I have successfully paired a MimoLite device. I can turn the relay Output on and off from the Device section. I want to setup a schedule to control the relay output. When in the Create New Schedule section and select Actions I don't see the Relay Output. In Actions under Type - ZWave Controls it only shows Set RGB Levels, Modify Configuration Parameters and Send Raw Zwave command. I also tried to use Device Actions - Input Output Controls - Turn On Output. The Device entry doesn't list any devices.
Please help. Hopefully I missed something obvious
