MarcoGT wrote:Hi,
is it possible to control:
- temperature
- fan speed
- working mode (aircond-de-humification)
Marco
For me, the answer has been yes and no, depending upon whether I use one of the ZXt-120's built-in IR libraries or program the IR codes, manually, and play with the codes taught to the ZXT-120.
Using ZXT-120's built in library, Indigo allows(1) changing heat/cool set points, (2)selecting heat/cool/autoheatcool mode, and (3) fan auto-on/always-on. So there's no fan speed setting or dehumidification mode (maybe other libraries offer different options in Indigo, though?) Also, since my Frigidarie Breeze isn't listed in the library, I'm using another unit's codes, which switches my unit from fahrenheit to celsius in Indigo and on the wall unit's display. Then in your Indigo control page, users could touch an icon that says "Fan only, High" and Indigo would tell the ZXT to set the unit to 28 degrees in heating mode, but the ZXT-120 would actually send the learned codes from your remote, which were se to Fan only high. Since we don't use the extreme temperature settings of our ductless hvac that the ZXT controls, this hack would work fine. If we ever need the extreme settings, we could just use the actual remote.
Manual IR programming of the ZXT-120 is described in its manual, but allows for some simple hacking for limited control of more of those unit states. In IR learning mode, the user programs 20 different sets of IR codes from the remote corresponding to one set of commands for 19 degrees through 28 degrees celsius for heat and for cool (10 each), but you wouldn't have to use those to correspond to the actual heating and cooling states. For example, unless you love making the room really hot on cold days, you might set the parameters for Heat 26, Heat 27, and heat 28 to not heat but just send fan(only) low, med, and high commands. Similarly, use the extreme lows of cool 19 and 20 for dehumidification and some other state...
