- Posted on
Tue Nov 15, 2016 10:31 am
Jaska
offline
I can not get this to work. The temperature reading appears correctly, but when I press the test button, the fire alarm state stays off.
I have exclude and re-include sensor many times, no change
Syncing - started for "076 - Smoke"
Z-Wave Syncing - retrieved module neighbors list: 5, 6, 17, 18, 20, 27, 28, 36, 40, 42, 46, 52, 55, 62
Z-Wave Syncing - assigning return route to "076 - Smoke"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smoke Sensor (FGSD002) - 0C021002
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 22v1 84v2 85v1 86v1 71v1 8Ev1 70v1 31v8 72v1 73v1 56v1 98v1 59v1 5Av1 9Cv1 7Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 360 minutes
Z-Wave Syncing - device "076 - Smoke" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: [1]
Z-Wave Syncing - group 2 association to interface already exists (skipping)
Z-Wave Syncing - group 5 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 2 "Notification flags" is 3
Z-Wave Syncing - retrieved parameter 10 "Group 2 command type" is 0
Z-Wave Syncing - retrieved parameter 11 "Group 2 command value" is 255
Z-Wave Syncing - retrieved parameter 1 "Smoke sensitivity" is 2 "Medium"
Z-Wave Syncing - retrieved parameter 3 "Visual alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 4 "Audible alerts" is 0 "Disabled"
Z-Wave Syncing - retrieved parameter 20 "Temperature interval" is 1 * 10 seconds
Z-Wave Syncing - retrieved parameter 21 "Temperature sensitivity" is 10 * 0.1°C
Z-Wave Syncing - retrieved parameter 30 "Temperature threshold" is 55 °C
Z-Wave Syncing - retrieved parameter 31 "Temperature alarm" is 1 "10 Seconds"
Z-Wave Syncing - retrieved battery level of 100%
SQL Logger creating table device_history_649013059 for "076 - Tamper"
Z-Wave Syncing - created device "076 - Tamper"
Z-Wave Syncing - created device "076 - Temperature"
SQL Logger creating table device_history_1272335134 for "076 - Temperature"
SQL Logger adding column "sensorvalue" to table device_history_1272335134 ("076 - Temperature")
Z-Wave Syncing - complete
SQL Logger adding column "sensorvalue_ui" to table device_history_1272335134 ("076 - Temperature")
Z-Wave Error device "076 - Smoke" does not support status request command
And when i press test button
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0F 00 04 00 4C 09 71 05 00 00 00 FF 01 03 00 38
Z-Wave Debug . . requestAlarmSensorStatus: node 076, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 1, valueExt 3, classSubKeyExt 7100000103
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 4C 06 31 05 01 22 01 05 AE
Z-Wave Debug . . requestVarSensorStatus: node 076, endpoint None, type 1, raw value 2201...
Z-Wave Debug . . requestVarSensorStatus: 26.1 °C (float: 26.100000)
Z-Wave received "076 - Temperature" sensor update to 26.1 °C
Z-Wave received "076 - Temperature" units changed to °C
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 4C 0A 71 05 00 00 00 FF 01 00 01 03 25
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 1, valueExt 0, classSubKeyExt 7100000100
