matt (support) wrote:The 04 after the the node ID (2C) is the length of the packet that starts on the next byte so the 0C is included. The very last byte is always the checksum.
dev = indigo.devices[1201449352] # your motion sensor ID here, can copy by right-clicking on the device
indigo.device.turnOn(dev, updateStatesOnly=True)
indigo.device.turnOff(dev, updateStatesOnly=True)
May 15, 2019 at 9:57:32 AM
Z-Wave controller included module: 012 - Notification Sensor
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "012 - Notification Sensor"
Z-Wave Syncing - retrieved module neighbors list: 1, 4, 5, 6, 7, 8
Z-Wave Syncing - assigning return route to "012 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Dome - 021F, Motion Sensor (DMMS1) - 00030083
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.92
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v7 72v1 73v1 71v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 720 minutes
Z-Wave Syncing - device "012 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Trigger Timer Expired - Basement Lights Off
Action Group Basement Lights Off
Z-Wave Syncing - retrieved group 4 associations: []
Sent X10 "Basement Laundry Lights" off (address)
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved parameter 4 "Enable motion sensor" is true
Sent X10 "Basement Workbench Lights" off (address)
Z-Wave Syncing - retrieved parameter 1 "Motion sensor sensitivity" is 12
Z-Wave Syncing - retrieved parameter 2 "Off delay" is 30 seconds
Z-Wave Syncing - retrieved parameter 6 "Re-trigger interval" is 8 seconds
Z-Wave Syncing - retrieved parameter 9 "Luminance sensitivity" is 100 LUX
Sent X10 "Basement Computer Light" off
Z-Wave Syncing - retrieved parameter 7 "Luminance reporting interval" is 180 seconds
Z-Wave Syncing - retrieved parameter 10 "LED blink during motion" is true
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "012 - Motion Sensor"
SQL Logger creating table device_history_31129718 for "012 - Motion Sensor"
SQL Logger adding column "batterylevel" to table device_history_31129718 ("012 - Motion Sensor")
SQL Logger adding column "batterylevel_ui" to table device_history_31129718 ("012 - Motion Sensor")
Z-Wave Syncing - created device "012 - Luminance"
SQL Logger creating table device_history_1331053306 for "012 - Luminance"
SQL Logger adding column "sensorvalue" to table device_history_1331053306 ("012 - Luminance")
Z-Wave Syncing - complete
SQL Logger adding column "sensorvalue_ui" to table device_history_1331053306 ("012 - Luminance")
Z-Wave sent "012 - Motion Sensor" status request
Z-Wave received "012 - Motion Sensor" status update is on
Z-Wave received "012 - Motion Sensor" status update battery level 100%
Z-Wave sent "012 - Luminance" status request
Z-Wave sent "Basement Wash Basin Light" off
Z-Wave sent "Basement Stairway Light" off
