- Z-Wave controller included module: 015 - Alarm Sensor (routing)
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "015 - Alarm Sensor (routing)"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 4, 5, 11, 12
Z-Wave Syncing - assigning return route to "015 - Alarm Sensor (routing)"
Z-Wave Syncing - retrieved manufacture and model names: LinearLinc - 014F, Alarm Sensor (routing) - 47423030
Z-Wave Syncing - retrieved protocol version 3.67, app version 1.04
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Sensor Alarm : Alarm Sensor (routing) (04 : A1 : 02, base 71)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 82v1 84v2 85v1 86v1 87v1 71v1 72v1 5Av1 9Cv1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 720 minutes
Z-Wave Syncing - device "015 - Alarm Sensor (routing)" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "015 - Alarm Sensor (routing)"
SQL Logger creating table device_history_563484538 for "015 - Alarm Sensor (routing)"
Z-Wave Syncing - complete
SQL Logger adding column "batterylevel_ui" to table device_history_563484538 ("015 - Alarm Sensor (routing)")
but the only state that shows up is battery level... will I have to test it and use the Raw Z-wave command to respond?
