- Code: Select all
Mar 17, 2017, 6:15:53 PM
Z-Wave Indigo Device "017 - Routing Slave" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 20
Model: Notification Sensor
Model ID: 00040001
Manufacturer: Ecolink
Manufacturer ID: 014A
Protocol Version: 4.05
Application Version: 10.01
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2
Associations: 1:[1] 2:[]
Config Values: - none -
Appears as attached files.
