Zooz Smart Energy Power Strip?
Thu Dec 01, 2016 3:55 pm
Different Computers offline
Ran across this looking for something else. Not crucial for me, but I can imagine replacing the power strip under my bedside table with this and cleaning up some USB adapters as I do it.
Supported?
Fri Dec 02, 2016 4:50 pm
Re: Zooz Smart Energy Power Strip?
No one has reported trying it or submitted a device profile yet. I suspect it will need a device definition added to Indigo, although it is possible it will work out of the box without one.
Fri Dec 02, 2016 10:47 pm
srkinard offline
I've considered buying one of them...but I'm torn thinking I might rather spend more for the Aeon Labs one and get energy consumption vs. USB ports.
Hard to say...if I break down and get one I'll submit info if no one else has yet.
Part of me thinks it might just work since it appears to be only 5 Z-wave switches vs the Aeon Labs with energy consumption. The Amazon reviews say this one doesn't have energy reporting.
Thu Dec 22, 2016 9:08 pm
eme jota ce offline
Just submitted a Device Report for the ZEN20 via Indigo.
Here is the Write to Log info, but please let me know if you need any other information.
Indigo Z-Wave Version: 2.0.34
Node ID: 49
Model: Power Strip
Model ID: 0651F51C
Manufacturer: Unknown
Manufacturer ID: 015D
Protocol Version: 4.05
Application Version: 20.15
Model Definition Version: 0
Library Type: 6
Class Name: Power Strip
Class Hierarchy: 04 : 10 : 04
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 8Ev1 72v1 73v1 59v1 5Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 04), 2:(10 : 04), 3:(10 : 04), 4:(10 : 04), 5:(10 : 04)
Multi-Endpoint Classes: 1:[5E 59 85 8E 20 25 27 86], 2:[5E 59 20 25], 3:[5E 59 20 25], 4:[5E 59 20 25], 5:[5E 59 20 25]
Features: routing, beaming
Neighbors: 4, 8, 12
Associations: 1:[1]
Config Values: - none -
Fri Dec 23, 2016 8:53 am
eme jota ce offline
As an update, Indigo shows the ZEN20 as five separate "Relay Switches" and allows for triggers and actions to each of the five, which is great.
Unless it's very close to the Z-Stick, I see a "no ack" error in Indigo.
Tried to delete and re-enroll. Also tried to optimize using Interface - Z-Wave - Optimize Z-Wave Network....
See the following in log:
   Z-Wave                          Optimizing - neighbor list update failed -- will try to update nearby neighbors first
   Z-Wave                          Optimizing - no known neighbors found
   Z-Wave                          Optimizing - failed "049 - Relay Switch 1 PInball Machine Power"
   Z-Wave                          Optimizing - complete
   Z-Wave Error                    Optimizing - update failed: "049 - Relay Switch 1 PInball Machine Power"
Pressing one of the ZEN20 power button three times (per instruction manual), then optimizing results in the following:
 Z-Wave                          Optimizing - started network optimization for nodes: 49
   Z-Wave                          Optimizing - starting "049 - Relay Switch 1 PInball Machine Power"
   Z-Wave                          Optimizing - ping failed
   Z-Wave                          Optimizing - finding neighbors
   Z-Wave                          Optimizing - requesting neighbor list update
Any thoughts?
Fri Dec 23, 2016 9:43 pm
No, that is an odd failure to have unless the module truly isn't in range (maybe it isn't?). Do you have other Z-Wave modules near it and are those reachable?
Try excluding it from the Z-Stick and then re-including it. It will get a different node ID, so you'll need to select the new one before trying to re-sync in.
Sat Dec 24, 2016 6:46 am
eme jota ce offline
1. Yes. Several other Z wave modules in same room, which is very small. (Linear WD500Z, Aeon switch DSC06106-ZWUS, and multi sensor 6).
2. Will do ...
Sat Dec 24, 2016 1:44 pm
eme jota ce offline
2. Will do ...
Seems to be working better. Thanks Matt. I also had the z-wave interface optimize it, which only worked on the ZEN20 by (nearly constantly) pressing one of the ZEN20 power buttons three times quickly. Otherwise, the optimization would fail in the log.
Fri May 31, 2019 1:38 pm
shrxman offline
I have a Zooz ZEN20, but the Model ID is different from @eme jota ce's output:
Indigo Z-Wave Version: 2.0.124
Node ID: 15
Model: Relay Power Switch
Model ID: A000A004
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 5.03
Application Version: 1.00
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 25v1 27v1 6Cv1 72v1 70v1 71v1 32v4 73v1 7Av1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01), 4:(10 : 01), 5:(10 : 01), 6:(10 : 01), 7:(10 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F], 4:[5E 85 59 8E 25 32 6C 9F], 5:[5E 85 59 8E 25 32 6C 9F], 6:[5E 85 25 6C 9F], 7:[5E 85 25 6C 9F]
Features: routing, beaming, energyMeter
Neighbors: 2
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[]
Outlet-1 doesn't even show up on the UI after adding the device. Seems like outlets 2-5 are handled correctly, but also that the USB ports are showing up as outlet 6 and 7. Zooz doesn't support controlling those Outlets via Zwave, or at least not currently, as far as I can tell.
Any ideas on how to get Outlet-1 to show up?
Mon Jun 10, 2019 3:22 pm
Can you re-sync the module and post the Event Log result of that?
Also inside the device dialog how many tab/panels does it create, and what is the first one called? Does that first one not control anything or does it control the 2nd outlet (and then all the rest are also off by one)?
Mon Jun 10, 2019 8:51 pm
shrxman offline
Hey Matt,
Good to hear from you. Hope all is well! :)
I just resync'd the device as is.. Did you want that, or did you need me to remove the device and add it back? Here's the output from the sync:
Z-Wave Syncing - started for "APS15_1"
Z-Wave Syncing - retrieved module neighbors list: 2
Z-Wave Syncing - assigning return route to "015 - APS15_1"
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Relay Power Switch - A000A004
Z-Wave Syncing - retrieved protocol version 5.03, app version 1.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01), 4:(10 : 01), 5:(10 : 01), 6:(10 : 01), 7:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F], 4:[5E 85 59 8E 25 32 6C 9F], 5:[5E 85 59 8E 25 32 6C 9F], 6:[5E 85 25 6C 9F], 7:[5E 85 25 6C 9F]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - complete
Z-Wave sent "APS15_1" status request
Z-Wave sent "APS15_1" energy status request
Z-Wave sent "APS15_2" status request
Z-Wave sent "APS15_2" energy status request
Z-Wave sent "APS15_3" status request
Z-Wave sent "APS15_3" energy status request
Z-Wave sent "APS15_4" status request
Z-Wave sent "APS15_4" energy status request
Z-Wave sent "APS15_5" status request
Z-Wave sent "APS15_5" energy status request
Z-Wave sent "APS15_6" status request
Z-Wave sent "APS15_7" status request
The device dialogue shows 7 relay switches:
Relay Switch 1: powers ALL on/off
Relay Switch 2: powers on/off plug labeled "ch2" (second power plug)
Relay Switch 3: powers on/off plug labeled "ch3" (second power plug)
Relay Switch 4:powers on/off plug labeled "ch4" (second power plug)
Relay Switch 5: powers on/off plug labeled "ch5" (second power plug)
Relay Switch 6: no changes on power strip
Relay Switch 7:: no changes on power strip
Here's the event log when I hit power on/off for each relay device. Notice the status update reflects off when I send and "on" command to either relay outlet 6 or 7. I believe those are for the two USB plugs that are not integrated with Zwave on this device.
  Z-Wave                          sent "APS15_1" on
   Z-Wave                          received "APS15_2" status update is on
   Z-Wave                          received "APS15_3" status update is on
   Z-Wave                          received "APS15_4" status update is on
   Z-Wave                          received "APS15_5" status update is on
   Z-Wave                          sent "APS15_1" off
   Z-Wave                          received "APS15_2" status update is off
   Z-Wave                          received "APS15_3" status update is off
   Z-Wave                          received "APS15_4" status update is off
   Z-Wave                          received "APS15_5" status update is off
   Z-Wave                          sent "APS15_2" on
   Z-Wave                          received "APS15_1" status update is on
   Z-Wave                          sent "APS15_2" off
   Z-Wave                          received "APS15_1" status update is off
   Z-Wave                          sent "APS15_3" on
   Z-Wave                          sent "APS15_3" off
Jun 10, 2019 at 7:47:35 PM
   Z-Wave                          sent "APS15_4" off
   Z-Wave                          sent "APS15_4" on
   Z-Wave                          sent "APS15_5" on
   Z-Wave                          sent "APS15_5" off
Jun 10, 2019 at 7:48:13 PM
   Z-Wave                          sent "APS15_6" on
   Z-Wave                          received "APS15_6" status update is off
   Z-Wave                          sent "APS15_6" off
   Z-Wave                          sent "APS15_7" on
   Z-Wave                          received "APS15_7" status update is off
   Z-Wave                          sent "APS15_7" off
Let me know if you need anything else on this one...
~ken
Fri Jun 14, 2019 5:09 pm
Hi Ken,
Thanks for the additional information. I'm going to email you off forum to continue troubleshooting this one.
Mon Sep 30, 2019 4:00 pm
Indigo 7.4 is now available and includes support for the Zooz Power Strip (ZEN20).
Sun Oct 20, 2019 7:21 am
chobo offline
Matt,
Thanks for adding support for this device in 7.4. Two things:
1. I had no idea the USB ports might be z-wave controllable — will test this soon.
2. Unfortunately, I'm receiving the following error when periodically polling this device:
Z-Wave Error                    device "XXX - USB Port 1" does not support status request command
Thoughts/suggestions? A resync has not resolved it.
Sun Oct 20, 2019 12:43 pm
Can you re-sync the device in Indigo then copy/paste the Event Log results into a reply for me?
Also, can you send the status request to all 8 devices Indigo created (individually) and include the Event Log results? I'm wondering if the problem is specific to the USB devices or not.
