z-wave Dome Siren with siren + 10 chimes?
Mon Jun 18, 2018 7:45 pm
whmoorejr offline
Anyone messed with this yet to see how easy or PITA it is to effectively use this? I think with the multiple types of chimes, it may be neat for discerning between outdoor motion, doors, etc.
$33.40 @ Amazon:
https://www.amazon.com/Dome-Automation-DMS01-Wireless-Battery-Powered/dp/B01M1NLPKZ/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1529372434&sr=1-1-fkmr0&keywords=wave+dome+siren
Manual:
https://cache-m2.smarthome.com/manuals/12026-manual.pdf
Video...At 6:13 he tests the different sounds...
https://www.youtube.com/watch?v=Eev0gqh3knY
Bill
My Plugin: My People
Tue Jun 19, 2018 12:34 am
Re: z-wave Dome Siren with siren + 10 chimes?
That will take seconds to write a plugin for based on the manual.
Tue Jun 19, 2018 4:55 am
CliveS offline
Yes I have the Neo version (i.e. 100% clone) and it can sometimes take 20 - 30 seconds (or more) before it plays a sound, I was so impressed it now sits in the spares box!
It was much quicker to get a response from the Pushover App
CliveS
Tue Jun 19, 2018 6:19 am
whmoorejr offline
CliveS wrote:
... 20 - 30 seconds (or more) before it plays a sound
So your saying it gives an intruder enough time to make a proper introduction before being interrupted by the siren? Etiquette built right in... how thoughtful.
Bill
Sun Nov 04, 2018 1:13 pm
mijit offline
I bought this siren and it works perfectly. Sub-second delay from opening a door to hearing a chime. But my devices don't span a great physical length, so there's not much network to traverse.
I did take me a while to figure out how to configure the secondary chime. From the Indigo interface, it's Interfaces -> Z-Wave -> Modify Configuration Parameter and then set Parameter 7 to 2 and Parameter 6 to the chime you want, for example, 3 for the "Big Ben" chimes. I also set Parameter 4 to 2 to use the "middle" volume level.
The "Advance Manual" on this page gives the breakdown of configuration parameters:
https://support.domeha.com/hc/en-us/art ... 01-Manuals
It seems non-trivial to trigger different chimes based on different doors, as you'd need to send raw Z-Wave commands to the device every time to configure the correct chime before sending the Siren On event. Otherwise, you'd hear whatever the last configuration was, which could be jarring (the siren is really, really loud).
Sun Nov 25, 2018 7:28 am
lotsofdevs offline
Thanks a ton to @mijit for working this out! I managed to make this work using Action Groups. So far it works perfectly. To set up an action group:
- Select "Action Group from the left list
- New...
- Type: Z-Wave Action->Modify Z-Wave Parameter
- Select the device and set the param index to 6 to the chime you want (1-10).
- Save
- Add New
- Device Actions -> Light/Appliance Controls -> Turn On
- select the device
No need to turn it off. It will stop after one chime (depending on how long the chime lasts).
This assumes that you already sent the parameter 7 to 2 and set the volume via parameter 4. You only have to do that once.
quite a few clicks, but you can then just duplicate and change the parameter once the first one is set up and working
Sun Dec 23, 2018 2:17 pm
mijit offline
Hey @lotsofdevs, glad you got it working!
I didn't think to look in the Action Groups for a Modify Z-Wave action. It sounds like you could use that to (for example) set a different chime for each door?
I ended up creating an Action Group to configure all seven parameters available to the Dome Siren, and set the trigger type to "Indigo Server Startup". That ensures proper configuration on each reboot, and gives me something I can edit for testing on the fly with "Execute Actions Now".
Thanks for the tip!
