Troubleshooting Z-Wave Error
Tue Apr 10, 2018 5:05 pm
CraftGeek offline
I have a couple of Schlage door locks in my z-wave network. On rare occasion the back door fails to unlock when I come home. When this happens, the log says only
" Z-Wave Error send "Back Door Lock" unlock failed"
Where do I start with troubleshooting this?
Is it a failure of the sending unit or the lock?
How do I get more data?
The Lock is reporting 99% battery.
Here is a dump of its info:
Z-Wave                          Indigo Device "Back Door Lock" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 68
Model: Door Lock (BE369/468/469)
Model ID: 63415044
Manufacturer: Schlage
Manufacturer ID: 003B
Protocol Version: 3.42
Application Version: 128.22
Model Definition Version: 0
Library Type: 6
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 20v1 80v1 62v1 63v1 85v1 86v1 22v1 70v1 71v1 72v1 98v1 7Av1 5Dv1
Encryption Status: Enabled for Commands 20 80 62 63 85 70 71 5D
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 1, 9, 20, 34, 35, 36, 37, 49, 53, 66
Associations: 1:[1]
Config Values: - none -
Sean
Wed Apr 11, 2018 10:34 am
Re: Troubleshooting Z-Wave Error
In this case I think it is a failure of the Z-Wave network to get the command to the lock. That is, the command to lock/unlock the door is failing to ACK back from the module. That would occur after the Z-Wave controller had retried the command and tried to find an alternate route to the lock. You might try moving a plugin (appliance / lamp) Z-Wave module that supports beaming (most of the new ones do) to an outlet closer to the lock to see if that helps.
Wed Apr 11, 2018 11:00 am
CraftGeek offline
:) Thanks Matt, I’ll try that. I have a Z-Wave repeater I’m not using that sounds like a good fit.
Sean
Sean
Wed Apr 11, 2018 6:53 pm
CraftGeek offline
I forgot that I have a light switch 6 inches from the lock.
Looking at the switch's properties, it says:
Model = Relay Scene Switch, firmware 5.41
Manufacturer = Unknown
Neighbors = 1, 4, 5, 6, 7, 8, 13, 14, 15, 16, 17, 18, 20, 22, 23, 24, 27, 28, 29, 30, 32, 33, 34, 36, 37, 39, 41, 42, 47, 48, 49, 52, 53, 57, 58, 59, 60
Note the device # of the lock is 68 and is not in the switch's list. The switch is #35 and is in the locks neighbor list.
Is the switch not relaying? If not is it because did not learn of the lock 6 inches away?
Is learning neighbors a manual process that I have to do when I add something?
Sean
Wed Apr 11, 2018 8:54 pm
CraftGeek offline
lanbrown wrote:
What if you optimize the Zwave network? You can find that as an option under the Zwave interface.
Trying that now. I’ll check in the morning to see what changed an report back.
Thank you.
Sean
Thu Apr 12, 2018 6:25 am
CraftGeek offline
Mixed results after the overnight optimization:
Node 35, Driveway lights:
Node 68, Back door lock:
1, 9, 20, 34, 35, 37, 49, 53, 66
Node 53, Z-Wave Repeater:
1, 6, 7, 8, 14, 18, 20, 23, 28, 33, 34, 35, 37, 38, 47, 48, 57, 58, 60, 68
The driveway lights switch did not learn of the door lock but the Z-Wave repeater that is now in an outlet 15 feet away from them did.
So, we’ll see...
Sean
Users browsing this forum: No registered users and 20 guests
