J
how do i get the z stick usb dongle apart to replace battery.
thanks
ginger
Just pry the 2 sections apart at the join - may need a thin blade but I used my fingernails- its quite easy and unlikely to do any damage. You can access the battery and then snap the halves back together.
durosity wrote:Alas it needs to be disconnected from the USB power to go into pairing mode
jay (support) wrote:May not be a problem by later next week - you might want to hold off buying a replacement until then.
durosity wrote:Just cracked mine open and it looks identical around the battery area.. and also soldered on. I was kinda hoping for a little button battery that could be popped out. I think sourcing a 3.7v battery that'd fit in the space would be difficult/more expensive than it's worth.
