macpro wrote:When you edit the device settings for this dimmer, none of the parameters are available.
So you cannot edit those settings.
Unless you use "Modify Configuration Parameter" from the Interface > Z-Wave menu, but then you have to be very careful because Indigo won't validate what you're doing with the parameters.
That is correct, it is more of a GUI feature missing. I use the "Modify Configuration Parameter" and it works fine. A tip is to request the current value from the device before changing the parameter to verify that you get the expected result. Not the same as having the parameters in descriptive text, but still...
From my point of view, this lack of function isn't stopping me from buying the Dimmer 2 though. You just have to read the manual carefully before changing the parameters.
http://manuals.fibaro.com/fgd-212/Peter
