Yale YRL220-ZW-605, Lock
Wed May 23, 2018 10:55 am
captcurrent offline
I am now playing a little more with Z-wave with moderate success. I have installed one of these locks to replace a morninglinc.
I have confirmed its on my network.
May 23, 2018, 12:13:29 PM
Z-Wave Syncing - started for "002 - Keypad Lever Lock (AYRL220)"
Z-Wave Syncing - assigning return route to "002 - Keypad Lever Lock (AYRL220)"
Z-Wave Syncing - retrieved manufacture and model names: Yale - 0129, Keypad Lever Lock (AYRL220) - 00010000
Z-Wave Syncing - retrieved protocol version 3.34, app version 21.32
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 86v1 98v1 72v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Syncing - complete
Z-Wave sent "002 - Keypad Lever Lock (AYRL220)" status request
The trouble is that it neither locks or unlocks
The logs shows
Z-Wave sent "002 - Keypad Lever Lock (AYRL220)" lock
Z-Wave sent "002 - Keypad Lever Lock (AYRL220)" unlock
But no acknowldegement and no action on part of the lock... Any thoughts?
Wed May 23, 2018 12:57 pm
Re: Yale YRL220-ZW-605, Lock
Did you include it using encryption?
Wed May 23, 2018 1:08 pm
captcurrent offline
not that I know of
Wed May 23, 2018 1:23 pm
Well, with Locks, you have to for them to work...
Wed May 23, 2018 1:31 pm
captcurrent offline
OK deleted and tried again
May 23, 2018, 3:26:38 PM
Z-Wave started controller inclusion mode with encryption
Z-Wave stopping controller inclusion mode
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "002 - Keypad Door Lock"
Z-Wave Syncing - assigning return route to "002 - Keypad Door Lock"
Z-Wave Syncing - created device "002 - Keypad Lever Lock (AYRL220)"
May 23, 2018, 3:27:42 PM
Received INSTEON "Front room" on (button 1)
May 23, 2018, 3:28:23 PM
Still no joy. Shouldn't the lock respond to the unlock and lock??
Wed May 23, 2018 1:36 pm
Follow the Changing Existing Hardware Inclusion to Use Encryption section of the page Jay linked to. You have to completely exclude the module, then re-include it using Indigo with encryption. The inclusion time is the only time encryption can be specified.
Wed May 23, 2018 2:12 pm
captcurrent offline
SOLVEED Re: Yale YRL220-ZW-605, Lock
Thanks!! I didn't see the link.. once I did 10 minutes and I was done
