DOME Door Pro now working
Wed Nov 08, 2017 7:40 am
norcoscia offline
Happy to report that my DOME Door/Window Sensor Pro is now working (after updating to 7.1.1). Tamper, battery level, wake interval and Open/Close states are all working great. The device also has a Temperature Sensor which does not seem to be supported/included with 7.1.1 (yet).
Thanks for the update and as usual, fantastic work with Indigo :)
_______
Norm
Wed Nov 08, 2017 9:11 am
CliveS offline
Re: DOME Door Pro now working
It is most probably being seen as a Dome Door/Window Sensor. https://docs.domeha.com/#door-window-sensor and not the Dome Door/Window Sensor Pro. https://docs.domeha.com/#door-window-sensor-pro as they have a very similar command class (as can be seen in the links) with the exception of the temperature monitor and it also has a tamper event.
CliveS
Wed Nov 08, 2017 9:17 am
norcoscia offline
Yes, agree - but I wanted to let folks know (other than the Temp sensor) it works perfectly now and it was not working before the update unless I trapped its Z-Wave commands for open / closed and updated a variable.
See entry here
viewtopic.php?f=58&t=18777&p=142711&hilit=DOME+open+close#p142711
_______
Norm
Fri Sep 28, 2018 1:13 pm
Indigo 7.2.0 is now available for download and has Z-Wave support for the Dome Door/Window Sensor (Standard and Pro), including the temperature sensor.
Sat Sep 29, 2018 6:06 am
norcoscia offline
_______
Norm
