I'm hoping someone can help. I have an Aeon Labs multisensor on my landing, when motion is detected it talks to indigo to turn the landing light on, triggers a timer etc, However over the past week or so it's now also randomly started turning on a lamp in my living room which is connected to a TKB plugin dimmer. This communication isn't going through Indigo as it doesn't know that the lamp has turned on unless i request a status update and there is no communication through the event log, The lamp also turns back off when the motion sensor is not triggered.
Has anyone else had this experience or something similar?
Below are the device properties for each device.
Thanks in advance for any help.
Andrew
Z-Wave Indigo Device "Landing Motion" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 4
Model: Multi Sensor (DSB05)
Model ID: 00020005
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.28
Application Version: 1.18
Model Definition Version: 4
Library Type: 6
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1
Features: routing, battery, beaming, waking
Neighbors: 1, 8, 10, 11, 12
Associations: 1:[1]
Config Values: 2:1 3:30 4:1 101:224 102:0 103:0 111:720 112:720 113:720 5:1
Z-Wave Indigo Device "Thai Light" Z-Wave Properties:
Node ID: 60
Model: Relay Switch (TZ66S)
Model ID: 02020611
Manufacturer: TKBHome
Manufacturer ID: 0118
Protocol Version: 3.40
Application Version: 1.12
Model Definition Version: 1
Library Type: 6
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 26v1 86v1 27v1 70v1 72v1 75v1 77v1
Features: routing, beaming
Neighbors: 1, 10, 12, 13, 14, 20, 22, 24, 27, 28, 45, 47, 54, 55, 57, 58, 59
Associations: - none -
Config Values: 19:0 1:0 3:0 4:0
