https://www.ebay.co.uk/itm/Heiman-HS2SK-Z-Smart-Plug-White-/253260185417
Much smaller than the TKB TZ69E/TZ88E @ £35.95 plus P+P and fractionally bigger than the Aeotec Smart Switch 6 @ £60.00 plus P+P
- Code: Select all
Sync and Properties
2 Dec 2017, 14:24:35
Z-Wave started controller inclusion mode
2 Dec 2017, 14:24:53
Z-Wave controller included module: 159 - Relay Power Switch
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "159 - Relay Power Switch"
Z-Wave Syncing - retrieved module neighbors list: 8, 150, 151, 153, 157, 158
Z-Wave Syncing - assigning return route to "159 - Relay Power Switch"
Z-Wave Syncing - retrieved manufacture and model names: Heiman - 0260, Relay Power Switch - 80061000
Z-Wave Syncing - retrieved protocol version 4.34, app version 1.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 86v1 27v1 72v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - created device "159 - Relay Power Switch"
SQL Logger creating table device_history_177144225 for "159 - Relay Power Switch"
Z-Wave Syncing - complete
SQL Logger adding column "accumenergytimedelta" to table device_history_177144225 ("159 - Relay Power Switch")
SQL Logger adding column "accumenergytotal" to table device_history_177144225 ("159 - Relay Power Switch")
SQL Logger adding column "curenergylevel" to table device_history_177144225 ("159 - Relay Power Switch")
2 Dec 2017, 14:25:23
Z-Wave Indigo Device "159 - Relay Power Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 159
Model: Relay Power Switch
Model ID: 80061000
Manufacturer: Heiman
Manufacturer ID: 0260
Protocol Version: 4.34
Application Version: 1.01
Model Definition Version: 0
Library Type: 6
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 72v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Features: routing, beaming, energyMeter
Neighbors: 8, 150, 151, 153, 157, 158
Associations: 1:[1]
Config Values: - none -
Z-Wave received "159 - Relay Power Switch" energy total to 16.9 kWh
SQL Logger adding column "accumenergytimedelta_ui" to table device_history_177144225 ("159 - Relay Power Switch")
SQL Logger modifying column "accumenergytotal" type of table device_history_177144225 ("159 - Relay Power Switch") from integer to REAL
SQL Logger adding column "accumenergytotal_ui" to table device_history_177144225 ("159 - Relay Power Switch")
2 Dec 2017, 14:25:58
Z-Wave sent "159 - Relay Power Switch" on
Z-Wave sent "159 - Relay Power Switch" off
Z-Wave sent "159 - Relay Power Switch" status request
Z-Wave sent "159 - Relay Power Switch" energy status request
Z-Wave sent "159 - Relay Power Switch" energy usage reset
Z-Wave received "159 - Relay Power Switch" energy total to 0.0 kWh
2 Dec 2017, 14:26:47
2 Dec 2017, 14:27:31
Enabling plugin "Z-Wave Sensor Logger 1.0.27"
Starting plugin "Z-Wave Sensor Logger 1.0.27" (pid 14596)
Started plugin "Z-Wave Sensor Logger 1.0.27"
Z-Wave Sensor Logger Debug startup called
2 Dec 2017, 14:29:10
Z-Wave Sensor Logger Debug -----
Z-Wave Sensor Logger Debug Raw command: 01 15 00 04 00 9F 0F 32 02 21 54 00 00 00 00 00 00 00 00 00 00 00 3B
Z-Wave Sensor Logger Debug Scale2: 0, Rate: 01, Meter: 00001, DP: 010, Scale1: 10, ScaleT: 010, ByteLength: 100
Z-Wave Sensor Logger Debug Bitmask: 0b10000101010100, Scale2: 0, Rate: 1, Meter: 1, DP: 2, Scale1: 10, ScaleT: 2, ByteLength: 4
Z-Wave Sensor Logger Debug Power Reported: 0.0 w
Z-Wave Sensor Logger Power Reported: 0.0 w
2 Dec 2017, 14:29:30
Z-Wave Sensor Logger Debug Raw command: 01 15 00 04 00 9F 0F 32 02 21 24 00 00 00 00 00 00 00 00 00 00 00 4B
Z-Wave Sensor Logger Debug Scale2: 0, Rate: 01, Meter: 00001, DP: 001, Scale1: 00, ScaleT: 000, ByteLength: 100
Z-Wave Sensor Logger Debug Bitmask: 0b10000100100100, Scale2: 0, Rate: 1, Meter: 1, DP: 1, Scale1: 00, ScaleT: 0, ByteLength: 4
Z-Wave Sensor Logger Debug Energy Reported: 0.0 kWh
Z-Wave Sensor Logger Energy Reported: 0.0 kWh
2 Dec 2017, 15:13:33
Z-Wave received "159 - Relay Power Switch" power load to 65.83 W
Z-Wave Sensor Logger Debug Raw command: 01 15 00 04 00 9F 0F 32 02 21 54 00 00 19 B7 00 00 00 00 00 00 00 95
Z-Wave Sensor Logger Debug Power Reported: 65.83 w
Z-Wave Sensor Logger Power Reported: 65.83 w
Z-Wave Sensor Logger Debug logging disabled
Model Smart Metering Plug HS2SK-Z-UK
Working Voltage AC220V (full voltage)
Av power consumption ≤0.5W
Power Range <3000W
Voltage Range 100~240VAC
Current Range <13A
Networking Z-Wave Ad-Hoc Network
Networking Distance ≤100m (in open area)
Working Environment -10℃~+50℃
Environment Humidity Maximum 95%RH
Dimension 79.6*67.9*62.8mm
