Yale - YRD220-ZW Lock - Added as device but wont lock/unlock
Fri Dec 09, 2016 6:24 pm
mpoulson offline
I was able to add the device (log below) but when I press lock/unlock nothing happens on the lock.
Any ideas what I am missing?
Dec 9, 2016, 4:13:57 PM
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Dec 9, 2016, 4:14:14 PM
Z-Wave Syncing - started for "008 - Keypad Door Lock"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 08 01 01 71
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E
Z-Wave Debug . . getNodeNeighbors: nodeId 008, neighbors: 6, 7
Z-Wave Syncing - retrieved module neighbors list: 6, 7
Z-Wave Syncing - assigning return route to "008 - Keypad Door Lock"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 08 01 B5
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 008, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 08 24 52 E7
Z-Wave Debug RCVD nodeInfoFrame: 01 0C 00 49 84 08 06 04 40 03 72 86 98 1B
Z-Wave Debug . . nodeInfoFrame: node 008, combined class list: 20v1 62v1 63v1 86v1 98v1 72v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 08 02 72 04 25 53 EF
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 08 08 72 05 01 29 00 02 00 00 A8
Z-Wave Debug . . requestManufactureInfo: node 008, manufacturerId 0129, productId 00020000
Z-Wave Debug . . requestManufactureInfo: Yale, Keypad Deadbolt (YRD210/220/240)
Z-Wave Syncing - retrieved manufacture and model names: Yale - 0129, Keypad Deadbolt (YRD210/220/240) - 00020000
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 08 02 86 11 25 54 09
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 08 07 86 12 03 03 22 21 20 4E
Z-Wave Debug . . requestVersInfoGen: node 008, protoVers 3.34, appVers 33.32
Z-Wave Syncing - retrieved protocol version 3.34, app version 33.32
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 86v1 98v1 72v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Syncing - created device "008 - Keypad Deadbolt (YRD210/220/240)"
Z-Wave Syncing - complete
Z-Wave Debug SENT requestLockStatus1: 01 09 00 13 08 02 62 02 25 55 FF
Z-Wave Debug terminatingSyncUI
Z-Wave sent "008 - Keypad Deadbolt (YRD210/220/240)" status request
Dec 9, 2016, 4:14:50 PM
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave started controller inclusion mode with encryption
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 02 01 00 00 B1
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave stopping controller inclusion mode
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 02 06 08 00 BE
Z-Wave stopped controller inclusion mode
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 08 24 56 E3
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 08 02 72 04 25 57 EB
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 08 02 86 11 25 58 05
Z-Wave Debug SENT requestLockStatus1: 01 09 00 13 08 02 62 02 25 59 F3
Fri Dec 09, 2016 8:20 pm
Re: Yale - YRD220-ZW Lock - Added as device but wont lock/un
Looks like it was already included on the controller before you tried the inclusion with encryption. Exclude it, then start over again. With encryption.
Sat Dec 10, 2016 4:19 pm
mpoulson offline
That did not seem to work.
What I have tried.
[*]Removed lock device from Indigo
[*]Excluded the device from Zwave network
[*]Put zwave controller in include mode with encryption
[*]Went to lock and "joined network" with my Zstick Gen5
[*]Attempted to add new device with "encryption mode enabled on new device UI"
[*]-While adding it timed out many time and I tried to keep the lock alive during the addition
[*]After many time I could finally get it added (normally after moving controller out of Inclusion mode with Encryption)
Sat Dec 10, 2016 4:29 pm
Do you mean you took the zstick to the lock?
If so, that's the problem - you can't include with encryption unless the zstick is in the Mac.
Try again but leave the stick in the Mac. (It will work via network wide inclusion)
Sun Dec 11, 2016 12:16 am
srkinard offline
I had the same issues with my Yale lock, so I plugged my Z-stick Gen5 into a 12-foot USB extension cable and moved it closer to the lock...then the Include with encryption was successful. Basically I removed the wall separating the Indigo server from the hallway with the lock so it became line of sight.
Once I did that, the inclusion worked fine and the lock responds perfectly. I use the Z-Wave Lock Manager plugin that Peter (howartp) wrote and it makes managing it super easy.
Ross
Wed Dec 14, 2016 9:25 pm
mpoulson offline
Howartp - thanks for the pointers! Worked like a charm.
Skinard - I had to get a USB extension able to get this to work too.
Thu Dec 15, 2016 6:20 am
johnpolasek offline
My Kwikset 910 was so far away I had to use a USB to WIFI bridge... it appears that inclusion is a very intensive process and there can be no interference or dropped packets during it.
Sat Dec 17, 2016 12:41 pm
dz1rfj offline
johnpolasek - Can you detail what you used to create a USB to WIFI bridge?
My kwikset will not include correctly, using the usb stick, and it will not include with the stick in the mac, despite the fact that I have a zwave bulb right near the doorlock on the exterior of the cynderblock garage, and an aeotec repeater in the garage.
-Brian
Tue Jan 31, 2017 7:41 pm
Dewster35 offline
This fixed me up too guys! Thanks!
Sat Jul 27, 2019 7:19 pm
akimball offline
Here are the steps I took that finally worked thanks to this thread (yale YRD226ZW):
If previously included but no encryption, select Interfaces -> zwave -> Start controller exclusion mode.
Quickly enter your unlock code ->7 -> wheel -> 3 -> wheel.
(Device excludes from z-wave network)
Remove the lock from the door if installed. Assemble using keypad, battery-pack, and tongue bolt in the right orientation so the “handedness” will be on proper side.
Carry entire dern lock to the computer running indigo and place z-wave aeotec gen5 plus about 1-foot away. Do NOT unplug the z-wave stick like any normal person might want to do!
Factory reset the lock. (Lock must be partially removed from door to reach reset button but it’s already apart.). Remove 1 battery, press the reset button while re-inserting the battery and keep holding button for 4 or 5 seconds. Lock will factory reset.
Re-enter your code.... reset the handedness.... open a new z-wave device in indigo... press “define and sync...”
...make sure the z-wave stick is about 12-inches away from lock for the following...
THEN, enter your code >7 > wheel > 1 > wheel (work fast here)........make sure the correct node device number in indigo’s z-wave is there....finally press “New with Encryption Enabled” and .... it finally worked.
I may buy another one someday so I’m posting for posterity. Oh yeah...don’t forget to re-install the lock.
-Al
