Finally got around to installing a Trade XL624 (TCONT624) and I'm seeing some behavior that I don't understand. I obtained this one on the secondary market, and I suspect that what I'm seeing is the result of an old installer setting left by the last owner. I had the thermostat professionally installed, but I wasn't home at the time. I don't believe the installer would have set something to cause what I'm seeing, but I don't know that for sure.
Included the thermostat in Indigo no problem.
Indigo didn't report humidity right away (the state humidityInput1 was not in the dict at first), but it showed up after awhile and was then visible in the Indigo UI.
The thermostat was set to heat mode.
This morning, Indigo called for heat and the thermostat display said it was on stage 2 heat.
The Indigo UI said that the thermostat was cooling, and displayed the idle icon.
I suspect it's this bit that's causing the confusion:
"Thermostat - Downstairs" is cooling (auxiliary)- Code: Select all
2019-05-10 04:40:00.021 Schedule HVAC Weekday Morning Setpoints
2019-05-10 04:40:26.755 Z-Wave received "Thermostat - Downstairs" temperature update to 65 °F
2019-05-10 04:40:32.943 Z-Wave sent "Thermostat - Downstairs" change heat setpoint to 68.0°
2019-05-10 04:40:32.969 Z-Wave sent "Thermostat - Downstairs" change cool setpoint to 74.0°
2019-05-10 04:40:37.625 Z-Wave received "Thermostat - Downstairs" heat setpoint is 68 °F
2019-05-10 04:40:38.147 Z-Wave received "Thermostat - Downstairs" cool setpoint is 74 °F
2019-05-10 04:40:38.645 Z-Wave received "Thermostat - Downstairs" is heating
2019-05-10 04:43:33.489 Z-Wave received "Thermostat - Downstairs" is cooling (auxiliary) <-----
2019-05-10 04:47:22.044 Z-Wave sent "Thermostat - Downstairs" mode status request
2019-05-10 04:47:22.044 Z-Wave received "Thermostat - Downstairs" mode is heat
2019-05-10 04:47:22.319 Z-Wave sent "Thermostat - Downstairs" fan mode status request
2019-05-10 04:47:22.319 Z-Wave received "Thermostat - Downstairs" fan mode is auto
2019-05-10 04:47:22.594 Z-Wave sent "Thermostat - Downstairs" state status request
2019-05-10 04:47:22.594 Z-Wave received "Thermostat - Downstairs" is cooling (auxiliary) <-----
2019-05-10 04:47:22.871 Z-Wave sent "Thermostat - Downstairs" fan state status request
2019-05-10 04:47:22.879 Z-Wave received "Thermostat - Downstairs" fan is on
2019-05-10 04:47:23.156 Z-Wave sent "Thermostat - Downstairs" humidity status request
2019-05-10 04:47:23.438 Z-Wave sent "Thermostat - Downstairs" temperature status request
2019-05-10 04:47:23.438 Z-Wave received "Thermostat - Downstairs" temperature update to 65 °F
2019-05-10 04:47:23.712 Z-Wave sent "Thermostat - Downstairs" heat setpoint status request
2019-05-10 04:47:23.714 Z-Wave received "Thermostat - Downstairs" heat setpoint is 68 °F
2019-05-10 04:47:23.989 Z-Wave sent "Thermostat - Downstairs" cool setpoint status request
2019-05-10 04:47:23.991 Z-Wave received "Thermostat - Downstairs" cool setpoint is 74 °F
2019-05-10 04:59:57.106 Z-Wave sent "Thermostat - Downstairs" mode status request
2019-05-10 04:59:57.106 Z-Wave received "Thermostat - Downstairs" mode is heat
2019-05-10 04:59:57.383 Z-Wave sent "Thermostat - Downstairs" fan mode status request
2019-05-10 04:59:57.383 Z-Wave received "Thermostat - Downstairs" fan mode is auto
2019-05-10 04:59:57.665 Z-Wave sent "Thermostat - Downstairs" state status request
2019-05-10 04:59:57.665 Z-Wave received "Thermostat - Downstairs" is cooling (auxiliary) <-----
2019-05-10 04:59:57.940 Z-Wave sent "Thermostat - Downstairs" fan state status request
2019-05-10 04:59:57.942 Z-Wave received "Thermostat - Downstairs" fan is on
2019-05-10 04:59:58.218 Z-Wave sent "Thermostat - Downstairs" humidity status request
2019-05-10 04:59:58.493 Z-Wave sent "Thermostat - Downstairs" temperature status request
2019-05-10 04:59:58.495 Z-Wave received "Thermostat - Downstairs" temperature update to 66 °F
2019-05-10 04:59:58.768 Z-Wave sent "Thermostat - Downstairs" heat setpoint status request
2019-05-10 04:59:58.770 Z-Wave received "Thermostat - Downstairs" heat setpoint is 68 °F
2019-05-10 04:59:59.046 Z-Wave sent "Thermostat - Downstairs" cool setpoint status request
2019-05-10 04:59:59.047 Z-Wave received "Thermostat - Downstairs" cool setpoint is 74 °F
My other XL624 doesn't display this message as far as I'm aware. I should note:
Thermostat - Downstairs Firmware: 2.31
Thermostat - Upstairs Firmware: 2.12
What is auxiliary cooling mode?
