Question on using Z-Wave raw packet trigger
Fri Jun 01, 2018 10:20 am
norcoscia offline
Hi, I just put a Dome Z-Wave mouser in my crawlspace - there is no way to trigger the trap (that I can see, and I did not want to dead short it).
I have set up a trigger (photo below), the configuration for an event is also pictured below - does anyone know if my packet match will work?
Thank you for any help in advance.
_______
Norm
Fri Jun 01, 2018 10:26 am
mat offline
Re: Question on using Z-Wave raw packet trigger
I can't answer the question - just love the idea!!! :P :twisted: :twisted:
Late 2018 mini 10.14
Fri Jun 01, 2018 10:28 am
Based on the docs you provided, yes it will work.
I’m dubious that their docs are quite right though. The format doesn’t quite ring true with me.
I’ll double-check later.
Fri Jun 01, 2018 10:44 am
norcoscia offline
Thanks guys. I hope it works I don’t want to go into my crawl space every day to check a trap and I worry a mouse will chew through my PEX water main line.
_______
Norm
Fri Jun 01, 2018 11:10 pm
Using the Match Raw Packet should work, but I think your Match Bytes isn't correct. Based on the documentation posted, you will want this for the trap triggered:
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x13 0x08 *
And this if you want to match the trap removed/cleared:
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x13 0x00 *
You can also catch if the trap was armed and disarmed (which should be easier to test). Armed:
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x13 0x02 *
Disarmed:
* 0x71 0x05 0x00 0x00 0x00 0xFF 0x13 0x04 *
Sat Jun 02, 2018 12:28 am
Thanks Matt, that’s where I was heading, just didn’t get to my desk in time.
Norcosia, theoretically the only difference is that your docs only give the value part of the command, but you need to match on the whole length of the command. You/they could achieve it with another 8 ?’s before what they propose, but the right way is * 71 05 as Matt says.
Sat Jun 02, 2018 5:46 am
norcoscia offline
Thanks Matt, that is really helpful - as soon as my wife wakes up I'll do some testing with it - the good part is the mouser found the network and is reporting its battery value - so this should get it working great.
Thanks howarth - they were on sale recently so I figured I would take a change - fingers crossed....
I don't like the idea of killing the poor mouse but I cant afford a flood - I think going the poison route is worse and some other animal might eat a dead poisoned mouse (like a stray cat or bird).
Anyway - thanks again to both of you for the help...
_______
Norm
Mon Jun 04, 2018 2:31 pm
krissh offline
You could try my Z-wave event and alarm listener plugin. It’s made for making triggers on z-wave notifications/events and should support all types. You’ll find it in the plugin store
Edit: The 0x13 notification type is not standard z-wave and therefore not included in the plugin. But it can easily be added, just add some lines to the csv file you’ll find within the z-wave folder within the plugin
Kristian
Mon Jun 04, 2018 3:58 pm
norcoscia offline
Thx, if I cant get it to work with the Z-Wave raw packet trigger that I have set up I will give it a look!
_______
Norm
Mon Jun 04, 2018 4:10 pm
krissh wrote:
Edit: The 0x13 notification type is not standard z-wave.
Oh yes it is...
https://www.silabs.com/documents/login/ ... Class.xlsx
Mon Jun 04, 2018 11:15 pm
krissh offline
howartp wrote:
Thanks for the link. You're right, I was looking at an older Sigma document. Then I'll just get these latest notification types included in the plugin.
Users browsing this forum: Google [Bot] and 3 guests
