Sensative Comfort - Accurate Temperature & Ambient Light
Thu May 03, 2018 1:20 pm
CliveS offline
Just got the new Sensative Strips Comfort, an Accurate Temperature and Ambient Light Sensor which looks just like the original Sensative window and door sensor.
It was included into Indigo with no problems but obviously without full support at present.
Full details from either Sensative https://www.stripsbysensative.com/comfort/ or from Vesternet who I bought it from https://www.vesternet.com/z-wave-sensative-comfort-gen5
It shows as a Multilevel Sensor (routing) and depending on which sensor was last to update you could have either lux or temp showing as the state.
Few details from the logs
2018-05-03 13:29:52.712 Z-Wave started controller inclusion mode
2018-05-03 13:30:14.856 Z-Wave controller included module: 183 - Multilevel Sensor (routing)
2018-05-03 13:30:14.878 Z-Wave stopped controller inclusion mode
2018-05-03 13:30:21.552 Z-Wave Syncing - started for "183 - Multilevel Sensor (routing)"
2018-05-03 13:30:21.597 Z-Wave Syncing - retrieved module neighbors list: - none -
2018-05-03 13:30:21.598 Z-Wave Syncing - assigning return route to "183 - Multilevel Sensor (routing)"
2018-05-03 13:30:22.053 Z-Wave Syncing - assigned return route
2018-05-03 13:30:22.657 Z-Wave Syncing - retrieved manufacture and model names: Sensative - 019A, Multilevel Sensor (routing) - 0003000A
2018-05-03 13:30:22.958 Z-Wave Syncing - retrieved protocol version 4.54, app version 0.03
2018-05-03 13:30:23.547 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
2018-05-03 13:30:23.548 Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v5 72v1 73v1 59v1 5Av1 5Ev1
2018-05-03 13:30:23.548 Z-Wave Syncing - retrieved encrypt commands: - none -
2018-05-03 13:30:23.548 Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
2018-05-03 13:30:23.881 Z-Wave Syncing - retrieved wake interval of 1440 minutes
2018-05-03 13:30:23.961 Z-Wave Syncing - device "183 - Multilevel Sensor (routing)" wake interval changed to 60 minutes
2018-05-03 13:30:24.522 Z-Wave Syncing - retrieved group 1 associations: []
2018-05-03 13:30:24.803 Z-Wave Syncing - added group 1 association to interface
2018-05-03 13:30:25.088 Z-Wave Syncing - retrieved battery level of 100%
2018-05-03 13:30:25.089 Z-Wave Syncing - retrieved battery level of 100%
2018-05-03 13:30:25.550 Z-Wave Syncing - created device "183 - Multilevel Sensor (routing)"
2018-05-03 13:30:25.556 SQL Logger creating table device_history_1183146762 for "183 - Multilevel Sensor (routing)"
2018-05-03 13:30:25.575 Z-Wave Syncing - complete
2018-05-03 13:30:25.653 SQL Logger adding column "batterylevel" to table device_history_1183146762 ("183 - Multilevel Sensor (routing)")
2018-05-03 13:30:25.655 SQL Logger adding column "sensorvalue" to table device_history_1183146762 ("183 - Multilevel Sensor (routing)")
2018-05-03 13:30:25.670 SQL Logger adding column "batterylevel_ui" to table device_history_1183146762 ("183 - Multilevel Sensor (routing)")
2018-05-03 13:30:25.723 SQL Logger modifying column "sensorvalue" type of table device_history_1183146762 ("183 - Multilevel Sensor (routing)") from integer to REAL
2018-05-03 13:30:25.800 SQL Logger adding column "sensorvalue_ui" to table device_history_1183146762 ("183 - Multilevel Sensor (routing)")
2018-05-03 13:30:25.871 Z-Wave sent "183 - Multilevel Sensor (routing)" status request
2018-05-03 13:30:26.154 Z-Wave received "183 - Multilevel Sensor (routing)" status update battery level 100%
2018-05-03 13:31:38.786 Z-Wave received "183 - Multilevel Sensor (routing)" sensor update to 283 lux
2018-05-03 13:31:38.798 Z-Wave received "183 - Multilevel Sensor (routing)" units changed to lux
2018-05-03 13:31:38.802 Z-Wave received "183 - Multilevel Sensor (routing)" sensor update to 22.1 °C
2018-05-03 13:31:38.814 Z-Wave received "183 - Multilevel Sensor (routing)" units changed to °C
2018-05-03 13:31:38.822 Z-Wave received "183 - Multilevel Sensor (routing)" status update battery level 100%
2018-05-03 13:31:53.499 Z-Wave Indigo Device "183 - Multilevel Sensor (routing)" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 183
Model: Multilevel Sensor (routing)
Model ID: 0003000A
Manufacturer: Sensative
Manufacturer ID: 019A
Protocol Version: 4.54
Application Version: 0.03
Model Definition Version: 0
Library Type: 6
Class Name: Multilevel Sensor (routing)
Class Hierarchy: 04 : 21 : 01
Command Class Base: 31
Command Versions: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v5 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1]
Config Values: - none -
RAW Data
3 May 2018, 13:50:45
Z-Wave received "183 - Multilevel Sensor (routing)" sensor update to 21.7 °C
15.3 seconds ago from 183 - Multilevel Sensor (routing):
0x01 0x0C 0x00 0x04 0x00 0xB7 0x06 0x31 0x05 0x01 0x22 0x00 0xD9 0x88
3 May 2018, 13:52:48
Z-Wave received "183 - Multilevel Sensor (routing)" sensor update to 1 lux
10.9 seconds ago from 183 - Multilevel Sensor (routing):
0x01 0x0C 0x00 0x04 0x00 0xB7 0x06 0x31 0x05 0x03 0x0A 0x00 0x01 0x7A
Can anyone write a python script to extract Lux and Temp to a variable until this is included in Indigo?
CliveS
Thu May 03, 2018 2:31 pm
Re: Sensative Comfort - Accurate Temperature & Ambient Light
Assuming that it always updates both, I think this may work:
ui_val = indigo.devices[ID_OF_SENSOR].states["sensorValue.ui"]
if ui_value.endswith(u" lux"):
   var_id = ID_OF_LUX_VARIABLE
   var_id = ID_OF_TEMP_VARIABLE
indigo.variable.updateValue(var_id, value=ui_value.split(" ")[0])
Just execute it as a device state change has any change Trigger type on the sensorValue.ui state of the sensor. Untested, but it's pretty close.
Thu May 03, 2018 4:31 pm
CliveS offline
Jay, you are a genius that worked great thank you
Now I have a weatherproof outdoor sensor that has a Temperature Range from -20 degrees C to +60 degrees C and 1-64000 LUX and around 10 year battery life.
PS
Line 1 needs changing from ui_val to ui_value for anyone else using the code.
Thanks again
CliveS
Sun May 12, 2019 4:06 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Sensative Temperature Sensor (Strips Comfort).
Users browsing this forum: No registered users and 32 guests
