Device Over-the-air Firmware Updates
Wed Jan 27, 2016 3:27 pm
canalrun offline
I have a Domitech LED bulb. Their support mentioned that features I require in the bulb are available by applying a Z-Wave Over-the-Air firmware update to the bulb.
Is this over-the-air update available in Indigo?
Barry.
Wed Jan 27, 2016 5:33 pm
Re: Device Over-the-air Firmware Updates
Firmware updates would need to come from Domitech.
There's no feature in Indigo for this.
Wed Jan 27, 2016 6:55 pm
canalrun offline
Thanks for your reply.
Yes, the actual firmware would come from Domitech. As it was described, and as I understand it, there is a feature within Z-Wave that performs Over-The-Air updates of firmware on Z-Wave devices.
I'm not familiar with this. I don't know whether it's something that is new. I have seen it discussed on several other HA forums.
The ability to perform Over-The-Air updates is something Indigo would have to support.
Barry.
Thu Jan 28, 2016 1:20 am
Ah sorry.
Yes, it's a new feature that came (I think) with ZWave Plus.
Indigo doesn't yet support it; I guess it will be on the Indigo 7 wishlist but we won't know if it makes it until they release it.
I think (though I've no Plus or Gen5 devices) there's other apps available (free?) that can do this upgrade for you - it doesn't need to be Indigo.
Thu Jan 28, 2016 2:21 am
canalrun offline
Thank you. Good suggestion. I had not thought about searching for other apps.
Barry.
Fri Jan 29, 2016 10:01 am
Yeah, Indigo doesn't have OTA firmware updating capability yet and some vendors require that you use their proprietary, often Windows based, updater apps to OTA update their modules. That is, even if Indigo had the capability some vendors won't release the raw .bin firmware file to us (or anyone).
Sat Nov 25, 2017 6:13 am
CelticWebs offline
Did the OTA firmware update capability get included in newer versions of Indigo?
Sat Nov 25, 2017 8:58 am
Nope, 'fraid not yet.
Sat Nov 25, 2017 9:12 am
CelticWebs offline
Shame, it’s one of the only reasons I originally went from Vera to Fibaro Home Centre. I’m now experimenting with Indigo.
As with many things, all of the systems have good and bad points, so far the ui and OTA updates are where I think my niggles are with Indigo.
Sat Nov 25, 2017 9:21 am
It will obviously vary by user depending on the modules you have, but I’ve used Indigo for 4 years and never wished for OTA updating because none of my ~50 devices support it anyway.
As Matt said above, most manufacturers require you to use Windows PCs to do the update with their own software so it’s out of Indigo’s hands for those manufacturers.
What don’t you like about the UI?
Sat Nov 25, 2017 9:39 am
CelticWebs offline
Bearing in mind I’ve only used it for a day so far, the ui is a bit too textual, I don’t mind it but getting the wife to access may be a challenge. She liked fibaro because put simply, it was pretty. It looked nice and was simple. I’ve only got a sensor, a switch and my evo home heating on there so far. Testing things before I take the plunge and move 60+’devices and all my scenes over from fibaro.
Sat Nov 25, 2017 10:00 am
Have you found Control Pages yet.
They take a bit of designing, but those should be the primary interaction with Indigo for your wife and guests. Only you should really be in the Indigo client itself, in general.
Sat Nov 25, 2017 11:09 am
CelticWebs offline
Yes, I just started playing with them about an hour ago, Does look like it will work out OK after all :)
Sat Nov 25, 2017 11:56 am
Different Computers offline
The trick with WAF control pages is to ask her what makes sense to her. ;)
Sat Nov 25, 2017 1:52 pm
CelticWebs offline
Good idea! WAF has always been an issue, it’s why most of my house is fully automated and if you want manual she just asks Siri or Alexa and no apps or gui have to be involved at all then.
Users browsing this forum: Google [Bot] and 1 guest
