Ran across this looking for something else. Not crucial for me, but I can imagine replacing the power strip under my bedside table with this and cleaning up some USB adapters as I do it.
Supported?
Indigo Z-Wave Version: 2.0.34
Node ID: 49
Model: Power Strip
Model ID: 0651F51C
Manufacturer: Unknown
Manufacturer ID: 015D
Protocol Version: 4.05
Application Version: 20.15
Model Definition Version: 0
Library Type: 6
Class Name: Power Strip
Class Hierarchy: 04 : 10 : 04
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 8Ev1 72v1 73v1 59v1 5Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 04), 2:(10 : 04), 3:(10 : 04), 4:(10 : 04), 5:(10 : 04)
Multi-Endpoint Classes: 1:[5E 59 85 8E 20 25 27 86], 2:[5E 59 20 25], 3:[5E 59 20 25], 4:[5E 59 20 25], 5:[5E 59 20 25]
Features: routing, beaming
Neighbors: 4, 8, 12
Associations: 1:[1]
Config Values: - none -
Z-Wave Optimizing - neighbor list update failed -- will try to update nearby neighbors first
Z-Wave Optimizing - no known neighbors found
Z-Wave Optimizing - failed "049 - Relay Switch 1 PInball Machine Power"
Z-Wave Optimizing - complete
Z-Wave Error Optimizing - update failed: "049 - Relay Switch 1 PInball Machine Power"
Z-Wave Optimizing - started network optimization for nodes: 49
Z-Wave Optimizing - starting "049 - Relay Switch 1 PInball Machine Power"
Z-Wave Optimizing - ping failed
Z-Wave Optimizing - finding neighbors
Z-Wave Optimizing - requesting neighbor list update
matt (support) wrote:No, that is an odd failure to have unless the module truly isn't in range (maybe it isn't?). Do you have other Z-Wave modules near it and are those reachable?
Try excluding it from the Z-Stick and then re-including it. It will get a different node ID, so you'll need to select the new one before trying to re-sync in.
eme jota ce wrote:matt (support) wrote:No, that is an odd failure to have unless the module truly isn't in range (maybe it isn't?). Do you have other Z-Wave modules near it and are those reachable?
1. Yes. Several other Z wave modules in same room, which is very small. (Linear WD500Z, Aeon switch DSC06106-ZWUS, and multi sensor 6).
2. Will do ...
Indigo Z-Wave Version: 2.0.124
Node ID: 15
Model: Relay Power Switch
Model ID: A000A004
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 5.03
Application Version: 1.00
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 25v1 27v1 6Cv1 72v1 70v1 71v1 32v4 73v1 7Av1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01), 4:(10 : 01), 5:(10 : 01), 6:(10 : 01), 7:(10 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F], 4:[5E 85 59 8E 25 32 6C 9F], 5:[5E 85 59 8E 25 32 6C 9F], 6:[5E 85 25 6C 9F], 7:[5E 85 25 6C 9F]
Features: routing, beaming, energyMeter
Neighbors: 2
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[]
Z-Wave Syncing - started for "APS15_1"
Z-Wave Syncing - retrieved module neighbors list: 2
Z-Wave Syncing - assigning return route to "015 - APS15_1"
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Relay Power Switch - A000A004
Z-Wave Syncing - retrieved protocol version 5.03, app version 1.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 6Cv1 72v1 8Ev1 70v1 71v1 32v4 73v1 55v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01), 3:(10 : 01), 4:(10 : 01), 5:(10 : 01), 6:(10 : 01), 7:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 25 32 6C 9F], 2:[5E 85 59 8E 25 32 6C 9F], 3:[5E 85 59 8E 25 32 6C 9F], 4:[5E 85 59 8E 25 32 6C 9F], 5:[5E 85 59 8E 25 32 6C 9F], 6:[5E 85 25 6C 9F], 7:[5E 85 25 6C 9F]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - complete
Z-Wave sent "APS15_1" status request
Z-Wave sent "APS15_1" energy status request
Z-Wave sent "APS15_2" status request
Z-Wave sent "APS15_2" energy status request
Z-Wave sent "APS15_3" status request
Z-Wave sent "APS15_3" energy status request
Z-Wave sent "APS15_4" status request
Z-Wave sent "APS15_4" energy status request
Z-Wave sent "APS15_5" status request
Z-Wave sent "APS15_5" energy status request
Z-Wave sent "APS15_6" status request
Z-Wave sent "APS15_7" status request
Z-Wave sent "APS15_1" on
Z-Wave received "APS15_2" status update is on
Z-Wave received "APS15_3" status update is on
Z-Wave received "APS15_4" status update is on
Z-Wave received "APS15_5" status update is on
Z-Wave sent "APS15_1" off
Z-Wave received "APS15_2" status update is off
Z-Wave received "APS15_3" status update is off
Z-Wave received "APS15_4" status update is off
Z-Wave received "APS15_5" status update is off
Z-Wave sent "APS15_2" on
Z-Wave received "APS15_1" status update is on
Z-Wave sent "APS15_2" off
Z-Wave received "APS15_1" status update is off
Z-Wave sent "APS15_3" on
Z-Wave sent "APS15_3" off
Jun 10, 2019 at 7:47:35 PM
Z-Wave sent "APS15_4" off
Z-Wave sent "APS15_4" on
Z-Wave sent "APS15_5" on
Z-Wave sent "APS15_5" off
Jun 10, 2019 at 7:48:13 PM
Z-Wave sent "APS15_6" on
Z-Wave received "APS15_6" status update is off
Z-Wave sent "APS15_6" off
Z-Wave sent "APS15_7" on
Z-Wave received "APS15_7" status update is off
Z-Wave sent "APS15_7" off
Z-Wave Error device "XXX - USB Port 1" does not support status request command
Users browsing this forum: No registered users and 17 guests
