and S2 input operation" is false
Z-Wave Syncing - retrieved parameter 25 "Reverse Q1 and Q2 output operation" is false
Z-Wave Syncing - retrieved parameter 61 "Power report threshold" is 15 %
Z-Wave Syncing - retrieved parameter 62 "Periodic power reports" is 3600 seconds
Z-Wave Syncing - retrieved parameter 60 "Include internal usage in power reports" is false
Z-Wave Syncing - retrieved parameter 65 "Energy report threshold" is 10 * 0.01 kWh
Z-Wave Syncing - retrieved parameter 66 "Periodic energy reports" is 3600 seconds
Z-Wave Syncing - created device "129 - Energy Meter"
Z-Wave Syncing - created device "129 - Shutter Position"
Z-Wave Syncing - created device "129 - Slats Tilt"
Z-Wave Syncing - complete
Z-Wave sent "129 - Shutter Position" status request
Z-Wave sent "129 - Shutter Position" energy status request
Z-Wave received "129 - Shutter Position" status update brightness 100
Z-Wave sent "129 - Slats Tilt" status request
