Peter thanks for your help so far.
I have detailed below where I am with this at the moment with my five ZRC-90s.
I am confused (which is easily done
![Wink :wink:](./images/smilies/icon_wink.gif)
I have two working perfectly with my ZME_UZB1 on my development system. Pressing buttons all produce the expected response in Indigo.
I have three not working that are / where attached to my production system with a Z-Stick S2.
I have only ever been able to get battery reports generated when pressing buttons on the ZRC-90s attached to the Z-Stick S2.
howarth wrote:... Has Indigo set the associations correctly - should only be 1 assoc group, which contains only Indigo.
I wonder though if your L+R buttons have got the ZRC into a confused state, thinking it's the controller, or part-controller. ...r
Associations are all OK, just showing Group 1 associated to Indigo.
Two of the three could have fallen victim to my L+R button set-up mistake?
The third one was set-up correctly and included OK but still only reports battery.
On this third one (fifth device) I thought I would try to connect it to my ZME_UZB1 but have failed. I have done a full factory reset (press R for 10 seconds and triple click on the R button) - Not sure if this is working correctly as the manual says "LED flashes twice then stay off after reset process completed. When I do it, the blue LED comes on and stays on for just over 10 seconds and then flashes once. So the device don't appear to be doing what the manual says.
Anyway, assuming this has worked I then try to include it on ZME_UZB1 by starting inclusion and then pressing the L button. The blue LED comes on and stays on permanently and nothing happens. Finally after a large number of minutes I have to take the batteries out to reset it.
I have also tried an Exclude (press L button) on the Z_Stick and again the LED comes on and stays on with no result.
One other oddity with my Z-Stick is that I have taken the batteries out of the first of the three and sync'd it which failed as expected. I then did a remove failing models from the Z_Stick and it was removed by Indigo and now doesn't show in the list of available modules when you try to add a new Z_Wave device. So far so good. However, when I put the batteries back in and press a button on the device, I can see a message for the removed node coming through on Z_Wave debug log.
Basically, I think the factory reset isn't resetting which is causing the problem but I could be wrong.
I am feeling inclined to buy a Gen 5 Z-Stick to replace the S2 as even though I have a spare ZME_UZB1 I have failed to update the firmware to the latest 5/06 - I can't get the Z_Way software to work correctly on Windows or my Raspberry Pi and their forum support is not that impressive.
A bit of a long story but I thought and hoped these devices were going to provide me with more reliable scene setting.
![Sad :(](./images/smilies/icon_sad.gif)
