Qubino dual relay module
Wed Feb 01, 2017 12:56 pm
Mattias offline
Re: Qubino dual relay module
I excluded / included on device, and did a few on-off's on the light switch after it was re-included. See the log below. The on/off status was not changed in the user interface. The device is called:
"130 - TVrum Fönster e43 ok"
received "130 - TVrum Fönster e43 ok" power load to 30.4 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 B0 00 00 5F
Z-Wave Debug . . requestMeterLevel: node 043, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 17.6 W (float: 17.600000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 17.6 W
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 12 12 32 02 21 64 00 00 2B 13 00 0A 00 00 2B 13 00 00 00 00 9C
Z-Wave Debug . . requestMeterLevel: node 018, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 11.027 kWh (float: 11.027000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 12 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 86
Z-Wave Debug . . requestMeterLevel: node 018, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 2B 03 25 03 00 FC
Z-Wave Debug . . requestRelayStatus: node 043, endpoint None, value 0
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 2B 03 25 03 FF 03
Z-Wave Debug . . requestRelayStatus: node 043, endpoint None, value 255
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 6D 00 00 82
Z-Wave Debug . . requestMeterLevel: 10.9 W (float: 10.900000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 10.9 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 0A 0A 32 02 21 34 00 00 00 6A 00 00 A4
Z-Wave Debug . . requestMeterLevel: node 010, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 10.6 W (float: 10.600000)
Z-Wave received "137 - HallNV_ny" power load to 10.6 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 10 0A 32 02 21 34 00 00 00 9D 00 00 49
Z-Wave Debug . . requestMeterLevel: node 016, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 15.7 W (float: 15.700000)
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" power load to 15.7 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 00 00 00 EF
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 0.0 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 0B 0A 32 02 21 34 00 00 00 48 00 00 87
Z-Wave Debug . . requestMeterLevel: node 011, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 7.2 W (float: 7.200000)
Z-Wave received "129 - Ute NV Entre e11 ok" power load to 7.2 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 6C 00 00 83
Z-Wave Debug . . requestMeterLevel: 10.8 W (float: 10.800000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 10.8 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 BE 00 00 51
Z-Wave Debug . . requestMeterLevel: 19.0 W (float: 19.000000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 19.0 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 01 11 00 00 FF
Z-Wave Debug . . requestMeterLevel: 27.3 W (float: 27.300000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 27.3 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 01 19 00 00 F7
Z-Wave Debug . . requestMeterLevel: 28.1 W (float: 28.100000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 28.1 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 01 0D 00 00 E3
Z-Wave Debug . . requestMeterLevel: 26.9 W (float: 26.900000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 26.9 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 A7 00 00 48
Z-Wave Debug . . requestMeterLevel: 16.7 W (float: 16.700000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 16.7 W
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 22 03 20 01 00 F2
Z-Wave Debug . . sensorSetLevel: node 034, endpoint None, cmdClass 20, value 0
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 22 0A 71 05 00 00 00 FF 07 00 00 00 4F
Z-Wave Debug . . requestAlarmSensorStatus: node 034, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 14 12 32 02 21 64 00 01 7D 9C 02 58 00 01 7D 9C 00 00 00 00 CA
Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 97.692 kWh (float: 97.692000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 14 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Z-Wave Debug . . requestMeterLevel: node 020, endpoint None, meterType 01, raw value 7400...
Wed Feb 01, 2017 4:57 pm
Please re-sync it and copy/paste the debug logging results of that as well. Thanks.
Wed Feb 01, 2017 11:38 pm
Mattias offline
Here's the sync. I hope I caught all the relevant rows.
Z-Wave Syncing - started for "130 - TVrum Fönster e43 ok"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 2B 01 01 52
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 99 B6 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55
Z-Wave Debug . . getNodeNeighbors: nodeId 043, neighbors: 9, 12, 13, 16, 18, 19, 21, 22, 24, 27, 30
Z-Wave Syncing - retrieved module neighbors list: 9, 12, 13, 16, 18, 19, 21, 22, 24, 27, 30
Z-Wave Syncing - assigning return route to "043 - 130 - TVrum Fönster e43 ok"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 2B 01 96
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 043, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 2B 24 04 92
Z-Wave Debug RCVD nodeInfoFrame: 01 19 00 49 84 2B 13 04 10 01 5E 86 72 5A 73 20 27 25 32 60 85 8E 59 70 EF 20 18
Z-Wave Debug . . nodeInfoFrame: node 043, combined class list: 20v1 60v1 25v1 86v1 27v1 72v1 8Ev1 70v1 32v1 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 2B 02 72 04 25 05 9A
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 2B 08 72 05 01 59 00 02 00 51 AA
Z-Wave Debug . . requestManufactureInfo: node 043, manufacturerId 0159, productId 00020051
Z-Wave Debug . . requestManufactureInfo: Qubino, Flush 2 Micro Relay (ZMNHBD)
Z-Wave Syncing - retrieved manufacture and model names: Qubino - 0159, Flush 2 Micro Relay (ZMNHBD) - 00020051
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 2B 02 86 11 25 06 78
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 2B 09 86 12 03 04 05 01 01 01 00 41
Z-Wave Debug . . requestVersInfoGen: node 043, protoVers 4.05, appVers 1.01
Z-Wave Syncing - retrieved protocol version 4.05, app version 1.01
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 2B 03 86 13 60 25 07 19
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 2B 04 86 14 60 04 28
Z-Wave Debug . . requestVersInfoCmdClass: node 043, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 043, combined class list: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 32v1 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 2B 03 86 13 32 25 08 44
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 2B 04 86 14 32 04 7A
Z-Wave Debug . . requestVersInfoCmdClass: node 043, class command 32 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 043, combined class list: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 2B 02 60 07 25 09 87
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 2B 05 60 08 40 02 00 F4
Z-Wave Debug . . requestMultiEndPointInfo: node 043, numEndPoints 2, sameClass True, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 2B 03 60 09 01 25 0A 89
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 16 00 04 00 2B 10 60 0A 01 10 01 5E 86 25 20 27 85 8E 59 32 EF 20 F9
Z-Wave Debug . . requestMultiEndPointDetails: node 043, endPoint 1, notStatic False, class hierarchy 10 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 043, combined multi-endpoint types: 1:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 043, combined multi-endpoint classes: 1:[5E 86 25 20 27 85 8E 59 32]
Z-Wave Debug . . requestMultiEndPointDetails: node 043, combined multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 043, combined multi-endpoint classes: 1:[5E 86 25 20 27 85 8E 59 32], 2:[5E 86 25 20 27 85 8E 59 32]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(10 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 86 25 20 27 85 8E 59 32], 2:[5E 86 25 20 27 85 8E 59 32]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 2B 02 85 05 25 0B 62
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 2B 03 85 06 08 51
Z-Wave Debug . . requestAssociationGroupCount: node 043, group count: 8
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 01 25 0C 61
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 2B 06 85 03 01 01 00 01 5D
Z-Wave Debug . . requestAssociations: node 043, group: 1, num associations: 1, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 02 25 0D 63
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 02 10 00 4A
Z-Wave Debug . . requestAssociations: node 043, group: 2, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 2, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 03 25 0E 61
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 03 10 00 4B
Z-Wave Debug . . requestAssociations: node 043, group: 3, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 3, associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 04 25 0F 67
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 04 10 00 4C
Z-Wave Debug . . requestAssociations: node 043, group: 4, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 4, associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 05 25 10 79
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 05 10 00 4D
Z-Wave Debug . . requestAssociations: node 043, group: 5, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 5, associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 06 25 11 7B
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 06 10 00 4E
Z-Wave Debug . . requestAssociations: node 043, group: 6, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 6, associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 07 25 12 79
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 07 10 00 4F
Z-Wave Debug . . requestAssociations: node 043, group: 7, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 7, associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 08 25 13 77
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 08 10 00 40
Z-Wave Debug . . requestAssociations: node 043, group: 8, num associations: 0, max associations: 16, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 8, associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Debug SENT addInterfaceMultiInstanceAssociation: 01 0D 00 13 2B 06 8E 01 08 00 01 01 25 14 7A
Z-Wave Syncing - added group 8 multi association to interface
Z-Wave Debug . . addInterfaceAssociation: node 043, group: 8, associations: [1]
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 2B 02 32 03 25 15 CD
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 2B 04 32 04 81 05 6C
Z-Wave Debug . . requestMeterInfo: node 043, meterType 01, subTypeFlags 05, supportsReset True
Z-Wave Debug SENT requestMeterInfo: 01 0D 00 13 2B 06 60 0D 01 01 32 03 25 16 A3
Z-Wave Debug RCVD multiEndPointPacket: 01 0E 00 04 00 2B 08 60 0D 01 01 32 04 81 05 09
Z-Wave Debug . . multiEndPointPacket: node 043, endPoint 1
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 2B 04 32 04 81 05 FF
Z-Wave Debug SENT requestMeterInfo: 01 0D 00 13 2B 06 60 0D 01 02 32 03 25 17 A1
Z-Wave Debug RCVD multiEndPointPacket: 01 0E 00 04 00 2B 08 60 0D 02 01 32 04 81 05 0A
Z-Wave Debug . . multiEndPointPacket: node 043, endPoint 2
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 1E 25 18 98
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 1E 01 00 B7
Z-Wave Debug . . requestConfigVal: node 043, parm index 30, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 30 "Power up state" is 0 "Last State"
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 30:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 01 25 19 86
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 01 01 01 A9
Z-Wave Debug . . requestConfigVal: node 043, parm index 1, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 1 "Input 1 mode" is 1 "Toggle"
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 1:1 30:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 02 25 1A 86
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 02 01 01 AA
Z-Wave Debug . . requestConfigVal: node 043, parm index 2, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 2 "Input 2 mode" is 1 "Toggle"
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 1:1 2:1 30:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 3F 25 1B BA
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 3F 01 00 96
Z-Wave Debug . . requestConfigVal: node 043, parm index 63, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 63 "Output 1 type" is 0 "Normally Closed"
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 1:1 2:1 30:0 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 40 25 1C C2
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 40 01 00 E9
Z-Wave Debug . . requestConfigVal: node 043, parm index 64, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 64 "Output 2 type" is 0 "Normally Closed"
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 64:0 1:1 2:1 30:0 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 6E 25 1D ED
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 2B 06 70 06 6E 02 7F 18 A7
Z-Wave Debug . . requestConfigVal: node 043, parm index 110, value 32536 (size 2)
Z-Wave Syncing - retrieved parameter 110 "Temperature offset" is 32536 * 0.1 degrees
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 64:0 1:1 2:1 110:32536 30:0 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 78 25 1E F8
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 2B 05 70 06 78 01 05 D4
Z-Wave Debug . . requestConfigVal: node 043, parm index 120, value 5 (size 1)
Z-Wave Syncing - retrieved parameter 120 "Temperature sensitivity" is 5 * 0.1 degrees
Z-Wave Debug . . requestConfigVal: node 043, combined config vals: 64:0 1:1 2:1 110:32536 120:5 30:0 63:0
Z-Wave Syncing - complete
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 1C 0A 32 02 21 34 00 00 00 62 00 00 BA
Z-Wave Debug . . requestMeterLevel: node 028, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 9.8 W (float: 9.800000)
Z-Wave
Thu Feb 02, 2017 10:54 am
Use the Interfaces->Z-Wave->Manage Associations... menu item to manually remove the association from the Qubino ZMNHBD to the Z-Stick (Indigo) for associations #1 and #8. Next, with debug logging still enabled, re-sync the device again and copy/paste the Event Log results into a reply for me. Also manually control the module at the switch and include those results. Does it work after the re-sync?
Thu Feb 02, 2017 1:14 pm
Mattias offline
here's the sync, after group removal. (I did it two times, and I'm not sure if I got the correct log-beginning or not). OnOff log coming soon.
Z-Wave removed association of "001 - Indigo Z-Wave Interface" from "130 - TVrum Fönster e43 ok" group 8
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 08 25 AB CF
Z-Wave retrieved group 8 associations: []
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 12 12 32 02 21 64 00 00 2B 64 00 0A 00 00 2B 64 00 00 00 00 9C
Z-Wave Debug . . requestMeterLevel: 11.108 kWh (float: 11.108000)
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 2B 24 AC 3A
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 2B 02 72 04 25 AD 32
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 2B 02 86 11 25 AE D0
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 2B 03 86 13 60 25 AF B1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 2B 03 86 13 32 25 B0 FC
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 2B 02 60 07 25 B1 3F
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 2B 03 60 09 01 25 B2 31
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 2B 02 85 05 25 B3 DA
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 01 25 B4 D9
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 2B 05 85 03 01 01 00 58
Z-Wave Debug . . requestAssociations: node 043, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 043, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 02 25 B5 DB
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 03 25 B6 D9
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 04 25 B7 DF
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 05 25 B8 D1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 06 25 B9 D3
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 07 25 BA D1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 2B 03 85 02 08 25 BB DF
Z-Wave Debug SENT addInterfaceMultiInstanceAssociation: 01 0D 00 13 2B 06 8E 01 01 00 01 01 25 BC DB
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Debug . . addInterfaceAssociation: node 043, group: 1, associations: [1]
Z-Wave Debug SENT addInterfaceMultiInstanceAssociation: 01 0D 00 13 2B 06 8E 01 08 00 01 01 25 BD D3
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 2B 02 32 03 25 BE 66
Z-Wave Debug SENT requestMeterInfo: 01 0D 00 13 2B 06 60 0D 01 01 32 03 25 BF 0A
Z-Wave Debug SENT requestMeterInfo: 01 0D 00 13 2B 06 60 0D 01 02 32 03 25 C0 76
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 1E 25 C1 41
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 01 25 C2 5D
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 02 25 C3 5F
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 3F 25 C4 65
Z-Wave Debug . . requestConfigVal: requeuing 1 unsolicited packets
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 40 25 C5 1B
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 6E 25 C6 36
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 2B 03 70 05 78 25 C7 21
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 2B 06 60 0D 01 01 25 02 25 C8 6B
Z-Wave Debug terminatingSyncUI
Z-Wave sent "130 - TVrum Fönster e43 ok" status request
Z-Wave sent "130 - TVrum Fönster e43 ok" energy status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 2B 07 60 0D 01 01 25 03 00 91
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 2B 03 25 03 00 FF
Z-Wave Debug . . requestRelayStatus: node 043, endpoint 1, value 0
Z-Wave Debug SENT requestRelayStatus: 01 0D 00 13 2B 06 60 0D 01 02 25 02 25 C9 69
Z-Wave sent "130 - TVrum Tak" status request
Z-Wave sent "130 - TVrum Tak" energy status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 2B 07 60 0D 02 01 25 03 FF 6D
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 2B 03 25 03 FF FF
Z-Wave Debug . . requestRelayStatus: node 043, endpoint 2, value 255
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 02 32 01 00 25 CA 7C
Z-Wave Debug RCVD multiEndPointPacket: 01 18 00 04 00 2B 12 60 0D 02 01 32 02 21 24 00 00 00 01 00 01 00 00 00 01 80
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 2B 0E 32 02 21 24 00 00 00 01 00 01 00 00 00 01 FF
Z-Wave Debug . . requestMeterLevel: node 043, endpoint 2, meterType 01, raw value 2400...
Z-Wave Debug . . requestMeterLevel: 0.1 kWh (float: 0.100000)
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 02 32 01 10 25 CB 6D
Z-Wave Debug RCVD multiEndPointPacket: 01 14 00 04 00 2B 0E 60 0D 02 01 32 02 21 34 00 00 00 A2 00 00 23
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 A2 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 043, endpoint 2, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 16.2 W (float: 16.200000)
Z-Wave received "130 - TVrum Tak" power load to 16.2 W
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 01 32 01 00 25 CC 79
Z-Wave Debug RCVD multiEndPointPacket: 01 18 00 04 00 2B 12 60 0D 01 01 32 02 21 24 00 00 00 01 00 01 00 00 00 01 83
Z-Wave Debug . . requestMeterLevel: node 043, endpoint 1, meterType 01, raw value 2400...
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 01 32 01 10 25 CD 68
Z-Wave Debug RCVD multiEndPointPacket: 01 14 00 04 00 2B 0E 60 0D 01 01 32 02 21 34 00 00 00 00 00 00 82
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 00 00 00 FF
Z-Wave Debug . . requestMeterLevel: node 043, endpoint 1, meterType 01, raw value 3400...
Thu Feb 02, 2017 1:20 pm
Mattias offline
I did some OnOff's and when I do it from the user interface I can see something in the log-file, but when the switch is turned OnOff nothing seems to happen.
Z-Wave received "137 - HallNV_ny" power load to 10.7 W
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2B 07 60 0D 01 01 25 01 FF 25 CE 93
Z-Wave sent "130 - TVrum Fönster e43 ok" on
Z-Wave Debug queueing energy request of "043 - 130 - TVrum Fönster e43 ok" (activity detected)
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2B 07 60 0D 01 01 25 01 00 25 CF 6D
Z-Wave sent "130 - TVrum Fönster e43 ok" off
Z-Wave Debug ignoring duplicate energy request of "043 - 130 - TVrum Fönster e43 ok" (activity detected)
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2B 07 60 0D 01 01 25 01 FF 25 D0 8D
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2B 07 60 0D 01 02 25 01 00 25 D1 70
Z-Wave sent "130 - TVrum Tak" off
Z-Wave Debug SENT setRelayValue: 01 0E 00 13 2B 07 60 0D 01 02 25 01 FF 25 D2 8C
Z-Wave sent "130 - TVrum Tak" on
Z-Wave Debug polling status of node "043 - 130 - TVrum Fönster e43 ok" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 01 32 01 00 25 D3 66
Z-Wave Debug SENT requestMeterLevel: 01 0E 00 13 2B 07 60 0D 01 01 32 01 10 25 D4 71
Z-Wave Debug RCVD multiEndPointPacket: 01 14 00 04 00 2B 0E 60 0D 01 01 32 02 21 34 00 00 00 6B 00 00 E9
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 2B 0A 32 02 21 34 00 00 00 6B 00 00 FF
Z-Wave Debug . . requestMeterLevel: 10.7 W (float: 10.700000)
Z-Wave received "130 - TVrum Fönster e43 ok" power load to 10.7 W
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 25 02 84 07 57
Z-Wave Debug . . nodeAwake: node 037
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 25 02 80 02 25 D5 B0
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 25 03 80 03 64 33
Z-Wave Debug . . requestBatteryLevel: node 037, level 100
Z-Wave received "037 - 114 - Motion Sensor_Bastu e37" status update battery level 100%
Z-Wave Debug . . nodeAwake: inhibit count-- to 0
Z-Wave Debug . . nodeAwake: stopping inhibit sleep timer
Z-Wave Debug SENT goToSleep: 01 09 00 13 25 02 84 08 24 D6 BC
Z-Wave Debug RCVD packet: 01 07 00 13 D6 00 00 0D 30 (hex)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 13 12 32 02 21 64 00 01 6B 6B 02 58 00 01 6B 6A 00 00 00 00 CC
Z-Wave Debug . . requestMeterLevel: node 019, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 93.035 kWh (float: 93.035000)
Z-Wave received "122 - Eluttag_vxthus_e19_ok" energy total to 93.035 kWh
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 13 12 32 02 21 74 00 00 08 1F 00 00 00 00 00 00 00 00 00 00 90
Z-Wave Debug . . requestMeterLevel: node 019, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 2.079 W (float: 2.079000)
Z-Wave received "122 - Eluttag_vxthus_e19_ok" power load to 2.079 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 16 0A 32 02 21 34 00 00 00 00 00 00 D2
Z-Wave Debug . . requestMeterLevel: node 022, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 26 03 20 01 FF 09
Z-Wave Debug . . sensorSetLevel: node 038, endpoint None, cmdClass 20, value 255
Thu Feb 02, 2017 1:30 pm
Mattias offline
I took one of my Qubino 1-relays and turned the switch OnOff and then the log looks as below. It's updated ok in the UI, so no issues with the device, just a reference.
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" status update is off
Z-Wave Debug queueing energy request of "016 - 133 - Vardagsrum Fönster_e16 ok" (activity detected)
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 10 03 25 03 00 C7
Z-Wave Debug . . requestRelayStatus: node 016, endpoint None, value 0
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 10 0A 32 02 21 34 00 00 00 00 00 00 D4
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" power load to 0.0 W
Z-Wave Debug polling status of node "016 - 133 - Vardagsrum Fönster_e16 ok" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 10 03 32 01 00 25 DD 3E
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 10 0E 32 02 21 24 00 00 00 76 00 01 00 00 00 76 C5
Z-Wave Debug . . requestMeterLevel: node 016, endpoint None, meterType 01, raw value 2400...
Z-Wave Debug . . requestMeterLevel: 11.8 kWh (float: 11.800000)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 10 03 32 01 10 25 DE 2D
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 00 10 03 20 01 FF 3F
Z-Wave Debug . . relaySetLevel: node 016, endpoint None, value 255
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" status update is on
Z-Wave Debug RCVD requestRelayStatus: 01 09 00 04 00 10 03 25 03 FF 38
Z-Wave Debug . . requestRelayStatus: node 016, endpoint None, value 255
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 10 0A 32 02 21 34 00 00 00 9F 00 00 4B
Z-Wave Debug . . requestMeterLevel: 15.9 W (float: 15.900000)
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" power load to 15.9 W
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 10 03 32 01 00 25 DF 3C
ZEAL Warning "133 - Vardagsrum Fönster_e16 ok" slow ACK time (578 ms) on sent z-wave command: 01 0A 00 13 10 03 32 01 00 25 DF 3C
Trigger noAck
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 10 03 32 01 10 25 E0 13
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 10 0A 32 02 21 34 00 00 00 97 00 00 43
Z-Wave Debug . . requestMeterLevel: 15.1 W (float: 15.100000)
Z-Wave received "133 - Vardagsrum Fönster_e16 ok" power load to 15.1 W
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 13 12 32 02 21 64 00 01 6B 6B 02 58 00 01 6B 6B 00 00 00 00 CD
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 13 12 32 02 21 74 00 00 07 D3 00 00 00 00 00 00 00 00 00 00 53
Z-Wave Debug . . requestMeterLevel: 2.003 W (float: 2.003000)
Fri Feb 03, 2017 3:10 am
PeteVis offline
Ok, I went ahead and did the hardcore exclusion reset as suggested by CrazyFin and autolog.
The exclusion went as described, but getting the device back into Indigo wasn't as smooth as I'd hoped.
Anyway, I turned on debugging, and did not see anything appear in the log, which is odd... but after a few minutes of toggling the actual switch, suddenly a small portion popped into the log.
Is this normal ?
BTW my device is one off the earlier models, firmware 1.01 (but I do see 8 associations inside the device settings...)
Z-Wave Debug                    starting node healing thread
   Z-Wave Debug                    starting node status polling thread
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 19 00 49 84 29 13 04 10 01 5E 86 72 5A 73 20 27 25 32 60 85 8E 59 70 EF 20 1A
   Z-Wave Debug                    queueing full request of "041 - Slaapkamer Verlichting" (activity detected)
   Z-Wave Debug                    polling status of node "041 - Slaapkamer Verlichting" (post-activity full request)
   Z-Wave Debug                    SENT requestRelayStatus: 01 0D 00 13 29 06 60 0D 01 01 25 02 25 5F FE
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 29 07 60 0D 01 01 25 03 00 93
   Z-Wave Debug                    . .  multiEndPointPacket: node 041, endPoint 1
   Z-Wave Debug                    RCVD requestRelayStatus: 01 09 00 04 00 29 03 25 03 00 FF
   Z-Wave Debug                    . .  requestRelayStatus: node 041, endpoint 1, value 0
   Z-Wave Debug                    SENT requestRelayStatus: 01 0D 00 13 29 06 60 0D 01 02 25 02 25 60 C2
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 29 07 60 0D 02 01 25 03 00 90
   Z-Wave Debug                    . .  multiEndPointPacket: node 041, endPoint 2
   Z-Wave Debug                    . .  requestRelayStatus: node 041, endpoint 2, value 0
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 29 07 60 0D 01 02 32 01 00 25 61 D5
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 29 12 60 0D 02 01 32 02 21 24 00 00 00 00 00 01 00 00 00 00 82
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 29 0E 32 02 21 24 00 00 00 00 00 01 00 00 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 041, endpoint 2, meterType 01, raw value 2400...
   Z-Wave Debug                    . .  requestMeterLevel: 0.0 kWh (float: 0.000000)
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 29 07 60 0D 01 02 32 01 10 25 62 C6
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 14 00 04 00 29 0E 60 0D 02 01 32 02 21 34 00 00 00 00 00 00 83
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 29 0A 32 02 21 34 00 00 00 00 00 00 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 041, endpoint 2, meterType 01, raw value 3400...
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 29 07 60 0D 01 01 32 01 00 25 63 D4
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 29 12 60 0D 01 01 32 02 21 24 00 00 00 00 00 01 00 00 00 00 81
   Z-Wave Debug                    . .  requestMeterLevel: node 041, endpoint 1, meterType 01, raw value 2400...
   Z-Wave Debug                    SENT requestMeterLevel: 01 0E 00 13 29 07 60 0D 01 01 32 01 10 25 64 C3
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 14 00 04 00 29 0E 60 0D 01 01 32 02 21 34 00 00 00 00 00 00 80
   Z-Wave Debug                    . .  requestMeterLevel: node 041, endpoint 1, meterType 01, raw value 3400...
Fri Feb 03, 2017 9:02 am
It looks like this older firmware (1.01) version isn't wanting to send out the state changes for some reason. Try using the Interfaces->Z-Wave->Manage Associations... menu item to manually add the association from the Qubino ZMNHBD to the Z-Stick (Indigo) for associations #2 and #6. What does the debug logging output look like then when you manually control the switches?
Fri Feb 03, 2017 10:26 am
PeteVis offline
It is indeed strange.
However, with the previous Indigo version, I am certain that I got immediate messages in the debug log (see my earlier posts in this thread).
Adding the associations for #2 and #6 does improve things.
Now I see debug messages now when I toggle I1 at the switch.
However, I do not see any messages when I toggle I2 at the switch.
This is what appears for the I1 toggle :
 Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 00 29 03 20 01 FF 06
   Z-Wave Debug                    . .  relaySetLevel: node 041, endpoint None, value 255
   Z-Wave Debug                    RCVD relaySetLevel: 01 09 00 04 00 29 03 20 01 00 F9
   Z-Wave Debug                    . .  relaySetLevel: node 041, endpoint None, value 0
Thu Feb 09, 2017 1:27 pm
Colly offline
I've been in contact directly with GOAP, parent company of Qubino, recently about all of our woes with integrating the devices in to our HA systems. While they initially dismissed my requests to upgrade firmware and links that this was related to the problems I've had they finally agreed that I can return my modules directly to them. Seemingly the normal process is that the modules should be returned direct to the supplier and then back to them but we've agreed to bypass it this time. For my sins I've 9 of these modules so I'll be returning them in two batches for firmware updates. I will post an update when I've got them back and reintegrated.
Here's hoping!
Thu Feb 09, 2017 3:44 pm
CrazyFin offline
Cool that Qubino / GOP is offering you a firmware upgrade!
I have had good experience with Qubino when directly showing them that it is a firmware issue with other of their devices. They have offered me firmware upgrades but I had to pay shipping to them and back from them. In my case it was their flush-dimmer (non-Gen5-version) that did not work properly due to a firmware bug but after firmware upgrade they worked fine.
If you have not shipped away your ZMNHBDx flush dual relays yet, can you please look on the back of the devices what version number it says?
Mine has H1S5P1. I am not sure but I think S5 means some kind of firmware version. I can see that the S5 used to be S1 and then overwritten manually by some engineer at Qubino with a pen to a S3 and then that S3 has been crossed over and someone has written S5 below S3 so my units full part number is ZMNHBD1 H1S5P1.
First I thought that S5 would mean firmware 1.05 but when I look in my Indigo dev environment where I test these devices I can see in the model ID under "Edit Device Settings" the following:
"Flush 2 Micro Relay (ZMNHBD), firmware 1.02" so all my ZMNHBDx devices have firmware 1.02 and are marked H1S5P1 and have 8 association groups
Here is my device output:
Indigo Z-Wave Version: 2.0.68
Node ID: 50
Model: Flush 2 Micro Relay (ZMNHBD)
Model ID: 00020051
Manufacturer: Qubino
Manufacturer ID: 0159
Protocol Version: 4.05
Application Version: 1.02
Model Definition Version: 5
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 31v7 32v4 73v1 59v1 5Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(10 : 01), 3:(21 : 01)
Multi-Endpoint Classes: 1:[5E 86 25 20 27 85 8E 59 32], 2:[5E 86 25 20 27 85 8E 59 32], 3:[5E 86 31 85 8E 59]
Features: routing, beaming, energyMeter
Neighbors: 10
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[1]
Config Values: 64:0 1:0 2:0 110:32536 120:5 30:0 63:0
All my devices works fine in Indigo BUT when I change state of relay 1 or relay 2 via input 1 and 2 on the device itself it takes 3-5 seconds before the state change is updated in Indigo. This is not Indigos fault but rather a bad (?) firmware behaviour by the device itself. I see same thing when testing the device with other platforms like OZWCP (Open-ZWave-Control-Panel).
Thu Feb 09, 2017 4:36 pm
Colly offline
My modules are H1S2P1, I do have a dimmer that has the S* overwritten with a pen - can't remember the detail though.
My output for mine is:
Node ID: 31
Model ID: 00020051
Application Version: 1.01
Library Type: 3
Command Versions: 20v1 60v4 25v1 86v1 27v1 72v1 8Ev1 70v1 32v4 73v1 59v1 5Av1 5Ev1 85v1
Neighbors: 15, 22, 39
Associations: 1:[1] 2:[1] 3:[] 4:[] 5:[] 6:[1] 7:[] 8:[1]
Config Values: 64:0 1:1 2:1 110:0 120:5 30:0 63:0
All my devices are V1.01. The biggest issue for me is that the lights will switch back on after either a command from Indigo or from the local switch. In some cases it will turn back on 4-5 times after switching it off each time. I've also noticed that one of my modules works more reliably when the toggle switch is in the "On" position as in the supply from the switch to I1 is live - can't figure that one out.. These two issues are the main reason I felt I needed to get in touch with the manufacturer in an attempt to resolve. In general I've been happy with the dimmers and the 1 Relay modules. Although I recently purchased a Fibaro dual relay and the fact it operated correctly straight away has convinced me to steer away from Qubino for the dual relays at least.
Fri Feb 10, 2017 1:32 am
CrazyFin offline
Yepp most likely it is the firmware 1.01 that you have on your devices that is causing the issues.
All my ZMNHBDx devices has firmware 1.02 and are working fine (except for the 3-5 second delay of updating state changes to the controller when controlling the device via input I1 and/or I2).
Can you please check what your config values are for parameter no 11 to 15 and post them here?
Have you tested the stability issues you mention by using a monostable switch instead of a bi-stable switch by setting param 1 and 2 to 0? I am using mono-stable switches and have not seen those kind of stability issues of the output state that you mention above.
Anyway, I guess your problems will disappear when you get them upgraded to latest firmware. Can you please post here when you receive the first batch back to you so that we can see if Qubino has a newer firmware than 1.02 that I have on my devices.
I see two possible causes for the device you mention works better with I1 on (and connected to live 230VAC):
1. Device is internally broken in the circuitry
2. Erroneously connections of the wires to the device
You should send in that device in your first firmware upgrade batch and see if they just replace the device or actually firmware upgrade it. I see on some of my devices that has been sent into Qubino that I actually received new (or refurbished) devices back instead of the original one I did send in.
(I do most of my device testings on my lab bench with a 24VDC power supply and 24VDC lamps connected which is far less dangerous than experimenting with 230VAC... It would be good if you could test your devices that way too.)
Fri Feb 10, 2017 3:41 am
PeteVis offline
I agree that Colly is seeing some weird stuff that might indicate a defective device, I am however confident that Matt will get this sorted, no matter what the firmware version is.
The reason I am sure that it will work is that Indigo DOES reflect the correct on/off state when I poll the device.
I'd rather not set my polling to "as often as possible" (and the other options are useless imo), so I just wait patiently untill Matt comes up with something to test.
edit : I have a temporary workaround in place, there is a PIR that I pass every time I have operated the qubino switch, so I've set up a trigger for the PIR to request a full status update of the qubino every time the PIR is triggered. This updates the Indigo interface to the correct on/off state of the qubino.
Page 6 of 9 1 ... 3, 4, 5, 6, 7, 8, 9
Users browsing this forum: No registered users and 31 guests
