Hello,
I finally had the wiring upgraded so I could excitedly get my new WD500Z-1 dimmer switch added to my Indigo (v6.1.6) Z-Wave (Aeon Labs Z-Stick v2) network. I followed the directions: unplug Z-Stick, press the blue button, watch the slow-blink, then pressed the up (or down) paddle on the switch, and nothing happens. Z-Stick keeps doing the slow-blink until it just seems to stop blinking. No fast-blink, no 3-second light-on, etc. I plug it back into the Mac Mini and Indigo doesn't show any new Nodes. This is my first hard-wired dimmer switch, but I do have a few other Z-Wave devices right near this one that work fine (a plugin lamp dimmer and a battery-operated door sensor).
I see in the forums others are using this successfully, but I cannot seem to get past the first hurdle. Any advice? Thanks!
-jonathan
p.s. how long should the z-stick remain in Inclusion mode after pressing the button? i.e. how long does the battery last. Mine stops after a few minutes, but goes back to slow-blink when I press the button again.
